Front Panel Proof Reading Thread
Goto page Previous  1, 2, 3, 4, 5, 6 ... 9, 10, 11  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author Front Panel Proof Reading Thread
emdot_ambient
Last Visit: 25 May 2013
PostPosted: Fri Oct 28, 2011 6:38 pm    Post subject: Reply with quote Add User to Ignore List
I would suggest swapping the shape controls and the fine tune controls, then just use a line connecting Coarse and Fine which will indicate their connection without the need for additional labels.
Right now the shape controls are floating by themselves, that's why I asked about them. Putting the Fine controls there would make more sense (to me) especially if their association with the Coarse control is graphically illustrated.
"None of your five bar gate jumps and over sort of stuff."
negativspace
Manhattan Analog
PostPosted: Fri Oct 28, 2011 8:22 pm    Post subject: Reply with quote Add User to Ignore List
Oh hey, look who's layout-critiquing now. hihi
When I tried it the way you describe - and I absolutely did - I didn't like the relationship between the waveform switch and the fine control pot. They're too close to one another to be functionally unrelated. Since I'm committed to sticking with a layout that fits with the existing modules in the series, every possible control arrangement is a compromise of some sort. I think this is the compromise that works best for me.
I do appreciate the feedback and critique, though! No stone unturned...
Analogue HavenCTRLEquinoxOZEFNFoxtone MusicPostModularSchneidersbüro
Luka
PostPosted: Fri Oct 28, 2011 8:51 pm    Post subject: Reply with quote Add User to Ignore List
Sorry - didnt mean to open a can of worms smile
melbourne australia
soundcloud
lastfm
vimeo
wtb:
220/230/240v Broken Dp4
20x20 ghielmetti matrix
taking offers on (melbourne pickup)
revox pr99 mk2
allenheath zed420
emdot_ambient
PostPosted: Fri Oct 28, 2011 9:54 pm    Post subject: Reply with quote Add User to Ignore List
Ah, but that wasn't criticism. I was, rather, simply suggesting a possible solution to the dilemma.
It ain't a can of worms so much as the usual push and shove, give and take of panel design thumbs up
Of course one way around the issue is to get rid of the Fine controls totally and just use 10-turn pots (hides)
Luka
PostPosted: Fri Oct 28, 2011 9:55 pm    Post subject: Reply with quote Add User to Ignore List
That is how all my vcos are done - i dont see the point of duplicate controls
melbourne australia
soundcloud
lastfm
vimeo
wtb:
revox pr99 mk2
allenheath zed420
negativspace
Manhattan Analog
PostPosted: Fri Oct 28, 2011 11:11 pm    Post subject: Reply with quote Add User to Ignore List
I had that thought, too... but I really prefer the coarse/fine control arrangement in actual use. Plus, I thought it might be good to be able to sweep the full frequency range of these with a turn of a knob - FM wackiness and whatnot.
EATyourGUITAR
has no life
PostPosted: Mon Nov 07, 2011 2:45 pm    Post subject: Reply with quote Add User to Ignore List
I need some DUSG in my life. I'm hoping this will increase the power of my very small system. I did not include an AC out or the 1v/oct input. you can put a normal connection from trig out to trig in if you will use it for LFO more than a AD or AR.
Norman_Phay
tehpwnzriated
Last Visit: 23 May 2013
PostPosted: Sat Nov 12, 2011 3:09 pm    Post subject: Reply with quote Add User to Ignore List
I've been mulling over this one for a while - it's for the ryk M185 sequencer, in frac format. I've made it real life size on the computer screen and held the various components up against it to make sure it all fits and it seems all right, but likely to be an expensive mistake if not! Have a look:
http://soundcloud.com/theda-electronic-music/
http://http://vietgrove.bandcamp.com/ <---new album 14-06-12!!!1
EATyourGUITAR
has no life
PostPosted: Sat Nov 12, 2011 4:10 pm    Post subject: Reply with quote Add User to Ignore List
@ Norman Phay I see two 3mm holes that look like they should not be there in the middle of the panel. they could be 3mm LED's? what about Run/stop, reset, prev, next? are those buttons? if so 0.15 is kinda small for a button shaft unless its PCB mount. the 3mm LED between RESET and PREV is probably fine. but I don't know why you have a few 3mm LED between step 5 and 6 at the top and bottom. that looks like a mistake. I don't know why you want two LED's for 5 but not the others. CV OUT has two holes. whats the 0.25 inch? is that banana or euro? then there is a 0.17 inch next to that. is that a jewel light?
sduck
WTF?
PostPosted: Sat Nov 12, 2011 5:02 pm    Post subject: Reply with quote Add User to Ignore List
Those holes between 5 and 6 and the extra ones at 3 and between reset and prev are pcb mounting holes I would presume - ?. The extra cv out hole is for the range selection switch.
Actually everything looks pretty good. I built the 2.1 version of this, but the only front panel difference is the stage cv in. I assume your stage leds are at the bottom, and the knobs are at the top? If so, the knobs may be a bit crowded, depending on what kind of knobs you're using. There are 2 3mm holes that look like the may be leftover led holes in the middle of stages 1 and 2 - or are those mounting holes for the portmento add-on pcb?
What they do is this: They leak current in proportion to the frequency of the signal. The ramifications of this can only be truly appreciated when solving nodal current balances in the Laplace domain, unfortunately.
flickr cloud of sound touyube
fluxmonkey
PostPosted: Sat Nov 12, 2011 5:58 pm    Post subject: Reply with quote Add User to Ignore List
to me, it's counter-intuitive to group the pots together vertically, but th jacks grouped horizontally... easy enough tp swa[ 'em so each channel lines up in one row. you could then also add some vertical dividing lines to help keep each AR visually distinct...
www.fluxmonkey.com
please email (rather than PM) with any direct correspondence
EATyourGUITAR
has no life
PostPosted: Sat Nov 12, 2011 6:13 pm    Post subject: Reply with quote Add User to Ignore List
your probably right. I just thought it would look stupid with
ATTACK ATTACK ATTACK ATTACK across the top but I did not even try it that way. I know I need to move the LED's if I do it that way. I might just scrap the design in favor of a dual module with +/- exponential curve knobs and exponential on/off toggle switch. I may or may not have some 281 coming instead of the DUSG. I heard Toppo has more PCB's but is too busy to answer PM's right now. 281 or DUSG the saga continues.
Norman_Phay
tehpwnzriated
PostPosted: Sat Nov 12, 2011 6:15 pm    Post subject: Reply with quote Add User to Ignore List
Sduck has it - the additional holes are for the ryk pcb and a stripboard addon for the portamento mod. Looking at each stage, the little hole at the bottom is for the stage LED, and the hole above the long slider cutout is for the little switch to select portamento for that stage.
For the 3 knob controls - tempo, slide and gate time, I was going to use those serge knob lookalikes that small bear do, I have a big bag of them. The pushbutton switches for run/stop, reset, previous and next are these tiny little sub-min buttons I saw at Maplin's.
I'm planning on ordering this one next. Even though I have pesoldered all of the resistors to the little 4- and 8-way switches, I am dreading the panel wiring for this one, it looks like a real ordeal.
Rod Serling Fan Club
aquatic hitchhiker
Last Visit: 24 May 2013
PostPosted: Tue Nov 15, 2011 8:49 pm    Post subject: Reply with quote Add User to Ignore List
My panel design program and skills are rudimentary so so use your imagination. The "+" are knobs, switches, jacks and LEDs. Don't get too hung up on size differences of the +'s. I used another panel as a template so a few are inconsistant. I'm mostly concerned about any spelling errors and the like or if there is something about the layout you would change. There are already a couple things I'll likely change... Thanks!
DIY panels and PCBs for Buchla and Euro format: http://synthpanels.blogspot.de/
youtube channel: http://www.youtube.com/user/MrPalebluedot
emdot_ambient
PostPosted: Tue Nov 15, 2011 9:41 pm    Post subject: Reply with quote Add User to Ignore List
I don't see any errors.
aquatic hitchhiker
PostPosted: Wed Nov 16, 2011 1:08 pm    Post subject: Reply with quote Add User to Ignore List
Thanks emdot
valis
aliens killed bigfoot
PostPosted: Tue Nov 22, 2011 11:27 pm    Post subject: Reply with quote Add User to Ignore List
@ Rod Serling Fan Club I don't see any noticeable typos either. I don't quite understand the multiplier/divider module so I assume that's all labled correctly. Looks good.
fluxmonkey
PostPosted: Wed Nov 23, 2011 11:05 am    Post subject: Reply with quote Add User to Ignore List
@Rod Serling Fan Club -- just my own quirk, but i tend towards a left->right organization based on the order modules are most likely to be patched. i have more short patch cables than long, and it generally help me keep a clear mental map when i'm tweaking. so i'd rearrange a bit, maybe (left to right):
-clock
-RCD
-Sequencer
-Woggle
-Switch
-Quantize
-Mix
also for me personally, i'd be doing a lot of CV summing on a panel like this, and would probably opt for 2 single-width mixers (3 bipolar ins and a bias?,) rather than a double.
www.fluxmonkey.com
aquatic hitchhiker
PostPosted: Wed Nov 23, 2011 5:11 pm    Post subject: Reply with quote Add User to Ignore List
Thanks for check valis
flux - I do to and on paper the order was roughly similar to what you suggest. Then I started looking at different setups and serge panels and such (like the sequencer and red control panels for isntance) and realized the panels seemed a bit backwards to me and then it all made sense. If you have your VCOs on the left of a panel it would make sense that a CV control panel like this would have the quantizer/sequencer closer to the VCOs. It also made sense that clock divisions and such would be closer to EGs and things you would want to clock, which jives with my other panel.
Good idea on the mixing capabilities. I could shrink the quantizer by a row, and have already been considering doing so. The CGS mixer pcb is small enough and I have one on hand. I really like being able to use the attenuvertor as a mixer and/or invidual bi-polar "CV processors" so I think I would keep that but adding an additional mixer is a great idea.
aquatic hitchhiker
PostPosted: Fri Nov 25, 2011 12:43 pm    Post subject: Reply with quote Add User to Ignore List
I think this is my final revision. Thanks for the mixer suggestion flux. I worked out perfectly. I was going to try to stick a CGS VC comparator/divider there but the PCB was going to be tough to fit in the box as many of the PCBs in the boat take up a lot of room and are different shapes so stacking is difficult. The CGS mixer board is tiny and perfect.
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 5 of 11
