| View previous topic :: View next topic |
| Author |
!!The Pseudo 0.5 258J Build/Mod Thread!! |
Jarno Ultra Wiggler
  Posts: 768 Location: Rosmalen, NL
Posted: Thu Mar 17, 2011 4:24 am Post subject: |
I actually searched for 2n3638 and got pn3638, specs look the same, but you will need the "non -A" version because that one has a much higher Hfe.
Could only find the pn3638a on eBay, anybody got a source for these? |
| Back to top |
Peake I'm in ur DIY. Filling cases with Buchla
    Posts: 2437 Location: Loss Angeles
Posted: Thu Mar 17, 2011 2:50 pm Post subject: |
| J3RK wrote: |
Transistors:
1 J201 (or original 2N4339, or 2N3819 or other FET, J201/2N4339 HIGHLY recommended)
Caps:
1 .0047uF (Recommend Styrene for accuracy, Mylar for classic, (or C0G also for accuracy, untested)) |
The J201 and 2N4339 indeed have similar but not exact idss ranges, which is the important bit for the sine shaper. I bought 35 J201 off eBay and got two with an idss in the .8x range, four in the .7x, and the rest were well below that, in the middle of its indicated range. Buchla specified the sine shaper as requiring an idss from between .7 to 1.2, "preferably" .8 to 1.1.
The 2N3819 is way higher than this, even for its minimum; you may find interesting distortion waveforms from this...
Test rig for determining idss:
http://www.forsselltech.com/media/attachments/JFET_Jig1.pdf
Ignore everything below grounding S. In the diagram, "ground" is the negative battery terminal. One milliamp meter, one 9V battery, three alligator clips, and you're in business. G and S go to the negative terminal; a single clip to both leads is fine.
Or more simply:
-Alligator clip the + VOM lead (set it to DC current) to a 9V battery's + terminal
-Clip the - VOM lead to the FET's Drain pin
-Clip the FET's G and S pins together and on the other end, to the battery's - terminal.
Note that regarding caps, Buchla used .0047uf Polycarbonate in every one of his oscillators from the 158a through the 258c, upon which this clone is based. There is no "mylar for classic" in this instance. In the Moog 901s and EMS Synthi oscillators, yes.
I've started a parts/build blog on this oscillator, for those who wish to use some vintage parts or not. Will be updating as more is learned:
http://ebolatone.blogspot.com/2011/03/vintage-parts-in-j3rks-258ish-cl one.html
Thanks J3RK! _________________ [WTB] Buchla 266r version 1 front panel
| Back to top |
J3RK Super Deluxe Wiggler
   Posts: 2495 Location: Seattle
Posted: Thu Mar 17, 2011 3:43 pm Post subject: |
By mylar for classic I meant it contributes to a slightly thicker? Sound. There are a lot of variables at work here, but it did seem to make a slightly audible difference. Polycarbonate should be listed as well, but I haven't personally tried them. I'll definitely get some to try out now though nice blog too! I'm planning a pair of accurate/modern ones, and a pair of vintaj/mostly vintage ones. |
| Back to top |
Rod Serling Fan Club aquatic hitchhiker
   Posts: 3433 Location: Germany
Posted: Thu Mar 17, 2011 3:56 pm Post subject: |
| Glad you are doing that Peak. I am still working out my approach but I am going to do 2 double oscillators and I think I might build one of the “258s” vintage per your info and maybe go for cleaner modern (or just different) approach with the other. I like variety. |
| Back to top |
Posted: Thu Mar 17, 2011 4:27 pm Post subject: |
Interesting that, about the mylar. I'll try it too. RSFC, yes, variety is fun. I'm glad in this project that we get lots of choices. _________________ [WTB] Buchla 266r version 1 front panel |
| Back to top |
Posted: Thu Mar 17, 2011 6:00 pm Post subject: |
I just used a Greeny-esque mylar on the old one. Now to find some other varieties.  |
| Back to top |
sanders Wiggling with Experience
Posted: Thu Mar 17, 2011 8:51 pm Post subject: |
Where do u get these polycab caps?
How about the Mylar ones?
i think that my arp odyssey uses silver mica. |
| Back to top |
Posted: Thu Mar 17, 2011 11:49 pm Post subject: |
| Mylar is available pretty much anywhere. They're quite common. They're usually glossy, roundish squarish shape a lot of times. Mouser has Silver Mica. They are fairly expensive. I wanted to try them in something I was working on, but for the amount I needed, it would have been very expensive. |
| Back to top |
gwaidan Super Deluxe Wiggler
    Posts: 1666 Location: Sydney
Posted: Fri Mar 18, 2011 1:22 am Post subject: |
| Polycarbonate sorta disappeared in the early 00s, so all that's available is NOS-see http://my.execpc.com/~endlr/film.html for more details |
| Back to top |
brother303 Wiggling with Experience
   Posts: 364 Location: Ruhr-Area/Germany
Posted: Sat Mar 19, 2011 4:14 pm Post subject: |
Hi J3RK,
would it be possible to provide some wiring diagrams with the building instructions of how to wire up the tl074 (output boost) to one muck and the lin/exp-switch mod to another muck?
This would be incredibly helpful!
Best regards
Greg _________________
| Peake wrote: | | DIY is all about the backlog. If you don't have a huge backlog, you aren't trying hard enough. |
| Back to top |
Posted: Sat Mar 19, 2011 4:55 pm Post subject: |
| I can do a little non-inverting amp diagram using a TL071 or TL074. I need to go back and read through the lin exp thing again before I could do that one. It sounds simple, I just need to re-read it. |
| Back to top |
Posted: Sun Mar 20, 2011 6:25 am Post subject: |
Hi,
| J3RK wrote: | | I can do a little non-inverting amp diagram using a TL071 or TL074. I need to go back and read through the lin exp thing again before I could do that one. It sounds simple, I just need to re-read it. |
Very cool.
Thanks lot!
| Back to top |
emdot_ambient Super Deluxe Wiggler
   Posts: 2386 Location: Frederick, Maryland USA
| Back to top |
Posted: Mon Mar 21, 2011 4:36 pm Post subject: |
| None of them are THAT rare, or expensive really. If you go for a real 4339, that would be where it might get a bit expensive. Otherwise I found that J201 for the sine shaper is cheap, nearly the same, and does an excellent job. Exponential converter is relatively cheap if you go with a THAT340. It's $6 but it also takes care of another pair of matched NPNs from the board as well. The 2N3638 is hard to find, but the NTE 129 replacement for it is available, though relatively expensive. Not horrible though. CA3080s are readily available in the $2-$5 range, and that's pretty much it for the tricky stuff. You can get all of this (short of a real 4339 and the CA3080) at Mouser. |
| Back to top |
Posted: Mon Mar 21, 2011 5:45 pm Post subject: |
| J3RK wrote: | | You can get all of this (short of a real 4339 and the CA3080) at Mouser. |
I can't find THAT340s or 2k Tempcos at Mouser...unless my search skillz aren't up to snuff (which they might not be). _________________ "None of your five bar gate jumps and over sort of stuff." |
| Back to top |
thermionicjunky Thyratron Genius
      Posts: 1434 Location: San Francisco
| Back to top |
Posted: Mon Mar 21, 2011 7:25 pm Post subject: |
| That's the correct THAT chip. I forgot about the tempco. I would go to either Bridechamber or Magic Smoke for those. I'm sure there are plenty of other places, but I know they have these ones have them. Mouser may have them, but I haven't looked. I like the big PRC ones best. |
| Back to top |
| Back to top |
theantiroman Common Wiggler
  Posts: 177 Location: Inside the Beltway
Posted: Tue Mar 22, 2011 3:13 pm Post subject: |
Is anyone going to build the modern version only?
I'm going to look for a parts list for that, that is, try to assemble one.
I'm probably not too interested in tracking down crazy parts but I will be building up two boards and placing them in a single panel.
Also what is the rationale to go about running this on 12V, if it will run off that? Not really a problem if it won't; I need to learn my power supply DIY tech eventually anyway! _________________ An eagle-eyed viewer might be able to see the wires. A pedant, might be able to see the wires. But I think if you're looking at the wires you're ignoring the story. If you go to a puppet show you can see the wires. But it's about the puppets, it's not about the string. If you go to a Punch & Judy show and you're only watching the wires, you're a freak. |
| Back to top |
Luka Super Deluxe Wiggler
    Posts: 4910 Location: melbourne
Posted: Tue Mar 22, 2011 3:26 pm Post subject: |
i think ill use modern parts and wont bother with THAT IC _________________ .
melbourne australia
soundcloud
lastfm
vimeo
wtb:
220/230/240v Broken Dp4
20x20 ghielmetti matrix
taking offers on (melbourne pickup)
revox pr99 mk2
allenheath zed420 |
| Back to top |
