| View previous topic :: View next topic |
| Author |
4hp Spring Reverb driver module - schematic, pics, sounds |
Tombola Ultra Wiggler
  Posts: 934 Location: London, England
Posted: Mon May 30, 2011 2:07 pm Post subject: 4hp Spring Reverb driver module - schematic, pics, sounds |
I was just about to buy an A199 spring reverb when I decided to save 4hp of space and build my own.
The circuit is based on Roy Mallory's tech note and tone control, which is useful - a symmetrical cut/boost of bass and treble. The drive, recovery, tone and blend buffer take the four amps in a TL074.
The gain on the drive circuit is reduced quite a bit - R10 is 660R rather than 62R (it's R1 in Mallory's article), and the recovery circuit has a variable drive.
I put a couple of phono jacks on the back of my Doepfer case, so it's easy to plug in an external tank - a nice rich 6-spring 9EB2C1B (mainly because I built the circuit with the 8EB2C1B from a fender amp)
[s]http://soundcloud.com/musicthing/diy-spring-reverb-module[/s]
UPDATE: See revised schematic
| Back to top |
limpmeat Veteran Wiggler
  Posts: 611 Location: Melbourne
Posted: Mon May 30, 2011 6:51 pm Post subject: |
| looks great, love the front panel |
| Back to top |
Neutron7 Oldschool bleeper
Posted: Mon May 30, 2011 10:01 pm Post subject: |
| that tank sounds really nice. great job! |
| Back to top |
mikecameron Thread Killer
  Posts: 579 Location: Peoria, IL
Posted: Mon May 30, 2011 11:17 pm Post subject: |
I have been thinking of doing this very thing! Thanks for sharing your work, I'll be building it soon.  |
| Back to top |
jimmyambulance Ultra Wiggler
  Posts: 865 Location: Jamaica Plain, MA
| Back to top |
Dego Veteran Wiggler
    Posts: 663 Location: Sweden
Posted: Tue May 31, 2011 8:51 am Post subject: |
Very nice  |
| Back to top |
BugBrand Knowledge of Bugs
| Back to top |
mig27 Wiggling with Experience
  Posts: 265 Location: Berlin
Posted: Tue May 31, 2011 9:55 am Post subject: |
Nice one!
And I also dig the plexi front plate.
Looks a bit like my OSC303.
Care to share how you built these?
I'm currently looking cheaper front plate alternatives than the usual Schaeffer job
Michael |
| Back to top |
| Back to top |
Posted: Tue May 31, 2011 10:37 am Post subject: |
Thanks, appreciated.
Must look into this closer--
M |
| Back to top |
KNYST hiding in the forest
    Posts: 2321 Location: the Taiga, Sweden
| Back to top |
Jarno Ultra Wiggler
  Posts: 795 Location: Rosmalen, NL
Posted: Tue May 31, 2011 3:54 pm Post subject: |
Thought you needed something with a bit more oomph to drive a reverb tank. Nice n small this, superb!
| Back to top |
fluxmonkey Super Deluxe Wiggler
Posted: Tue May 31, 2011 9:12 pm Post subject: |
nice to hear a demo comparison between the 2 springs. _________________ www.fluxmonkey.com
please email (rather than PM) with any direct correspondence |
| Back to top |
boothnavy Super Deluxe Wiggler
   Posts: 1010 Location: Boston
Posted: Tue May 31, 2011 10:49 pm Post subject: |
If you made R10 in your circuit variable with a pot, could you then control the input amount?
Also, would any modification be necessary if using 15v? _________________ boothnavy - synthesist
www.analogcraftsman.com |
| Back to top |
Posted: Wed Jun 01, 2011 2:28 am Post subject: |
Boothnavy: I did try that on the breadboard with a 1k pot, because I assumed I'd build it with variable drive and fixed recovery. It didn't work well for me - very limited useful range, quick to distort in a nasty way, but then I didn't test it with a huge range of input signals.
Re: 15v - sorry, I have no idea - I guess the TL074 datasheet would give you the max voltage. The other values don't seem that critical so you'll probably be fine. _________________ http://musicthing.co.uk/modular/ |
| Back to top |
Posted: Wed Jun 01, 2011 2:35 am Post subject: |
R9 is another interesting one - it's a kind of damping/stabilising on the recovery circuit - worth experimenting with - or removing - on breadboard _________________ http://musicthing.co.uk/modular/ |
| Back to top |
| Back to top |
Glitch Militia Learning to Wiggle
Posted: Wed Jun 01, 2011 10:21 am Post subject: |
What input / output impedance is this designed for ? I do not know that tank that you got.
I currently got this one on breadboard, tweaking some values etc. I like the sound of yours, so I'll try that next.
| Back to top |
Posted: Wed Jun 01, 2011 10:25 am Post subject: |
Both my tanks are 800 Ohm / 58 Ohm (input impedance / DC). 2575 Ohm / 200 Ohm (output impedance / DC). _________________ http://musicthing.co.uk/modular/ |
| Back to top |
Posted: Sat Jun 11, 2011 7:07 am Post subject: |
This shows off the sound of the big six spring tank quite well. (
Disappointingly, the six springs are actually mounted as three springs with joints between the separate springs... )
[s]http://soundcloud.com/musicthing/maths-qmmg-anti-oscillator-diy[/s] |
| Back to top |
