| View previous topic :: View next topic |
| Author |
power LED flicker? (TipTop Zeus) |
50quidsoundboy beneath the carpet tiles, the beach
 Posts: 477 Location: London, UK
Posted: Fri Dec 02, 2011 6:05 pm Post subject: power LED flicker? (TipTop Zeus) |
hi all
i just set up my first system tonight (OMG it's so much fun).
the +12v power LED on my bus board is fickering, is this normal? the sound seems unaffected. i'm running a TipTop microZeus onto a Zeus passive bus board, powering three modules. |
| Back to top |
Diao Wiggling with Experience
   Posts: 487 Location: Kansas City, Kansas
Posted: Fri Dec 02, 2011 6:11 pm Post subject: |
| Make sure your power switch on the µZeus is all the way up. They can be a little goofy from time to time, so if its flickering just give the switch a little extra *oomph* up and it should stop. |
| Back to top |
Posted: Fri Dec 02, 2011 6:12 pm Post subject: |
| And by the way, that does mean that its not getting solid +12V power, so I would recommend making sure its up before you do any serious wiggling. |
| Back to top |
Posted: Fri Dec 02, 2011 6:47 pm Post subject: |
hmm no, fiddling with the switch has no effect. the connections between the microZeus and the bus board seem sound, although i did make up the connecting wires / spade connectors myself and i'm a bit of a soldering novice (not totally inexperienced though) - perhaps i need to check them further for a bad joint or something.
the modules seem unaffected - no flickering LEDs on those. also the +5v bus LED doesn't flicker at all, nor do the LEDs on the microZeus itself. no idea what's going on. |
| Back to top |
lombrose Wiggling with Experience
   Posts: 369 Location: Recife, PE, Brazil
| Back to top |
Posted: Fri Dec 02, 2011 7:31 pm Post subject: |
| 50quidsoundboy wrote: | hmm no, fiddling with the switch has no effect. the connections between the microZeus and the bus board seem sound, although i did make up the connecting wires / spade connectors myself and i'm a bit of a soldering novice (not totally inexperienced though) - perhaps i need to check them further for a bad joint or something.
Ah, sorry, I misread your original post as the LED's on the µZeus were flickering . Ones on the busboard I have no clue about. |
| Back to top |
Posted: Fri Dec 02, 2011 8:03 pm Post subject: |
Reading this I become to think if this same issue caused the problem on my FoH power...  |
| Back to top |
Posted: Fri Dec 02, 2011 8:11 pm Post subject: |
| lombrose wrote: | Reading this I become to think if this same issue caused the problem on my FoH power...  |
did you experience the exact same symptom - a flickering/blinking +12v LED on the passive bus board? |
| Back to top |
Posted: Fri Dec 02, 2011 8:22 pm Post subject: |
| 50quidsoundboy wrote: | | lombrose wrote: | Reading this I become to think if this same issue caused the problem on my FoH power...  |
Yes exact the same symptom, and I`m afraid my NR was affected...  |
| Back to top |
Posted: Sat Dec 03, 2011 5:00 am Post subject: |
| thanks for the tip - i'll get a multimeter and check my voltages before proceeding further. |
| Back to top |
Yeuky Common Wiggler
 Posts: 84 Location: Sydney, Australia
Posted: Sat Dec 03, 2011 5:51 am Post subject: |
| This has been a known issue on the TipTop distro boards for a while. It is more than likely that the LED itself is the problem, and your power is fine. |
| Back to top |
Posted: Sat Dec 03, 2011 6:09 am Post subject: |
| Yeuky wrote: | | This has been a known issue on the TipTop distro boards for a while. It is more than likely that the LED itself is the problem, and your power is fine. |
that sounds promising - have you experienced this yourself, or has it been discussed elsewhere on MW? (not doubting your opinion, just trying to gather as much info as possible...) |
| Back to top |
Posted: Sat Dec 03, 2011 6:50 am Post subject: |
There's been a bit of dicussion on the issue, i.e this thread.
As long as you can measure a constant +12v, and everything works fine, then the issue is very likely the LED. |
| Back to top |
Posted: Sat Dec 03, 2011 7:04 am Post subject: |
| Yeuky wrote: | There's been a bit of dicussion on the issue, i.e this thread.
ah brilliant, thanks. |
| Back to top |
| Back to top |
Posted: Sun Dec 04, 2011 11:16 am Post subject: |
| Back to top |
