| View previous topic :: View next topic |
| Author |
Cheap Video Converters/Peripherals |
lizlarsen Super Deluxe Wiggler
   Posts: 1970 Location: Denton, TX
Posted: Sun Feb 12, 2012 6:08 pm Post subject: |
| Quote: | | I can't seem to get this thing to sync correctly with my system. The image scrolls horizontally no matter what position the external sync switch is in. |
The LZX doesn't like to sync to a source that's far out from the NTSC sync frequency standards. It has a fairly wide range -- any camera or DVD player I've dried is fine -- the only device I have that it doesn't like is a cheapo scan converter I picked up for $30 once. I'm suspecting it's the same problem in this case. You'll need to run the media player thru a video mixer with a TBC or a TBC of some kind, to lock the LZX to it directly it sounds like.
Frustrating, I know! _________________ LZX Industries | http://www.lzxindustries.net |
| Back to top |
Posted: Sun Feb 12, 2012 6:10 pm Post subject: |
FWIW, I have a Sony network'ed media player box I paid about $80 for, that plays Netflix via wi-fi and will also play tons of video file formats off of a USB drive port. That works fine as a sync source, and has Composite, Component and HDMI outputs. I think it runs a similar software interface to the PS3. _________________ LZX Industries | http://www.lzxindustries.net |
| Back to top |
giorgio NITE MIND
   Posts: 2411 Location: BRAND NEW YORK
| Back to top |
| Back to top |
bitSmasher Common Wiggler
  Posts: 169 Location: Sydney.au
Posted: Sat Feb 18, 2012 7:09 am Post subject: |
| bitSmasher wrote: | | As an additional input, I keep a bunch of videos on my phone and pack an A/V cable for it... Will buy an ipod touch for this purpose soon enough, less liability! | After my ipod nano ended up in a drink (hah, whoops!) it's time to buy a Touch.
Pretty well convinced they're a great solution and I'd rather pay more for something reliable and versatile than suffer with compromised discount players.
edit: half hour after writing this, my girlfriend just messaged me to say I can use her old iphone for video work. total coincidence  _________________ http://www.youtube.com/user/Bitsmasher |
| Back to top |
spaceship Common Wiggler
  Posts: 191 Location: Austin, Tx
| Back to top |
Posted: Sun Jun 10, 2012 7:24 pm Post subject: |
Yep that's what you need. Nick Ciontea here also has some sort of Alesis I/O dock with a video output. _________________ LZX Industries | http://www.lzxindustries.net |
| Back to top |
giorgio NITE MIND
Posted: Sun Jun 10, 2012 10:33 pm Post subject: |
I use these all the time with a bunch of older IOS devices. they work great. I also got some cheaper versions from amazon that work, although when I plug them into my iphones a message saying they won't work comes up. maybe they don't charge or something, I can't remember. I only wish that the IOS device would play the video on its screen while sending video to the composite output. that would be the ultimate in portable video playback for me, as I use 3 iphones to play back clips i made with the LZX into my modified panasonic mx-10 mixer (one through an external TBC)
edit: i can only find 2 of my 3 apple cables so I tried one of the cheap knocksoff I have, and it works fine. I did have to plug in and rotate the iphone to portrait mode and then re-plug but it started to send video once I did that, and it is charging. _________________ ▲✌♡✂☃☂☁☀☻☹☺♢✄✐☒☠☣☢☤☎✇✈✖▼
FS in NYC: http://www.muffwiggler.com/forum/viewtopic.php?p=1160656 |
| Back to top |
| Back to top |
barto Wiggling with Experience
  Posts: 446 Location: seattle
| Back to top |
Posted: Wed Jun 13, 2012 3:51 pm Post subject: |
| barto wrote: |
that adapter isnt s-video. s-video has 4 pins |
| Back to top |
Posted: Wed Jun 13, 2012 4:21 pm Post subject: |
Those 7-pin connectors are used on some computer video cards as more of a break-out cable to give you component outs, etc.
Ambery.com makes a Composite/S-Video to Component converter that is about $80, I have one and it works well.
Doing a Component output module for the LZX system would be very straightforward, actually (just a modification on a portion of the Color Video Encoder circuitry), but so far there hasn't been a lot of requests or demand for it. It would cost about the same as the CVE. _________________ LZX Industries | http://www.lzxindustries.net |
| Back to top |
Cat-A-Tonic Lobsters love Muff
     Posts: 2648 Location: Yokohama, Japan
Posted: Fri Jun 29, 2012 11:45 pm Post subject: |
| MrDys wrote: |
http://www.ambery.com/pivipr.html
If you mult a video signal,
this is a cheap way to do mirrored/kaleidoscopic effects
(Each channel lets you pick whether horizontal or vertical or both h&v are mirrored). |
How is this working out for you? _________________ http://soundcloud.com/decay-generator
| stk wrote: |
We "deserve" exactly what we get, if we leave it up to somebody else to determine our destiny.
| Back to top |
Posted: Wed Jul 04, 2012 4:56 am Post subject: |
Does anyone know if these are good units?
-Sony SEG-2550 (Special Effects Generator)
and other various model numbers
-Asaca ASW-100 (video switcher) _________________ http://soundcloud.com/decay-generator
| stk wrote: |
| Back to top |
Posted: Wed Jul 04, 2012 10:57 pm Post subject: |
I've seen lots of awesome videos from MrDys that use the Ambery device for mirroring (see his latest post in the video clips thread.) It is pretty cool!!
I don't know anything about those SEGs, but older mixers or switches that do not have TBCs built into the inputs will be more of a chore to interface than newer ones, such as those from the late 80's and 90's. _________________ LZX Industries | http://www.lzxindustries.net |
| Back to top |
nickciontea brownshoesonly
   Posts: 1076 Location: Chicago
Posted: Thu Jul 05, 2012 4:19 pm Post subject: |
definitely worth the Alesis I/O dock if you are using an ipad..
1. if you do audio.. this thing takes care of everything from midi to audio I/O
2. gives you composite out.
3. gives you a nice angle/protection/stability for ergonomic, comfortable use. _________________ http://brownshoesonly.com | |
| Back to top |
MrDys Super Deluxe Wiggler
     Posts: 1810 Location: Baltimore
Posted: Thu Jul 05, 2012 6:08 pm Post subject: |
| Cat-A-Tonic wrote: | | MrDys wrote: |
How is this working out for you? |
Yep. What Lars said. I use it all the time for mirroring. It's also incredibly handy if you get a good shape going and you think, "Man, I wish that was oriented the other way." Switch to channel 3 and there you go. Cheap and handy. _________________
| darenager wrote: | | I wonder how many people with Maths don't know it can file a tax return, or that Plague Bearer can indeed give bears the plague |
| suitandtieguy wrote: | | STG IS ALL ABOUT THE PLUR. |
| Back to top |
Arturo00 Maximum bass on all frequencies!
  Posts: 1639 Location: Ottawa
Posted: Sun Jul 08, 2012 10:17 pm Post subject: |
I mentioned a while ago that my friend was going to sell me a TBC. I got it for $20 and had no idea what I was in for. This thing is a magic box!!! Video Feedback loops are amazing! Twisting those 4 knobs produce the trippiest resutls!
 _________________ A/V: http://www.hardscience.ca
Musics: Tapewobble | Hard Science | My Dad vs Yours
Videos: YouTube | Vimeo
Studio: Analogue Head
Titter: @hardscience |
| Back to top |
| Back to top |
Posted: Mon Jul 09, 2012 8:51 am Post subject: |
exactly the same situation with
SONY XV-Z10000
Looks great, dirt cheap, but no power cable.  _________________ http://soundcloud.com/decay-generator
| stk wrote: |
| Back to top |
