| View previous topic :: View next topic |
| Author |
Front Panel Proof Reading Thread |
fluxmonkey Super Deluxe Wiggler
Posted: Thu Sep 22, 2011 3:35 pm Post subject: |
uh... thanks, but no credit to me for either of those circuits. 208 was derived from buchla, via schematic by scott stites and pcb layout by VTL5C3. bandpass was buchla via schematic capture & correction by marjan urekar. i just made the boards. psyched to see 'em alive in the wild, though! _________________ www.fluxmonkey.com
please email (rather than PM) with any direct correspondence |
| Back to top |
rico loverde Super Deluxe Wiggler
  Posts: 3516 Location: Portland, Oregon
Posted: Thu Sep 22, 2011 3:56 pm Post subject: |
| fluxmonkey wrote: | | uh... thanks, but no credit to me for either of those circuits. 208 was derived from buchla, via schematic by scott stites and pcb layout by VTL5C3. bandpass was buchla via schematic capture & correction by marjan urekar. i just made the boards. psyched to see 'em alive in the wild, though! | cool, yea i was given credit to the people that rereleased them, doesn't make much sense so i changed them to the creator of each...
with that in mind should i take jerks name of the oscillator? _________________ works for Malekko Heavy Industry |
| Back to top |
negativspace Manhattan Analog
   Posts: 3749 Location: Manhattan, KS
Posted: Thu Sep 22, 2011 4:25 pm Post subject: |
That territory gets kinda murky, IMO. Crediting the original circuit's designer is valid. But then again it's probably been changed a bit since the original, so do you credit the last person to make any changes? How big a change qualifies? Does credit for J3RK's 285 board belong to J3RK? Mark Verbos? Buchla?
These are valid questions. I think any answer is correct, and I think that the most technically-correct way is to credit the maker of the PCB itself. I often credit the original designer on my own panels. I say do what suits you best. (While respecting fluxmonkey's specific request, of course.) _________________ Analogue Haven ∙ CTRL ∙ EquinoxOZ ∙ EFN ∙ Foxtone Music ∙ PostModular ∙ Schneidersbüro |
| Back to top |
emdot_ambient Super Deluxe Wiggler
   Posts: 2386 Location: Frederick, Maryland USA
Posted: Thu Sep 22, 2011 5:07 pm Post subject: |
| negativspace wrote: | | Does credit for J3RK's 285 board belong to J3RK? Mark Verbos? Buchla? |
The answer to that is..."YES"
My current design for a dual 258 from the J3RK PCBs labels it a "DUAL J3RK 258 VCO", but I think of it more as not a statement of credit, but rather of provenance. The "258 VCO" points to the Buchla origin, and the "J3RK" points to the circuit's provenance. Unfortunately...kind of hard to fit both of those plus "Verbos" on the panels. Not sure it really matters, though. If I ever get rid of that module, whoever gets it will know where the PCB came from and then be able to see it's based on Verbos's.  _________________ "None of your five bar gate jumps and over sort of stuff." |
| Back to top |
sduck WTF?
    Posts: 4460 Location: Vortepexaion, TN, USA
Posted: Thu Sep 22, 2011 10:15 pm Post subject: |
My vote for the 258 label is
But it's your panel, do what you want. _________________ What they do is this: They leak current in proportion to the frequency of the signal. The ramifications of this can only be truly appreciated when solving nodal current balances in the Laplace domain, unfortunately.
flickr cloud of sound touyube |
| Back to top |
giorgio NITE MIND
   Posts: 2411 Location: BRAND NEW YORK
Posted: Thu Sep 22, 2011 10:38 pm Post subject: |
Rico I am loving that panel. I hope mine can look like that at some point. still not sure what's gonna go in it yet... might make 2 or the same, each with a single 258 vco, single teezer, dual 281, single serge VCS & dual LPG and then the other/zany stuff on a 3rd panel..
did you make this from scratch? _________________ ▲✌♡✂☃☂☁☀☻☹☺♢✄✐☒☠☣☢☤☎✇✈✖▼
FS in NYC: http://www.muffwiggler.com/forum/viewtopic.php?p=1160656 |
| Back to top |
Posted: Fri Sep 23, 2011 12:09 am Post subject: |
| giorgio wrote: | Rico I am loving that panel. I hope mine can look like that at some point. still not sure what's gonna go in it yet... might make 2 or the same, each with a single 258 vco, single teezer, dual 281, single serge VCS & dual LPG and then the other/zany stuff on a 3rd panel..
did you make this from scratch? | thank you Giorgio, I used a blank serge panel template and the swooshes were made by someone else, other than that it's all me... I'm actually pretty blown away it's turning out _________________ works for Malekko Heavy Industry |
| Back to top |
widdly Wiggling with Experience
    Posts: 486 Location: singapore
Posted: Fri Sep 23, 2011 1:34 am Post subject: |
Nice Panel and nice thread idea. I'll post the serge-a-like panel I'm designing once it's done.
For fonts I'm using itc eras medium. I use it italic for the labels at the top.
The comments below are pedantic so feel free to ignore them. I think there is a little too much labelling. Also serge panels tend to have outputs at the top and inputs at the bottom.
On the 281 I'd leave off the labels ATTACK IN and DECAY IN and connect the socket with a line to the swoosh on the knob. You could even connect the attack knob, attack cv knob and attack cv input with a line and then put an ATTACK label above the attack knob and a VC label between the cv input and the attenuator. Kinda like the slope control on the variable slope vcf here.. http://www.serge-fans.com/m-class-bi-filter.cfm
On the LPG I'd remove the CONTROL IN and CV IN labels and connect the to the knob swoosh and use a single label for the knob and input. I'd remove the INPUT LEVEL and connect the knob to the socket with a line and have a single INPUT label.
Again, on the wogglebug I'd use a single label for cv inputs that have an attenuator (RATE and SMOOTH), connect them with a line and place the label in the middle.
On the Wogglebug, I'd use a line to group the output sockets. Kinda like the outs on the vcf on m-panel I posted. If you put all the outputs at the top and separated them with a line, you could label the section OUTPUTS then label the sockets WOGGLE instead of WOGGLE OUT etc.
On the Sequential switch, I'd move the IO1..IO4 to the top of the panel and put a line around them.
I'd change the bandpass to kHz (instead of Khz). Actually for fully serge-a-like I'd leave of the Hz altogether.. so 200 200-900 900-4k and 4k+ like the resonant eq here.. http://www.serge-fans.com/m-class-eq-shift.cfm |
| Back to top |
Posted: Fri Sep 23, 2011 2:23 am Post subject: |
@widdly...def some good ideas, I'll try em out tomorrow see how they look. What size fonts are you using, I feel like mine is too big to fit in-between the swooshes and jacks... I think I'll def at least try putting outputs at top in an outline and inputs on bottom _________________ works for Malekko Heavy Industry |
| Back to top |
Posted: Fri Sep 23, 2011 2:28 am Post subject: |
| I'll check the font size tonight. Yours looks a bit bigger than what I'm using. |
| Back to top |
lie3vie3 Common Wiggler
   Posts: 104 Location: Belgium
Posted: Fri Sep 23, 2011 2:46 am Post subject: |
If you plan to use this panel stand-alone you could use some mixers because now all you're modules have only one input. I would move the deep-switch of the 292 off-grid and add an extra input. If you remove the input level pot of the 194 and move the outputs up, you could add an attenueverter in the bottom three spots. Lastly I would (and I did) name the single input/output of your sequential switch 'O/I' to show that it's different from the other inputs/outputs. I also think you would miss the switch to select the number of stages, maybe you can fit it in off-grid? _________________ Youtube Channel |
| Back to top |
Posted: Fri Sep 23, 2011 3:10 am Post subject: |
| lie3vie3 wrote: | | If you plan to use this panel stand-alone you could use some mixers because now all you're modules have only one input. I would move the deep-switch of the 292 off-grid and add an extra input. If you remove the input level pot of the 194 and move the outputs up, you could add an attenueverter in the bottom three spots. Lastly I would (and I did) name the single input/output of your sequential switch 'O/I' to show that it's different from the other inputs/outputs. I also think you would miss the switch to select the number of stages, maybe you can fit it in off-grid? | Oh shit totally forget the switch for the seq switch! Thanx for reminding me. The panel will be w a couple of the zthee bog panels so the mixer on that should cover me. _________________ works for Malekko Heavy Industry |
| Back to top |
Posted: Wed Sep 28, 2011 1:15 pm Post subject: |
ok heres my revised panel so far, tried to get most of the outputs to the top and dropped some of the redundant naming. Also read somewhere the font was ITC Eras so changed to that
| Back to top |
Posted: Fri Sep 30, 2011 12:29 pm Post subject: |
one last bump before i send this out to Luigi at epinasty. anyone see any spelling errors? _________________ works for Malekko Heavy Industry |
| Back to top |
Luka Super Deluxe Wiggler
    Posts: 4910 Location: melbourne
Posted: Fri Sep 30, 2011 12:55 pm Post subject: |
looks good to me rico
i have most of those modules and the one thing i wish i had added more was leds. it is nice to be able to see what is happening. i suppose it isn't very serge approach so you may not care. _________________ .
melbourne australia
soundcloud
lastfm
vimeo
wtb:
220/230/240v Broken Dp4
20x20 ghielmetti matrix
taking offers on (melbourne pickup)
revox pr99 mk2
allenheath zed420 |
| Back to top |
| Back to top |
Posted: Fri Sep 30, 2011 8:10 pm Post subject: |
thanks guys, well i guess off it goes... _________________ works for Malekko Heavy Industry |
| Back to top |
| Back to top |
Neutron7 Oldschool bleeper
Posted: Wed Oct 05, 2011 1:54 pm Post subject: |
This is a "multibus"
I bought a boatload of multiway switches and need something to use them for!
there will be 4 of them, one for each "corner" of my synth. It is to save on long wires getting in the way, and i need a bunch of multis anyways, especially with my cirklon CVIO box shipping any day now!
they are all connected together internally with 8 shielded bus cables,
each of the 4 multis can be connected to any of the busses or none at all.
FPD file:
http://dl.dropbox.com/u/3248170/multibus.fpd
I am using white chickenheads for the switches. |
| Back to top |
falafelbiels still learning to wiggle
   Posts: 2686 Location: Rotterdamm son
Posted: Wed Oct 05, 2011 4:28 pm Post subject: |
nice idea! I have a bunch of those switches as well and no project for them... yet...
looks in order. |
| Back to top |
