Front Panel Proof Reading Thread
Goto page Previous  1, 2, 3 ... 6, 7, 8, 9, 10, 11  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author Front Panel Proof Reading Thread
emdot_ambient
Last Visit: 22 May 2013
PostPosted: Sat Feb 11, 2012 10:05 pm    Post subject: Reply with quote Add User to Ignore List
fluxmonkey wrote:
...if you want to use a nutdriver...you need to allow clearance for the tool as well...
Whoa...good point! Now I've got to go back and take a look at some panels I've designed but haven't ordered. I've crammed my jacks in pretty dang close.
Thanks for the tip!
"None of your five bar gate jumps and over sort of stuff."
jarvis
concerned with insignificances
Last Visit: 20 May 2013
PostPosted: Mon Feb 13, 2012 9:25 pm    Post subject: Reply with quote Add User to Ignore List
At .5" center-to-center horizonal spacing there's just enough room to get the nuts on to the emerson/johnson banana jacks without them interfering with their neighbors, however it is probably too close to use a nut driver. I'm just going to tighten with a pair of pliers... it'll be a monotonous job but it's better than redesigning my panels for the bazillionth time!
dmitri
PostPosted: Thu Mar 08, 2012 11:56 am    Post subject: euro cgs panels for vintage beauty travel case Reply with quote Add User to Ignore List
wrong thread.
panels not even close to ready.
removed.
http://www.coa-modular.com
http://www.youtube.com/DmitriSFC
zthee wrote:
"How to place the boards behind the panel is equally important as how the panel will look. You should be able to look at the front, turn it around and it should be just as pretty. I don't think you should leave the placement of the boards for "I'll solve that when I get to that part...". It should be thought of before."
sonicwarrior
Last Visit: 21 May 2013
PostPosted: Thu Mar 08, 2012 12:14 pm    Post subject: Re: euro cgs panels for vintage beauty travel case Reply with quote Add User to Ignore List
Stiener? hihi
Soundcloud
For sale: V/Oct to Hz/V converter PCB
WTB: Dr. Octature
dmitri
PostPosted: Thu Mar 08, 2012 12:19 pm    Post subject: Reply with quote Add User to Ignore List
did i spell it wrong ?
whoopsy
Steiner-Parker
thanks
d
rockmanrock
Last Visit: 08 May 2013
PostPosted: Thu Mar 08, 2012 10:14 pm    Post subject: Reply with quote Add User to Ignore List
Admittedly this is more of a design post, but we haven't got a sticky thread for that. I'm going through various options for my overall approach to my first designs and would appreciate any wisdom. These are for an MFOS VCO and the format is "Half Rast" - 6.75" tall panels.
Above you can see three layouts. The pots are all on a 1 inch grid which seems to me is bordering on cramped, but I've got a lot to fit in and I don't want to build a massive wall.
The first one is very straightforward, but my concern is with a big grid of knobs on a row of similar modules, everything merges together. The middle one breaks up this grid tyranny a bit but with the jacks in the middle you get cables drooping down obscuring the controls. With the third style I'm thinking about using a bigger knob for a 'feature' parameter, in this case tuning. (On a filter it would be the cut-off, for an LFO the speed and so on.) The idea is to improve ergonomics and playability. To fit these last two layouts in the same 2 inch panel width I've forgone the third CV attenuator.
These are only roughs really but any comments on these panel designs would be much appreciated.
emdot_ambient
PostPosted: Fri Mar 09, 2012 1:11 am    Post subject: Reply with quote Add User to Ignore List
I prefer the 3rd one. I always lean toward putting larger knobs on controls that will be used a lot. Makes it easier to grab on the fly 'cause it's more visible.
One nitpick on all of them, though, "Pulse Width" is one word, not two. And even run together, it's too long a word for your design in the current font size. I'd recommend changing it to simply PW or something shorter so as not to crowd the edge of the panel...or reducing the fonts on all text to accommodate the text.
I think you're OK dropping the attenuator on one of the CV inputs, or even dropping one altogether. I can't think of too many cases where you will actually use 4: V/Oct from a seq or keyboard, an attenuated one for a vibrato LFO, a second attenuated one for either an LFO or EG...At least w/me there's not that many times I do much more with pitch. A VCF would be more important to have many inputs, I'd think.
bleeps
Last Visit: 18 May 2013
PostPosted: Sat Mar 10, 2012 12:29 am    Post subject: Reply with quote Add User to Ignore List
This is the "works" version of Michael Barton's CV Arpeggiator in 18hp. Here's a list of the controls for proofing:
MOVEMENT - knob (no text, icons were made): Up/Down, Up Repeating, Down Repeating, Pendulum, Up and Stay, Down and Stay, Random
OCTAVES - knob: 1, 2, 3, 4, 5
NOTE SET - 1, 2, 3, 4, 5, 6, 7, 8
3rd note - toggle switch: MAJOR, MINOR
7th note - toggle switch: MAJOR, MINOR
WIDTH - knob (no values)
TEMPO - knob (no values)
GATE/TRIGGER selector - toggle switch: GATE, TRIGGER
GATE LED - led
OUT JACKS - ARP, G/T
IN JACKS - CV, SET, 3RD, TEMPO, CLK, RESET, 7TH
This is my first panel design. I'll mock this up onto cardboard before doing a laminated paper on a panel.
emdot_ambient
PostPosted: Sat Mar 10, 2012 7:38 am    Post subject: Reply with quote Add User to Ignore List
Lovely work, bleeps! I was jealous until I realized I've got one of those PCBs in my backlog already! I haven't even looked at the docs enough to figure out what I'll need to include on my front panel...so you've just saved me a lot of work! thumbs up
e-grad
PostPosted: Sat Mar 10, 2012 7:41 am    Post subject: Reply with quote Add User to Ignore List
@dmitri
It's Serge VCF not Serg VCF.
elektrograd
bleeps
PostPosted: Sat Mar 10, 2012 10:46 am    Post subject: Reply with quote Add User to Ignore List
emdot_ambient
Thanks! It should be noted that this does deviate a bit from the panel and functionality suggested in the build doc. You may want to add some of this stuff back in:
1) I left off two pots as the panel is already crowded and I figure I could just attenuate signals prior to input.
2) I added switches to the 3rd and 7th note parameters. The switches will get defeated when a jack is plugged into the respective CV inputs.
3) CV input for PWM (Width) and the Gate Out were left off. The gate out was combined with the trigger out and is selected via the switch in the middle. I might add both of these jacks back in, but that would mean the stepped layout at the bottom will change.
I had to re-read the build doc several times to figure out what I wanted to do. There are a lot of features packed into the board.
Cheradenine
Modulate me harder
PostPosted: Tue Mar 13, 2012 6:36 am    Post subject: Reply with quote Add User to Ignore List
Here's a 4U M-class sized panel I'm about to order...but before doing so, maybe it's better if someone else could check it.
That's an ultra minimal design, no scale on the pot and the fewest possible text.
Bare anodized aluminium with black infilling for the engravings.
Holes are 8mm for bananas, 7mm for pots, 6,5mm for mini jacks (aux in on the mix, and the second input of the res-eq) and 6mm for the switch on the reverb (this one is a tight fit)
My main concern is the text : I never ordered panel with painted engravings, so I don't know how well it will render with this mix of font/size/engraving. Won't it be too small ?
1.soundcloud - vimeo
2.Entartete K.
rockmanrock
PostPosted: Tue Mar 13, 2012 10:23 am    Post subject: Reply with quote Add User to Ignore List
Thanks for the feedback. I did progress from left to right with my design so I prefer the third one too. I was trying to keep to a strict 1 atten per input rule but they do chew up available the space and limit the ergonomics. I think keeping the third CV input jack is worth it though, a banana jack doesn't take up much space and I can use a common atten for multiple oscillators.
I've not decided on a font yet, they all looked 'wrong' to me. That thread on fonts needs a closer look.
I've printed these out and they still seem a bit cramped, I don't know how the Eurorack fans manage with even closer pot spacings.
emdot_ambient
PostPosted: Sun Mar 18, 2012 9:17 am    Post subject: Reply with quote Add User to Ignore List
I'm afraid I don't know the answer to that. Some of your text is 1.5mm high, I typically use 2.5mm for my smallest text...but I've never done in-fill. In-fill significantly ups the price of a panel.
Also, you could save some money by deciding on a font size and combining a lot of your text. For example, in the CV Processor section you have the Offset pot labeled with its name "offset" and two other text objects "-5" and "+5". Those objects together cost you $0.85.
However, if you combine all those into one object (keeping the font and font size the same as the OFFSET text) that combined object only costs you $0.42.
Additionally, changing every "-" and "+" to one "- +" text object (that's the minus sign, 6 spaces, and then the plus sign) will reduce the cost from $0.47 to $0.24.
Doesn't sound like a lot but it adds up. Do the same with all the 0/1 and D/W, making sure to combine knob text with their associated indicators and I'm sure you can get the cost down below $120.
You'd also solve your "is it too small" issue because all the text would be over 2mm high, which should be fine.
fluxmonkey
PostPosted: Sun Mar 18, 2012 9:44 am    Post subject: Reply with quote Add User to Ignore List
@Cheradenine--might have been intentional, but the decimals on the Res EQ freq pots look like commas, not dots?
www.fluxmonkey.com
please email (rather than PM) with any direct correspondence
Cheradenine
Modulate me harder
PostPosted: Sun Mar 18, 2012 3:01 pm    Post subject: Reply with quote Add User to Ignore List
Thanks for having checked it, guys !
@fluxmonkey : yes it's intentional, or more like a reflex...we french are using comma for decimal mark Mr. Green
@emdot_ambient : thanks fore the advice ! I vaguely remembered that, that's why the names/creators of the modules are already grouped...
I've done it for all what you suggested, make me save 7€ It's peanut butter jelly time!
2.Entartete K.
emdot_ambient
PostPosted: Sun Mar 18, 2012 5:30 pm    Post subject: Reply with quote Add User to Ignore List
7€ is 7€! thumbs up
(As my current sig says: "The future belongs to the efficient"!)
fluxmonkey
PostPosted: Tue Mar 20, 2012 8:15 pm    Post subject: Reply with quote Add User to Ignore List
Going over this w/ my finest toothed combs, since it'll come in at almost $300... my first full Sergish panal:
Wogglebug
2X 258 VCOs
Dual LFO (CGS)
Noise Cornucopia (MFOS)
Steiner VCF (CGS)
Mix/Proc
Dual RingMod (111)
any feedback greatly appreciated!
rico loverde
PostPosted: Tue Mar 20, 2012 8:56 pm    Post subject: Reply with quote Add User to Ignore List
very nice fluxmonkey. my serge panel with buchla clones should be here soon. epinasty etched one for me. i can't wait to get it in my grubby little hands. i really like your module choices. i don't see any mistakes but I'm horrible at catching them and this thread was a huge help when i started mine.
works for Malekko Heavy Industry
View user's profile Send private message Send e-mail Yahoo Messenger
msprigings
PostPosted: Tue Mar 20, 2012 9:28 pm    Post subject: Reply with quote Add User to Ignore List
rico out of curiousity what is in your buchla serge style panel?
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 7 of 11
