MIDI Beat Clock (Arduino-powered)
Goto page 1, 2  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules
Author MIDI Beat Clock (Arduino-powered)
solarmodulars
Last Visit: 24 Aug 2012
PostPosted: Thu Apr 14, 2011 12:43 pm    Post subject: MIDI Beat Clock (Arduino-powered) Reply with quote Add User to Ignore List
MIDI Beat Clock
by Tom Whitwell
"Midi / pulse clock divider, with swing, running on arduino"
cool Nice DIY.
Tombola
Last Visit: 21 May 2013
PostPosted: Thu Apr 14, 2011 1:00 pm    Post subject: Reply with quote Add User to Ignore List
Thank you!
Here is a post in the DIY forum with some details about the schematic/code.
wetterberg
Last Visit: 16 Mar 2013
PostPosted: Thu Apr 14, 2011 2:21 pm    Post subject: Reply with quote Add User to Ignore List
Tombola wrote:
Will do a post in the DIY forum with some details about the schematic/code.
yes please smile
View user's profile Send private message AIM Address MSN Messenger
matttech
PostPosted: Thu Apr 14, 2011 2:22 pm    Post subject: Reply with quote Add User to Ignore List
Tombola wrote:
Thank you! There is now a qmmg in the next space along, which makes for a better class of demo.
hey mate - PM me about the filter (not sure what's up with my messages, but some don't seem to have been sent, and yours came up blank)
WTB: Focusrite Octopre/ Saffire PRO40, Rubicon/Dixie, modcan dual delay
EXPERIMENTAL MODULAR SYNTH MUSIC:
http://soundcloud.com/spitezoo-experimental-lab
MODULAR DEMOS:
https://soundcloud.com/matttech-offcuts
NON-MODULAR MUSIC (mainly):
http://soundcloud.com/blue-light-fever
http://www.last.fm/music/Blue+Light+Fever
OLD COMMERCIAL RELEASE: http://www.saltrecords.com/recordings/discography/?id=2&cid=11
reignbear
PostPosted: Thu Apr 14, 2011 4:04 pm    Post subject: Reply with quote Add User to Ignore List
well this pretty much rules. SlayerBadger!
just out of curiosity what is the depth of the build?
wetterberg
PostPosted: Thu Apr 14, 2011 4:08 pm    Post subject: Reply with quote Add User to Ignore List
low pin count... arduino... You can probably run this on a tiny breadboard and this:
Note; 0.7"*1.3" SlayerBadger!
reignbear
PostPosted: Thu Apr 14, 2011 4:18 pm    Post subject: Reply with quote Add User to Ignore List
@wetterberg Guinness ftw!
matttech
PostPosted: Thu Apr 14, 2011 4:25 pm    Post subject: Reply with quote Add User to Ignore List
hi tombola - you messaged me about a doepfer filter but for some reason your latest message came through blank, and ones i've sent you just go to my outbox, but don't appear to have been sent
you can get me on pencilpreston@hotmail.com if you want
cheers
MODULAR DEMOS:
sandyb
reap what you sow
PostPosted: Thu Apr 14, 2011 4:54 pm    Post subject: Reply with quote Add User to Ignore List
cheers
how the PM system works here:
http://www.muffwiggler.com/forum/viewtopic.php?t=29818
hth
sandy
it does matter
Tombola
PostPosted: Thu Apr 14, 2011 6:01 pm    Post subject: Reply with quote Add User to Ignore List
It's not especially deep - about two inches?
You don't need to use an actual arduino board, or even the Mini that Wetterberg linked to, just the 28 pin Atmel chip with a (very) few supporting components
DIY module by Tom.Whitwell, on Flickr
jimmyambulance
Last Visit: 20 May 2013
PostPosted: Fri Apr 15, 2011 11:46 am    Post subject: Reply with quote Add User to Ignore List
want to share your code at all?
i've been wanting to make an arduino module and i have 2 unused minis around. i'm not the best at electronics and my concern is the details - did you use protection on your jacks? what kind of signal can it accept/put out? i'm assuming you can use the doepfer-style connector to the 5v?
sorry for all the questions...
NEW ENGLAND:
WTB: uFold II
Sound Electronics
Dinners - soundcloud
wetterberg
PostPosted: Fri Apr 15, 2011 2:06 pm    Post subject: Reply with quote Add User to Ignore List
yes, I'm more interested in how the i/o is handled smile I don't need midi at all.
nickciontea
brownshoesonly
PostPosted: Fri Apr 15, 2011 2:23 pm    Post subject: Reply with quote Add User to Ignore List
outputs are straight off the digital outs.. High and low.. real simple.
the digital outs are great for clocking, logic, and gates.
for a simple clock and divider w/0 midi.. i would use an interrupt based program. this way you can reset and even do tap tempo.
i wanna try to make an arduino module with some jacks, knob, and one switch that designates what 'program/module" to run.
Tombola wrote:
Thank you!
http://brownshoesonly.com |
Tombola
PostPosted: Fri Apr 15, 2011 6:48 pm    Post subject: Reply with quote Add User to Ignore List
If you PM me I'll send the code - it's pretty scrappy, not in a state I'd want to 'publish'
Didn't use any protection. The outs are straight from the digital pins. The point is it's literally an Atmel 328 with a few supporting analog components = cheap in everything but your time.
I've fired probably +/- 6v into the inputs with no trouble. You *should* protect the inputs with diodes etc.
Doepfer connector has 5v. I used the Synovatron proto kit, and cut a trace to get 5v distributed around the board.
Tombola
PostPosted: Fri Apr 15, 2011 6:58 pm    Post subject: Reply with quote Add User to Ignore List
Digital in = simple - easy to read pulses and act on them
Analog in = simple, you have 1024 levels of precision in theory, but I wouldn't expect anything like that in practice, but knobs and simple voltage control should be OK
Digital out = really simple. You should buffer/boost the pulses, but not totally necessary
Analog out = tricky with any precision. Quantizers and midi/cv modules are usually built around micro controllers like the Atmel, but coded properly, and using proper d-to-a converters.
MIDI is actually simple because it's just serial data, which Arduino can read. The circuit on the board is just protection (for your synth/keyboard/MPC) and inversion.
Parametex
Last Visit: 16 May 2013
PostPosted: Sat Apr 16, 2011 3:26 am    Post subject: Reply with quote Add User to Ignore List
This is very cool!
A ong while I have been wondering why why there has not been a din sync modules produced!
Well done!
synthomaniac
PostPosted: Sat Apr 16, 2011 9:05 am    Post subject: Reply with quote Add User to Ignore List
That's great feedback - I'll consider adding improved 5V support on-board when I design the Rev2 version of the Synovatron DIY kits later this year; perhaps by just having a few user-configurable busses.
Monobass
thonk.co.uk
PostPosted: Tue May 03, 2011 3:29 pm    Post subject: Reply with quote Add User to Ignore List
hey synthomaniac... ever considered doing some uk module building workshops? I can build kits fine, but anything more is a bit daunting.
Thonk - Modular Synth DIY
258J Euro kit - Manhattan Analog Kits- 4ms Kits - Clarke68 Panels - Expert Sleepers Glow Cables - Banana Jacks
Tombola
PostPosted: Wed May 04, 2011 1:57 am    Post subject: Reply with quote Add User to Ignore List
Would be a great idea. I got started in this after going to a Tom Bugs workshop in London.
http://musicthing.co.uk/modular/
Low-Gain
PostPosted: Wed May 04, 2011 6:43 am    Post subject: Reply with quote Add User to Ignore List
well so much for that module. lol.
I had one in the works almost just like this one. more division outputs though + a few other features..
lol.
Looks great!
-]|- Low-Gain Electronics -|[-
twitter.facebook.bandcamp.flickr.vimeo.youtube.BugBrand!
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules All times are GMT - 5 Hours
