cats and modular synths, but mostly cats
[BUILD] - CGS Euro Modules
Goto page Previous  1, 2, 3, ... 19, 20, 21  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author [BUILD] - CGS Euro Modules
RealDudes
Lives in a Dudeplex
Last Visit: 19 Jun 2013
PostPosted: Wed Nov 23, 2011 2:08 pm    Post subject: Reply with quote Add User to Ignore List
Can we see a pick of the completed backside of one of these beauties? they look SlayerBadger!
my goatee isnt stupid
https://soundcloud.com/sounddudes
jenamu6
PostPosted: Wed Nov 23, 2011 2:28 pm    Post subject: Reply with quote Add User to Ignore List
SMS303 wrote:
jenamu6 wrote:
Could these panels and designs be easily bananafied?
That should be possible, imo ....
Jean will you build them or ..... ???
If you're not...
I'm still busy with 2 Best of CGS BOG's & MARSH...
I can put them in my backlog if you pay enough razz Mr. Green
Paying you to screw up components and a PCB?
Me thinks.....NO!!!
Open tape:
http://jenamu6.muffwiggler.com
My youtube modular music movies:
http://www.youtube.com/results?search_query=jenamu6&search_type=&aq=f
My modular noises:
http://soundcloud.com/jenamu6
SMS303
Tha BABELFISH Wiggler...
Last Visit: 18 Jun 2013
PostPosted: Wed Nov 23, 2011 2:30 pm    Post subject: Reply with quote Add User to Ignore List
Me thinks.....NO!!!
d'oh! hmmm..... !LOL! Mr. Green
In Casper we TRUST! SlayerBadger!
<--- Jaime Murray does Capua....
http://nl.electrobel.org/SMS303
https://soundcloud.com/sms303
http://www.mixcloud.com/SMS303/
http://www.flickr.com/photos/sms303/
clarke68
Making DIY modulars look cool since 2011
PostPosted: Wed Nov 23, 2011 3:22 pm    Post subject: Reply with quote Add User to Ignore List
I just updated the "PCB Mounting" post on the first page with these (and a few other) photos:
That's as far as I've gotten in my builds. At this point, I expect some of the other guys will have boards populated and modules screaming before I do...keep your eye on this thead!
RealDudes
Lives in a Dudeplex
PostPosted: Wed Nov 23, 2011 3:28 pm    Post subject: Reply with quote Add User to Ignore List
they look like architecture models
we're not worthy we're not worthy we're not worthy
clarke68
PostPosted: Wed Nov 23, 2011 3:29 pm    Post subject: Reply with quote Add User to Ignore List
Depends what you consider easy. The jack holes are all sized for 3.5mm jacks...about 6mm. The banana jacks I've used require about 8mm, so you'd have to drill out all the jack holes. Not too bad a job if you're fairly comfortable with a drill.
Beyond that, I think there might be one place in all of these panels where I assumed a normalized connection would be implemented...may have been in the Funky Drummer, I can't remember.
apfEID
electro-vivisection
PostPosted: Wed Nov 23, 2011 3:39 pm    Post subject: Reply with quote Add User to Ignore List
these are beautiful, I hope I find time to start doing some DIY next year...
Te Occidere Possunt Sed Te Edere Non Possunt Nefas Est
http://anthonysaunders.bandcamp.com/
Monobass
thonk.co.uk
PostPosted: Wed Nov 23, 2011 4:47 pm    Post subject: Reply with quote Add User to Ignore List
man I can't wait to start mine...
did you post the details of what knobs you used somewhere?
Thonk - Modular Synth DIY
258J Euro kit - Manhattan Analog Kits- 4ms Kits - Clarke68 Panels - Expert Sleepers Glow Cables - Banana Jacks
scozbor
100th Member!
PostPosted: Wed Nov 23, 2011 5:01 pm    Post subject: Reply with quote Add User to Ignore List
yes these panels have barged in and jumped my DIY queu!
http://hadaldrop.bandcamp.com/
http://scozbor.bandcamp.com/
negativspace
Manhattan Analog
PostPosted: Wed Nov 23, 2011 6:15 pm    Post subject: Reply with quote Add User to Ignore List
Part #s from Jameco are listed in the other thread. thumbs up
I'm going to try some black aluminum ones from Mouser, they had one line that worked for all 3 sizes and wasn't stupidly expensive - I hope they don't suck.
Analogue HavenCTRLEquinoxOZEFNFoxtone MusicPostModularSchneidersbüro
clarke68
PostPosted: Wed Nov 23, 2011 7:03 pm    Post subject: Reply with quote Add User to Ignore List
They're in the first post of this thread, too, but I'm happy to repeat:
My knobs are from Jameco. Obviously you can use any knobs you want, but it will help if you get the size close. Sizes and Jameco part #s are:
small - 0.55" - 136241
medium - 19.8mm - 264990
large (on MSU only) - 33.3mm - 264946
falafelbiels
still learning to wiggle
PostPosted: Wed Nov 23, 2011 7:33 pm    Post subject: Reply with quote Add User to Ignore List
SMS303 wrote:
Me thinks.....NO!!!
eek!
clarke68
PostPosted: Mon Nov 28, 2011 3:07 pm    Post subject: Modifying CGS PCBs for +/- 12 volts Reply with quote Add User to Ignore List
I went through Ken's site and did a quick search for everything written about building these PCBs for use with +/- 12v. If you find (or know of) any other 12v mods, please post it and I'll keep this list updated.
CGS29 - Wave Multipliers
While untested, the module should work on +/-12 volts.
CGS77 - Serge 1973 VCF
Will run on +/- 12 volts or +/-15 volts.
CGS35 - Steiner VCF
Version 1.3 can be built as shown on the overlay of the PCB ... For use with +/-12 volt supplies, the two diodes marked with rings around their pads on the overlay should be replaced with links.
CGS114 - DUSG / CGS75 - VCS
CGS48 - VCO
The module will work on +/-12 volts if the 20k resistor connected to pin 3 of the LM311 is reduced to 14k.
CGS13 - Gated Comparator
Resistors RA and RB form the voltage divider that determines the gate output voltage. Use 1k for RB. When running off +/-15 volts use 1k8 for RA. When running off +/-12 volts, use RA = 1k5.
CGS31 - Digital Noise
CGS36 - Pulse Divider/Boolean Logic
VER1.3 PCBs have the upper part of the output dividers marked as RA on the PCB. These resistors are 1k8 for +/-15V operation and 1k5 for +/-12 volt operation. Likewise the two 1k8 resistors in the inverters should be 1k5 for 12 volt operation. The two 1k5 resistors in the OR and AND gates could probably be increased to 1k8 for 15 volt operation. Check your output voltages when you have assembled them. Ideally the voltages will swing between 0 volts and +5 volts. Some small variance either way is nothing to be concerned about.
simfonik
Last Visit: 17 Jun 2013
PostPosted: Wed Nov 30, 2011 12:06 am    Post subject: Reply with quote Add User to Ignore List
Based on the rear panel image for the MSU, it looks like I need the following potentiometers:
(10x) 313-1000F-100K
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B100K/  ?qs=sGAEpiMZZMuarXojuOTsc9jR33G5hGO%252bcj2YiaooI6I%3d
(1x) 313-1000F-1K
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B1K/?q s=sGAEpiMZZMuarXojuOTsc7XUj8Kk%2f1Ts8uwZ%252baquuNs%3d
(1x) 313-1000F-1M
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B1M/?q s=sGAEpiMZZMuarXojuOTsc7XUj8Kk%2f1TscFmzyHqZdKI%3d
(1x) 313-1000F-20K
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B20K/? qs=sGAEpiMZZMuarXojuOTsc3UoKTY4nCEoKqEqi3d3N6w%3d
(1x) 50k log .... can't seem to find this at Mouser or Jameco.
Does that look right? Any idea on the 50k log pot? dizzy
negativspace
Manhattan Analog
PostPosted: Wed Nov 30, 2011 12:19 am    Post subject: Reply with quote Add User to Ignore List
50k logs @ Mouser - 313-1500f-50k
simfonik
PostPosted: Wed Nov 30, 2011 12:41 am    Post subject: Reply with quote Add User to Ignore List
w00t Thanks!
bkbirge
Last Visit: 31 May 2013
PostPosted: Wed Nov 30, 2011 6:42 pm    Post subject: Reply with quote Add User to Ignore List
Can't wait to get started on a funky drummer and mini synth. Anyone got one of those shareable mouser project BOM's going yet? If not I'll see about putting a couple together, they make ordering (after the first time) so much easier.
"The person who says it cannot be done should not
interrupt the person doing it." ~ Chinese Proverb
Tall Midget
Extra Value Super-Premium Wiggler
PostPosted: Wed Nov 30, 2011 11:15 pm    Post subject: Reply with quote Add User to Ignore List
Hey Brian, I already posted one in the other thread, it's just an Excel spreadsheet but it works with mousers BOM import tool. It needs some work described below to it but it's mostly complete. The only things missing AFAIK are the 22k (25k) trimmer for the Serge Voltage Controlled Filter and the 22k-25k trim for the CGS VCO. I'm not even sure if the other trim-pots I specified are still in stock. That's all that's keeping me from starting the project are the trim-pots. I'm not sure if I made the changes for 12 volt operation listed above either. If someone were to make it a complete BOM that'd be really neat.
Tall Midget wrote:
I didn't include the knobs or jacks, too tired to add them or count them now but most of the parts are there I think. Potentiometers are Mouser Part #'s but I would order them from somewhere else other than mouser to save money. There are a few Digikey part # that aren't specifically listed as being from Digikey but if Mouser doesn't recognize a part number when you import it, odds are it's a Digikey part number.
Edit: Check out the updated BOM bkbirge posted on Page 3 of this thread.
Tall Midget
PostPosted: Wed Nov 30, 2011 11:17 pm    Post subject: Reply with quote Add User to Ignore List
Also here's some of the parts needed for the Funky Drummer:
clarke68 wrote:
Gated Comparator Sequence pots are all 100k linear.
Here's all of the switches on the Funky Drummer:
Pulse Divider Reset - Mouser #633-FB15ANEP2
Note actual part number is 633-FB15ANEP2-xy, where x is the size (F = small, H = large) and y is the color (C = red, A = black, B = white) of the button cap. This part is pretty critical, as the hole in the panel is specifically sized for this switch. Good quality switch, tho...tested to 50k cycles.
Gated Comparator Manual Loop/Load - Mouser #633-M201901-RO
There are probably other switches that will fit here, just be sure you get one that's ON - OFF - (ON)
Digital Noise Clock & Gated Comparator Loop Enable - most any SPDT ON - ON will work, the mounting holes are 0.25 in. which seems typical. I used part #317236 from Jameco.
bkbirge
PostPosted: Thu Dec 01, 2011 11:09 am    Post subject: Reply with quote Add User to Ignore List
Cool, didn't know about the BOM import tool.
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 2 of 21
