Sound of Shadows Min/Max Delay time?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
raulsworldofsynths
I'd patch that!
Post by raulsworldofsynths » Sun Sep 04, 2011 9:40 am
I read through the manual but couldn't find this item of info.
Can anyone shed light on this?
Pardon the ignorance of my next question since I only understand a little about delays.
I've read that in BBD delays the more stages the longer the delay time.
I know the SOS is a Digital Delay but if it had to be in those terms how many stages would the SOS be?
For instance in comparison to the Pittsburg Analog Delay which has a 4096 stage.
Hope this made some sense. Thanks.
conscious
Post by conscious » Mon Oct 03, 2011 10:11 am
The Website says:
Delay Length
Min: ~31.3ms
Max: ~342ms
seems kinda short, but i never meassured only used delays.
opsysbug
Post by opsysbug » Mon Oct 03, 2011 11:19 am
I think if you are concerned at all with Delay times then SOS is not for you.
This cruncher fucker is a "delay" in name only. A really poor excuse for a delay
in fact. Terrible and ugly and stupid. Like a Delay pedal's mentally ill cousin
who has been locked in the room upstairs. And I bought my 2nd one
day after the 1st arrived!! :lol: :hihi:
suboptimal
A Towering Mediocrity
Post by suboptimal » Mon Oct 03, 2011 2:13 pm
Heheh too true. This is a "delay" in the same sense as the Plague Bearer is a "filter."
Soy Sos
Dub Surgeon
Post by Soy Sos » Mon Oct 03, 2011 2:31 pm
The SoS goes pretty slow, maybe lower than 1 second.
But at that rate it's really grindy, I like it though.
lilakmonoke
Post by lilakmonoke » Thu Jun 14, 2012 10:52 am
i was puzzles by this too but i think ive got it now. that chip has only 44k memory. i have no idea at what bitrate it works it but should be at least 12 or even 16 from what it sounds like. i think its only meant to be used at 342 msec max which seems to be reasonable for a karaoke machine. at 342 msec there is very little thd (noise), if you go faster the sound quality becomes even better. you can go slower on the SOS but the noise will increase rapidly because it lowers the sample rate to generate more time with the same sample memory ... which is kind of abusing the chip. right or wrong?
DGTom
Post by DGTom » Thu Jun 14, 2012 11:01 am
Fairly sure the PT2399 uses 1bit conversion, with a really high sampling rate. The list in the datasheet that has clock rate & delay time says the clock is running between 2 & 18mHz (for normal operation)
The slower the clock rate, the greater the delay, the more the output resembles a squarewave.
lilakmonoke
Post by lilakmonoke » Thu Jun 14, 2012 11:52 am
that makes sense ... 1bit conversion means only one bit (on/off) but that really fast? question is how many decent mseconds would you then get out of 44 k memory?
DGTom
Post by DGTom » Thu Jun 14, 2012 10:54 pm
lilakmonoke wrote:only one bit (on/off) but that really fast?
pretty much, it involves a couple of integrators & feedback from the data storage to the input stage, its a pretty nice way to do ADC with few parts & can sound pretty good.
"decent ms" ? I dunno, whatever works for you. As you say, PT only expected it to be used for a little over 300, it all depends on how much THD you can live with :D
Return to “Flight of Harmony”
