[BUILD] - CGS Euro Modules
Goto page Previous  1, 2, 3 ... 15, 16, 17 ... 19, 20, 21  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author [BUILD] - CGS Euro Modules
simfonik
Last Visit: 22 May 2013
PostPosted: Sat Mar 24, 2012 7:49 pm    Post subject: Reply with quote Add User to Ignore List
That looks amazing, Rico. cool
rico loverde
Last Visit: 24 May 2013
PostPosted: Sat Mar 24, 2012 8:40 pm    Post subject: Reply with quote Add User to Ignore List
Thanx guys! It wouldnt have happened if it wasnt for this amazing forum!
works for Malekko Heavy Industry
View user's profile Send private message Send e-mail Yahoo Messenger
lessavyfav
PostPosted: Fri Apr 06, 2012 2:06 pm    Post subject: Reply with quote Add User to Ignore List
Hello - can anyone explain which size LED's I should get to fit into the 3mm LED Lens I got. The BOM has 5mm LEDs, I had some of these at my space and they don't seem to fit. Should they, like, click in?
negativspace
Manhattan Analog
PostPosted: Fri Apr 06, 2012 2:30 pm    Post subject: Reply with quote Add User to Ignore List
The holes are sized for 3mm LEDs in holders. (Lens maybe as well.)
Analogue HavenCTRLEquinoxOZEFNFoxtone MusicPostModularSchneidersbüro
clarke68
Making DIY modulars look cool since 2011
PostPosted: Fri Apr 06, 2012 2:49 pm    Post subject: Reply with quote Add User to Ignore List
3mm LED lenses are for T-1 size LEDs. T-1 is secret LED manufacturer talk for "3mm", but you won't find anything at mouser looking from 3mm LEDs. 5mm LEDs are called "T-3".
Assembly instructions on the LED lens data sheet are: "Insert lens through panel hole, and insert LED into lens."
lessavyfav
PostPosted: Fri Apr 06, 2012 3:20 pm    Post subject: Reply with quote Add User to Ignore List
Great! T-1. Yeah that is the trick. I was searching 3mm and getting nothing...
Thanks everybody. Slow me keeping this thread alive!
jbaken
PostPosted: Wed Apr 11, 2012 10:14 pm    Post subject: Reply with quote Add User to Ignore List
So I finally finished the mini synth and it sounds great.. My one issue is with the vcas. When I plug my vco into into either of my vcas I get a bit of bleed through. I made sure the vca was outputting 0 dc and minimized cv bleed w the trims. I also gave every module it's own plug to the power supply so I'm stumped over this.. Any ideas would be great
rico loverde
PostPosted: Wed Apr 11, 2012 10:48 pm    Post subject: Reply with quote Add User to Ignore List
i had this issue but it worked itself out when i redid the power on mine. there were a few issues i had so I'm not 100% sure the rewiring of the power is what solved it. i ended up getting a cps motm busboard and power each module off that. hopefully someone else will offer some better help
ringstone
antipodean experimentalist
Last Visit: 23 May 2013
PostPosted: Wed Apr 11, 2012 10:50 pm    Post subject: Reply with quote Add User to Ignore List
I believe this can happen if the 3 BC548's are not well matched (think I saw a reference to this on the CGS mailing list). I have a bit of bleed on mine, but I didn't have a large stock to choose from. I will order up a bunch in the near future and do a better matching job...
Blair
Ecclesiastical Scaffolding Facebook
Mindless Eye * Soundcloud
some noise
jbaken
PostPosted: Thu Apr 12, 2012 12:03 am    Post subject: Reply with quote Add User to Ignore List
Hmm I guess I didn't match the 548s as close as the dual. I also don't recall having bleed on my test power supply. Feels like trannies or my mono rocket case are to blame.
Besides that, this thing is amazing. I gotta thank everyone here for posting their experiences/troubles w the build...It helped me a lot.
regenbot
PostPosted: Sat Apr 14, 2012 3:40 pm    Post subject: Reply with quote Add User to Ignore List
Question about the DUSG wiring. Is the VC IN pot just an attenuator. Can i put cv input to signal in of the pot and then out to F on the pcb? I thought could, but iam somewhat confused after lookin at the schematics and wiring documentation. hmmm.....
Another thing i notice that there are three different M marked inputs on the board. I'm assuming the trig out is on the two M's near the 5V6 diodes. What's that third M input for?
Cheers, Heikki
sounds
drawings
free music
ringstone
PostPosted: Sat Apr 14, 2012 8:20 pm    Post subject: Reply with quote Add User to Ignore List
Cheers, Heikki
It's not "W" - which is just above one FC input? If so, it's the 0V power terminal.
Blair
some noise
regenbot
PostPosted: Sun Apr 15, 2012 1:55 am    Post subject: Reply with quote Add User to Ignore List
It is d'oh! I now remember confusing it with an M earlier too, thanks for your help smile
sounds
drawings
free music
regenbot
PostPosted: Sun Apr 15, 2012 2:31 am    Post subject: Reply with quote Add User to Ignore List
So can anyone tell if i can put the VC input as an passive attenuator? CV In > VC In pot > F on the pcb?
Cheers, Heikki
sounds
drawings
free music
hv0190
Last Visit: 10 May 2013
PostPosted: Sun Apr 15, 2012 2:36 am    Post subject: Reply with quote Add User to Ignore List
Heikki, if I read the schematics of the DUSG right this wouldn't work as intended, as the CV In at the same time feeds the negative input of an op amp through a 470K resistor - the attenuator is designed to be a polarised attenuator - wiring it your way this wouldn't work I guess hmmm.....
If the journey is the reward I might as well sit down beside the road and have some beers right now.
regenbot
PostPosted: Sun Apr 15, 2012 2:52 am    Post subject: Reply with quote Add User to Ignore List
Ok, i thought so too, but had to make sure before rewiring cry
Thanks Guinness ftw!
sounds
drawings
free music
Emalot
PostPosted: Sun Apr 15, 2012 3:45 am    Post subject: Reply with quote Add User to Ignore List
Rico, we're not worthy we're not worthy
Can you tell us the list of modules in your case??
EDIT;I saw the list in the "gloat thread" Guinness ftw!
regenbot
PostPosted: Mon Apr 16, 2012 2:36 pm    Post subject: Reply with quote Add User to Ignore List
EDIT: I think i have wrong kind of power supply in my uzeus no ground eek!
Ok got the quadslope all wired up now. It is working apart from one dead led.
There is one issue. The voltage it outputs is wobbly and shaky is it somekind of grounding issue?
I did put all the pot & jack grounds to onky one of the boards. Could that cause issues?
Please help
sounds
drawings
free music
Monobass
thonk.co.uk
PostPosted: Mon Apr 16, 2012 2:50 pm    Post subject: Reply with quote Add User to Ignore List
Mouser seem to be out of 20k or 25k 9mm small 9mm pots...
http://uk.mouser.com/Search/Refine.aspx?Keyword=311-1902F
anyone know of a suitable alternative?
negativspace
Manhattan Analog
PostPosted: Mon Apr 16, 2012 4:19 pm    Post subject: Reply with quote Add User to Ignore List
Try Small Bear, I know he's out of the 50k Linear but I think he's got the rest in stock. (Incl. 25k.) If Banzai Music is easier for you since they're on your side of the Atlantic, they should have them as well.
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 16 of 21
