Parts discontinued at Rapid
Author Parts discontinued at Rapid
wmonk
Hi,
I just noticed some of the Cermet 6mm trimmers are discontinued at Rapid very frustrating I didn't see these specific parts anywhere else.
Codes:
67-0432 500R 5mm cermet
67-0434 1K 6mm cermet
67-0440 10k 6mm cermet
67-0444 50K 6mm cermet
67-0446 100K 6mm cermet
Same for 1N4148 47-3308, new part number is 47-5608.
Any idea on replacement with the same 6mm spacing?
BugBrand
6mm - that's 1/4" I think, right?
These are fine:
http://www.rapidonline.com/Electronic-Components/Resistors-Potentiomet er/Preset-Potentiometers/-frac14-in-Multiturn-cermet-potentiometers-Tr uOhm/71493
There's a few different 1/4" ones.. Just pop up one level from the link above.
For the 1N4148s just use their Tru-Semi ones:
http://www.rapidonline.com/Electronic-Components/Discrete-Semiconducto rs/Signal-Diodes/1N4148-Signal-diode/74690
Tru**** is the Rapid own brand. They always source good quality stuff - I've never had any problems at all.
Edit -- actually, here are 6mm cermets:
http://www.rapidonline.com/Electronic-Components/Resistors-Potentiomet er/Preset-Potentiometers/6mm-Cermet-trimmer-potentiometers/65259
Synthbuilder
Looks like Rapid are moving their suppliers around. It's hard to keep up.
I also use the Bourns 3386F type which is normally available in the usual values I use:
http://www.rapidonline.com/Electronic-Components/Resistors-Potentiomet er/Preset-Potentiometers/3-8in-single-turn-cermet-potentiometers-Bourn s/65267
Tony
