My Simple Clock Divider (does it make sense?)
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author My Simple Clock Divider (does it make sense?)
fonik
Last Visit: 21 May 2013
PostPosted: Sun Feb 08, 2009 6:22 pm    Post subject: My Simple Clock Divider (does it make sense?) Reply with quote Add User to Ignore List
below you see pictures of my finished divider module. i posted this over at e-m.com as well, but i have a couple of questions and wanted to be sure to get the opinions of you patch experienced folks.
for the divisions i used inverters. why? this way all divisions are "ON" when reset pulse is received.
i never have had a divider before, and for me it has been just natural to have it this way. i looked about it as it would be a sequencer: i.e. the Klee2 sequencer reloads on the pulse and is at the "one" of the pattern when reload (reset) pulse is received. i would think a divider should operate the same way, when it gets controlled by another divider or sequencer or whatever. am i wrong here? woult it be better to have all divisions "OFF" when reset is received? then the reset pulse would have to be the last step in a sequence!?
any opinion would be appreciated...
cheers,
matthias
www.modular.fonik.de
www.fonitronik.de
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids)
Cat-A-Tonic
Lobsters love Muff
PostPosted: Sun Feb 08, 2009 6:39 pm    Post subject: Reply with quote Add User to Ignore List
Quoted from Ken Stone (on his CGS Pulse Divider):
The divider is used to generate interrelated pulses for use in creating poly-rhythms, and unusual sequences. It can also be run at audio frequencies as a sub-oscillator/sub harmonic generator. The output pulse from each division is one clock cycle in length, and the relationship between pulses is fixed. Specifically, the /4 output will correspond to every second pulse from the /2 output. Likewise, the /8 will correspond to every second pulse from the /4 output, and the /6 will correspond to every second pulse from the /3 output. Needless to say, the /2 and /3 groups are not related to each other, or to the /5 or /7 outputs. All however share a common external reset, so they can be synchronized. All outputs go high on reset.
Feed a clock signal into the input of the pulse divider. The divided signal is available simultaneously for each output. If running at audio frequencies, feed some of these to a mixer or other signal processing device. If running at low speed, try driving two different sequencers at the same time from different divisions.
Try feeding the /8 output into the reset - this will force all to synchronize to a /7 count, with the lesser divisions becoming "syncopated".
I think you will miss not having the odd divisions.
Resetting to odd divisions yields interesting time signatures, polyrhythms, and syncopations as described above.
Resetting from Logic is fun too.
If possible you should at least add a /3 output as it is the modt useful of the odd divisions.
Think waltz or triplet.
Other than that your module looks very nice as usual.
It is nice that yours goes to /16, and /32.
http://soundcloud.com/decay-generator
stk wrote:
We "deserve" exactly what we get, if we leave it up to somebody else to determine our destiny.
neandrewthal
full clout y'all
Last Visit: 20 May 2013
Location: Spending warm summer days indoors writing frightening verse to a buck-toothed girl in Luxembourg
PostPosted: Sun Feb 08, 2009 8:48 pm    Post subject: Reply with quote Add User to Ignore List
I agree, but I also think a module with even divisions from 2-32 is just as useful as well in it's own way.
I think the most useful/flexible way of handling divisions would be to have 2 separate modules. One like foniks that offers long divisions and one like the CGS which offers shorter odd divisions. That way you can easily do both your triplets and your 16-32-64-128 etc... divisions and anything in between can be achieved with logic. You could also use both independently if you want.
Nice module BTW. I'd jump for it in a second if I didn't already have 2x pulse dividers/master divider/suboscillator/vc divider lined up.
It was only a hundred miles or so to the ice caverns, and the second day, when we were lying out under the blistering sun-thing he had materialized, he sent down some manna. Tasted like boiled boar urine. We ate it.
plord
Wacky for Wiard Wiggler
PostPosted: Sun Feb 08, 2009 11:31 pm    Post subject: Reply with quote Add User to Ignore List
Regarding the inverters, I think no matter what you do some people will complain, because not every clocked OR clock-generating module is going to behave the same. I get all kinds of different behavior from clocked and clockable stuff around here. The CGS outputs all go high on reset, as noted, which may or may not be what you wanted to have happen if, for example, you're using the /4 to step through slow sequencer key changes on a /8 or /6 pattern confused On the other hand, as the Analogue Soutions people are fond of pointing out, resetting to one on step 16 won't always be the right thing either, which is why they reset to step 16 on the Oberkorn.
Anyway, sometimes I lose the 1, and the only way to get it back is a hard reset on the whole system. Drag :(
plord
PostPosted: Sun Feb 08, 2009 11:33 pm    Post subject: Reply with quote Add User to Ignore List
Oh, and: I'm totally in for 2 or 3 of these regardless of their reset behavior. A skinny little Frac divider just dedicated to making the long divisions? I'm all over it.
consumed
International Filter Conspiracy
PostPosted: Mon Feb 09, 2009 12:19 am    Post subject: Re: My Simple Clock Divider (does it make sense?) Reply with quote Add User to Ignore List
nice looking design matthias!
all steps on at reset? interesting. ill have to think about that for a bit.
my only clock divider is the doepfer 160 (which does not work that way).
question: is your clock divider putting trigger-like pulses out at every stage?
on the a160, every next clock output gate length is double the length of the previous output.
(so /2 gate is one clock cycle high/one low, /4 gate is 2 clock cycles high/2 low, etc)
i dont know how it would work out to have those occur on the 1.
soundcloud | bandcamp
A Dingleberry Monstrosity
eat the kids first
PostPosted: Mon Feb 09, 2009 1:26 am    Post subject: Reply with quote Add User to Ignore List
looks fine to me, but thats only after a quick glance. At first I was rather confused about having the 1/ there, but if you you wanted to tap the stock signal then that would save you from having to use a mult.
throw in some "and" gates to get everything else
for example "1 and 2" = 3
"1 and 4" = 5
etc etc SlayerBadger!
For Sale - All proceeds go to muff wiggler for the site and/or to help with hospital bills (You will paypal him directly, not me)
http://www.muffwiggler.com/forum/viewtopic.php?p=1172380
fonik
PostPosted: Mon Feb 09, 2009 4:50 am    Post subject: Re: My Simple Clock Divider (does it make sense?) Reply with quote Add User to Ignore List
wow. thanks for all your professional opinions and thoughts about this. great input. w00t
will have to think about all this for a while...
i wanted to keep things simple and not suffer from feature creep. so no odd divisions yet. however, i will think about it. and it seems this divider could be a nice addition to existing designs - that is what i get from some of your statements.
no, not triggers, just gates as the dopefer does (or the CGS). would triggers be more desireable? a module could provide both and/or selectable for sure (just AND gates to combine the incoming clock with the divisions), but then i fear the feature creep again...
that was the idea. one could easily chain multiple dividers.
cheers,
matthias
www.fonitronik.de
fonitronik at
Leisure Cove
PostPosted: Mon Feb 09, 2009 10:18 am    Post subject: Reply with quote Add User to Ignore List
"1 and 4" = 5
I've been wondering how I could get odd divisions out of a clock divider! Thanks! I love this forum.
Also, beautiful and inspiring work as always, Fonik.
https://vimeo.com/user262182/videos
www.theshamblers.blogspot.com
View user's profile Send private message AIM Address
fonik
PostPosted: Mon Feb 09, 2009 11:29 am    Post subject: Reply with quote Add User to Ignore List
"1 and 4" = 5
depends on the design of the divider. mine is 4024 based, so no way. using the 4017 you could have odd divisions (refer to ken stones designs or yves ussons divider).
i.e. an AND gate for division 1 AND 4 would just result in the 4, since both inputs have to be high for the AND gate output to be high wink
cheers,
matthias
www.fonitronik.de
fonitronik at
otherunicorn
Santa
PostPosted: Tue Mar 03, 2009 6:49 am    Post subject: Reply with quote Add User to Ignore List
The reason for resetting to ON is simple - You want to reset to step 1, not step 0. This is music, not maths.
As for resetting to step 16 instead of step 1, there is reason for that too - if you want to advance to the first step with the first pulse. It all depends on how you play.
I have long thought that a sequencer should have an extra 1/2 stage (not 1/2 step!!) - an initial "0" stage with no pots or outputs. A sequence would be "initiated" to this stage, so that it advanced to step 1 on the first clock pulse. It would then be out of the loop, with "reset" taking the sequence back to step 1 with each successive cycle.
fonik
PostPosted: Tue Mar 03, 2009 7:06 am    Post subject: Reply with quote Add User to Ignore List
couldn't have said it better. grin
cheers,
matthias
www.fonitronik.de
fonitronik at
otherunicorn
Santa
PostPosted: Tue Mar 03, 2009 6:04 pm    Post subject: Reply with quote Add User to Ignore List
There is another difference I forgot to mention - binary counters advance on the falling edge of a clock signal. Synth modules are triggered by a rising edge (trig or gate) signal.
fonik
PostPosted: Wed Mar 04, 2009 4:43 am    Post subject: Reply with quote Add User to Ignore List
that is true for the binary counter IC itself. however my module advances ont the rising edge - just a question of implementation...
cheers,
matthias
www.fonitronik.de
fonitronik at
zthee
Panelhöna
PostPosted: Wed Mar 04, 2009 4:53 am    Post subject: Reply with quote Add User to Ignore List
The 4024 goes high and remains high for the entire duration of that division? I.e. the /8 output goes high on the 8th step and low after 8 steps?
Wouldn't it be good to add a trig output to the circuit? So you can have a short pulse sent at every division as well?
Information regarding the Two Thousand Six Hundred DIY project - > http://www.thehumancomparator.net
_
"Oh Batman, why you got to be so heteronormative?".
fonik
PostPosted: Wed Mar 04, 2009 5:37 pm    Post subject: Reply with quote Add User to Ignore List
it goes high for 1st to 4th step and low for 5th to 8th step. see picture:
yes and yes. however, i called it "simple divider" grin
i wanted to prevent any feature creep. i am thinking of offering a cheap PCB, though. it would be just this simple. i like this idea.
BTW the /1 output works as a conditioner (did not mention it earlier).
cheers,
matthias
www.fonitronik.de
fonitronik at
zthee
Panelhöna
PostPosted: Thu Mar 05, 2009 1:56 am    Post subject: Reply with quote Add User to Ignore List
Ooops, missed that part! grin It's so easy to get carried away! d'oh!
Hope you'll make a run out of your quantizer aswell? SlayerBadger!
_
fonik
PostPosted: Thu Mar 05, 2009 7:12 am    Post subject: Reply with quote Add User to Ignore List
8)
sure. that is the plan (actually scott suggested it to me). i hope i will be able to improve it's performance, though. it will require some ICs more and then i will need the to invest some money in the eagle standard version (but that was part of my plan for this year anyway). yes, DIY can be expensive, especially if you want to do it right.
cheers,
matthias
www.fonitronik.de
fonitronik at
zthee
Panelhöna
PostPosted: Thu Mar 05, 2009 7:57 am    Post subject: Reply with quote Add User to Ignore List
You rock man! we're not worthy we're not worthy
I'll def. take 2 of the quantizer board when it done! w00t
_
Kwote
Voltage Controlled Crackpot
Last Visit: 14 May 2011
PostPosted: Fri Mar 06, 2009 2:32 pm    Post subject: Reply with quote Add User to Ignore List
I missed the mention of the quantizer but I’d definitely be interested in that board so please keep us posted.
kwotemusic.com
my other sites
fonik
PostPosted: Fri Mar 06, 2009 5:54 pm    Post subject: Reply with quote Add User to Ignore List
thank you for your interest.
i am currently working on it on the breadboard. i am posting about my progress over at the e-m-forum (it is the place i call my home). as soon as there is a result/PCB/module/project/whatever i will surely post it here.
cheers,
matthias
www.fonitronik.de
fonitronik at
consumed
PostPosted: Fri Mar 06, 2009 7:12 pm    Post subject: Reply with quote Add User to Ignore List
i definitely like this behavior even though my clock divider works like this:
i dont see a 'right' way in either design. it would be fantastic to have both behaviors in a system.
ignatzthemouse
Last Visit: 23 Apr 2013
PostPosted: Wed May 27, 2009 5:10 am    Post subject: Reply with quote Add User to Ignore List
oooh ive just been thinking about how to do this. Will find this post and the diagrams useful.
The panel looks pretty btw.
Cheers fonik.
wetterberg
Last Visit: 16 Mar 2013
PostPosted: Wed May 27, 2009 8:31 am    Post subject: Reply with quote Add User to Ignore List
just re-read this thread - I like the debate about reset to nothing or step 1, actually. From my perspective I'd actually prefer the reversed behaviour - that resetting "primes the counter", but that it's the CLOCK that determines when we get the first count.
Fonik, I'm quite interested in this circuit, and I figure I'd breadboard this as soon as possible, with the two remaining /64 and /128 divisions too - might as well wink
Quick questions:
1) could you explain to me the circuitry surrounding the Reset In? Is it debouncing for the button? From the way I've understood it the 4024 is heavily buffered internally already?
2)Are there simpler methods of outputting, without going through transistors?
cheers. help
View user's profile Send private message AIM Address MSN Messenger
fonik
PostPosted: Wed May 27, 2009 11:15 am    Post subject: Reply with quote Add User to Ignore List
the two transistors form a simplified descrete schmitt trigger. they will help to condition the reset signal.
for the clock input i use one transistor only, since the 4024s input clocks at the falling edge, not of the rising edge as the 4017 does.
you could leave them off, but i would not. they are voltage buffers so you can drive as many modules from the output as you might like to.
the CMOS provide limited current on their ouputs. so if you drive multiple modules from one output the voltage might decrease, thus not trigger the subsequent modules anymore.
there is a divider from a manufacturer (i can't remember right now) that suffers exactly from this problem.
cheers,
matthias
www.fonitronik.de
fonitronik at
wetterberg
PostPosted: Wed May 27, 2009 12:18 pm    Post subject: Reply with quote Add User to Ignore List
thanks for the help, man! I really appreciate it! Having a bit of a lightbulb-diy moment here, and loving it!
Brilliant, cheers! So the circuit around Clock in is a simple logic inverter, and I could use a regular schmitt trigger instead?
Another lightbulb; since "opening" the transistors with the IC means that current can flow from the +v rail, correct?
Now all I need to do is understand the concept of resistors "pulling down to ground", and I'm off smile
we're not worthy
fonik
PostPosted: Wed May 27, 2009 1:54 pm    Post subject: Reply with quote Add User to Ignore List
try it. breadboards are our best friends. you don't have to understand all and everything, but you can try an be happy if it works. seriously.
yep. you could us an opamp too.
which resistors you are referring to?
cheers,
matthias
www.fonitronik.de
fonitronik at
wetterberg
PostPosted: Wed May 27, 2009 2:01 pm    Post subject: Reply with quote Add User to Ignore List
oh yes definitely! I'm just waiting on parts from "rapid" (slow motherfuckers very frustrating ) and then I'm all over it - I bought a nice assortment of components from there for just this purpose - but for now it's "imaginary breadboarding for me" wink (btw, does anyone know what that breadboarding app is called? Does circuit diagrams as well?)
ehrm... I'm not too good at all this stuff, but isn't r5 a pull-down resistor? And what about the 2.2k? not too sure about those?
Andreas - I can't stop looking at these red and black pcbs, they're gorgeous! And they feel really classy to the touch love
fonik
PostPosted: Wed May 27, 2009 2:46 pm    Post subject: Reply with quote Add User to Ignore List
software you mean? i think we are talking about spice modelling here. i am using a very simple software called electronic workbench (no longer available). i know tim stichcomb pointed to a very good freeware, but i can't remember.
R5? i dunno how it is called, however it forms a pulse conditioner in conjunction with the cap, i think (it is a leftover from ken stones circuitry). the diode keeps only the positive going signals.
the 2.2k at the LEDs are needed to drive the LEDs with current.
the 2.2k at the outputs form a voltage divider in conjunction with the 1k resistors to bring down the 15V gates to a reasonable value.
IIRC (and the real cracks should chime in here if i am wrong) pulldown resistors are used to pull an input down to GND if it is low. if you have i.e. more than one clock signal input on a CMOS (say the 4017 in a fonitronik seqswitch) you need to pull down the ICs inputs to make them stable.
cheers,
matthias
www.fonitronik.de
fonitronik at
wetterberg
PostPosted: Wed May 27, 2009 2:56 pm    Post subject: Reply with quote Add User to Ignore List
hehe, I'm not as advanced yet - no I'm talking about a piece of software that represents a virtual breadboard, where you can place virtual components and form a circuit *layout*.
ignatzthemouse
PostPosted: Wed Jun 03, 2009 6:23 am    Post subject: Reply with quote Add User to Ignore List
My limited experience means I'd prefer to just build from your schematic fonik but I have a load of hcf4040be ics knocking about so I'm using one of those to build a clock divider instead.
I hadn't intended to use transistors on the outputs and wasn't sure about doing so for the inputs. It seems to cope with clock from the A190 but isn't 100% reliable so I should experiment a little with that.
I mainly intended to use it to drive a 4017 based sequencer so I suppose I could use a very stripped down version.
I'll end up just building a prototype and seeing how it behaves but if anyone has suggestions of any kind id like to hear them.
fonik
PostPosted: Wed Jun 03, 2009 8:00 am    Post subject: Reply with quote Add User to Ignore List
i would say go with the transistors on the input stage. would be some protection for CMOS as well.
the 4040 delivers 6.8mA on the output (+15V operation). way enough to drive LEDs and the 4017:
say you run the 4040 from +15V. following ohm's law that would give you about 14.95V on a high output. with a 6.8k resistor in series to drive a LED you would suck 2.2mA (3.2mA for 4.7K).
the 4040 has 12(!) stages: /1, /2, /4, /8, /16 ... /1024 - wow. that's for real slow motion, i think.
cheers,
matthias
www.fonitronik.de
fonitronik at
ignatzthemouse
PostPosted: Wed Jun 03, 2009 8:32 am    Post subject: Reply with quote Add User to Ignore List
Interesting. I'm going to run it in a box off a 9v battery for now. I've never used anything other than batteries to power diy stuff. Just picked up a Ken Stone synthacon filter pcb which will be my first foray into the mains.
I was thinking of making one of the outputs switch able since the 4040 divides so insanely far.
I'm sure you make a good point about an input transistor protecting the ic. I've already fried one in the last week.
The pics in another thread of your diy racks are great btw and have inspired me to replace my piss poor soldering iron with something better.
talkboxert
PostPosted: Sat Oct 01, 2011 10:55 am    Post subject: Reply with quote Add User to Ignore List
Good to have it with the converters, i keep inverting my pulse before it goes to my doepfer divider to keep evrything on beat...
knob_alchemist
PostPosted: Mon Mar 05, 2012 2:41 pm    Post subject: Reply with quote Add User to Ignore List
Interesting...I'm just in search of a simple DIY Clock divider...
ersatzplanet
Synthwerks Design
PostPosted: Mon Mar 05, 2012 3:02 pm    Post subject: Reply with quote Add User to Ignore List
Looking at the schematic it seems pretty easy to put a header (3 pins for each inverter) that would allow bypassing the inverters so the user could choose "high on one" action or not. Even be able to choose different settings for each divisions output. Then they could make an expansion board with switches to allow front panel selection. Only if you haven't laid out the board yet. People who wanted to make it without the expense of the headers could just bridge the connections with bus wire.
-James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
james@synthwerks.com
synthwerks@me.com
"It takes about a week to learn how to play a synthesizer, but several years to learn how *not* to play it." - Brian Eno
fonik
PostPosted: Mon Mar 05, 2012 3:30 pm    Post subject: Reply with quote Add User to Ignore List
everything is possible, of course! alas, then it is not that simple anymore hihi
james, i have a SMT layout in the drawer, already. the only switch is a switch to select the division of the 5th output socket, though.
maybe i should/could do a TH DIY layout with all bells and whistles?
cheers,
matthias
www.fonitronik.de
fonitronik at
ersatzplanet
Synthwerks Design
PostPosted: Mon Mar 05, 2012 3:39 pm    Post subject: Reply with quote Add User to Ignore List
I'm sure you could sell both. The DIY crowd is getting bigger and bigger each day and as far as production cost go it is just your time bagging parts and that is if you even want to offer a parts kit. I say offer Bare board, Bare board with parts, Bare board with parts and front panel. Sell to all crowds. Some may buy the TH version just because of the added features.
-James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
synthwerks@me.com
emdot_ambient
PostPosted: Mon Mar 05, 2012 4:25 pm    Post subject: Reply with quote Add User to Ignore List
Some say that less is more...but I say added features is more. Mr. Green
I always want more.
"That's not a guitar, that's some kind of musical instrument!" ~ my wife
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
