ES-4 with macbook pro
MUFF WIGGLER Forum Index -> Expert Sleepers Goto page Previous  1, 2, 3, 4  Next [all]
Author ES-4 with macbook pro
fate
I ordered last night, just curious but is a s/pdif cable supplied?
An S/PDIF cable is not included.
ultrashock
just a small clarification.
From your site I've read that ES-4 works on 192kHz frequency. So, the project in my DAW (logic, live or so) should be also in 192kHz?
Is there any chance to set up ES-4 working without one more audio interface? (keeping in mind that macbooks have stereopair of digital and stereopair of analogue outputs (only restriction that they are combined in a small 3.5" jack hole..) - If it is possible to do it for at least output the cv only (while not recording the audio stuff from the synths)
and one more question to all - have you checked that macbooks (pros and ordinary ones) support up to true 192kHz optical digital i\o? I had only up to 96kHz in audio/midi setup of my built-in audio (macbok 2008 - I know, time to upgrade but it works like new)
upd: just found:
While the ES-4 is specified to run at 192kHz, at the time of writing this has not been tested. Operation up to 96kHz however has been tested and verified.
so, everything should be okay!
The ES-4 may work at 192kHz. I've not been able to verify that yet.
The ES-4 would adopt whatever rate your audio outputs are set to, which would typically be the same as what the DAW is using (usually the DAW controls the hardware).
Yes, you can use the ES-4 with the Mac's built-in output. See
https://www.muffwiggler.com/forum/viewtopic.php?t=42449
I'd be very surprised if the Mac's built-in output supports 192kHz. My MacBook Pro's output only goes up to 96kHz.
ultrashock
o, yeah, now everything is clear!
ES-4 is a genious device!!!
p.s.: I just found that it's better to buy direct M-M: Toslink-to-Mini Toslink Cable
http://www.amazon.com/6ft-Toslink-Mini-Cable/dp/B000FMXKC8
instead of this one (M-F):
http://www.amazon.co.uk/gp/product/B00016W67I/ref=oss_product
for use with optical to coaxial converter, right?
Yes, probably a more reliable connection without the adaptor.
chrisso
Loving this thread. Clearing up quite a few ES4 confusions for me.
My only question is about the older (2007) Intel iMac, combined audio and digital mini-jack output.
Can I use it (as aggregate device with Lynx Aurora Firewire), and do I use the same adapter cables discussed here, or a different one?
As far as I know the combined digital/analogue minijacks have always been the same.
If in doubt, plug a TOSlink cable into it (with a min-TOSlink adaptor) and route audio to the built-in output. If you see light coming out of the cable, you're in business.
chrisso
Confirming I have this correct then....
To use imac I need mini-toslink to toslink cable (linked earlier), Digital Optical TOSlink to SPDIF Coaxial Audio Converter (linked earlier) and spdif cable to link coaxial converter to ES4?
Not sure what you mean by "spdif cable to link coaxial converter". From the TOSlink-to-SPDIF converter you just connect to the ES-4 via a coaxial SPDIF cable.
chrisso
Maybe I'm confused then.
This.....
os wrote:
You will also most likely need a TOSlink adaptor and an optical to coaxial converter, both of which are dirt cheap.
So iMac > mini toslink to toslink cable > optical to coaxial converter > spdif cable > ES4.
That right?
Yes. Basically as in this video, but from the iMac rather than the Turtle Beach thing:
radiodread87
I am trying to get this to work with ableton on my macbook pro but not having much luck.
It will work at home on when running from an audio interface but I had wanted to use the built in macbook output so I could use my system live.
I connected the Mini toslink to toslink cable > to Toslink to Coaxial convertor > that is going via an RCA style cable to the ES4.
The red light on the ES4 wont light up.
Currently I have just the silent way stuff outputting, when the Toslink cable isnt connected to the mac there is a "popping" coming from the speakers in time with the silent way voice controller.
Is it a question of Routing? and if so how would one typically route the Audio from the Silent way LFO track or Voice controller track to the output of the ES4?
many thanks
If the only audio output you have active is the Mac's built-in output, there's no routing to be done, really.
Have you selected the Mac's built-in output as the output device in Live? As soon as you do that, the ES-4's sync light should light. If it doesn't, nothing will work, and in which case I would suspect the cables/adaptors.
If you leave the toslink cable plugged in to the Mac, but unplug the other end, you should see the red laser light shining out of it.
radiodread87
Hey OS
Yeah I actually just figured it all out, the adaptor box I got was not working. I will return it and get another one tomorrow. sorry for the drama.
xandersingh
Hey guys! will be picking up an ES-4 soon and using it through my macbook pro's headphone jack as an aggregate device alongside my Apogee Duet 2. Was wondering if the items in these links are what I need to get the job done. Also if there are better brands than these let me know. also on the other hand, if anyone knows of anything like a USB-S/PDIF interface for cheap let me know, thanks!
http://www.amazon.com/Digital-Optical-Toslink-Coaxial-Converter/dp/B00 0I98ZQY
http://www.sweetwater.com/store/detail/DRA501/
Those look fine.
Cheap USB-S/PDIF:
http://www.turtlebeach.com/products/sound-cards/audio-advantage-micro- ii.aspx
xandersingh
cool, im assuming the turtle beach thing just replaces the headphone jack and i still need everything else?
xandersingh
also would this work?
http://www.amazon.com/Musical-Fidelity-MFVLINK-V-Link/dp/B004PH03GU
this than, a spdif cable straight to the ES-4?
Yes. Be aware though that it's USB 1.1 class compliant, which means 16 bit audio, which means you lose channel 5 of the ES-4.
Yes, probably. I'm always suspicious of audiophile gear like this though. Read the reviews - talking about the sound improving with a more expensive USB cable! If you get one I'd be interested to hear how it works out.
Found this too:
http://www.audioaffair.co.uk/M2-Tech-Hi-Face-USB-to-S/PDIF-Converter/p roduct_5350
xandersingh
ill likey get something like those. (I'm a stickler for cable clutter). Ill let you know how it works!
xandersingh
http://www.ebay.com/itm/USB-S-PDIF-Digital-audio-signal-converter-Hifi -/230639224710?pt=LH_DefaultDomain_0&hash=item35b32b4786#ht_6854wt_139 8
this also seems cheap enough to take a chance on :-)
Yes, worth a try! It will be USB 1.1 again though.
The Asterism
Can someone clarify something for me please:
- with the ES-4, there are the two pre-calibrated pitch CV outputs,
but can any of the other five be calibrated using Silent Way software so that they can also control pitch to create a polyphonic setup?
Page 2 of 4
