Anyone ever seen a Frac/Eurorack Combo Rack?
Goto page 1, 2  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Fractional Rack Modules
Author Anyone ever seen a Frac/Eurorack Combo Rack?
Tubeampguy
Last Visit: 21 May 2013
PostPosted: Wed Dec 07, 2011 1:35 am    Post subject: Anyone ever seen a Frac/Eurorack Combo Rack? Reply with quote Add User to Ignore List
Anyone ever seen a case that would house and power both FRAC and EURORACK? help
Tubeampguy
PostPosted: Wed Dec 07, 2011 2:06 am    Post subject: Reply with quote Add User to Ignore List
Well I guess I'm not alone wanting a combo rack for both FRAC and EURORACK.
Now all we need is a rack manufacturer to step up to bat and offer it up. Are you listening MONOROCKET, ETC, ETC seriously, i just don't get it
Cat-A-Tonic
Lobsters love Muff
PostPosted: Wed Dec 07, 2011 3:17 am    Post subject: Reply with quote Add User to Ignore List
Not commercially,
but you could DIY a case with 2 PSUs and 2 bussboard systems.
Make one row for each format.
I've seen it done by others in the past.
http://soundcloud.com/decay-generator
stk wrote:
We "deserve" exactly what we get, if we leave it up to somebody else to determine our destiny.
BananaPlug
Last Visit: 20 May 2013
PostPosted: Wed Dec 07, 2011 8:44 am    Post subject: Reply with quote Add User to Ignore List
The last two iterations of my frankensynth use a metal frame. Each 3U row can be used for frac or euro easily. It's kind of a post and beam construction. Each rail is supported by legs going straight to the back of the case. That provides some flex so you can get the rail to rail spacing you need for frac or euro (a small difference). The rails use a sliding nut that takes an M3 screw. That takes care of side to side issues. You could split a rail, adding legs there and have a row that's half euro and half frac.
Here's what I'm talking about. I used it as three rows of frac but any of the rows would accommodate euro just as easily. If the lack of a little lip above and below the euro modules bothers you you might add some kind of filler strip and attach it to the legs. small gaps between rows are helpful for cooling anyway. The metal stuff is called Microrax. The cost adds up by the time you get all the little bits of hardware but it served my purposes very well and goes together quickly.
It's peanut butter jelly time!
mamonu
90s ambient miscreant!!
PostPosted: Wed Dec 07, 2011 12:15 pm    Post subject: Reply with quote Add User to Ignore List
now this looks great!
thumbs up thumbs up
Tubeampguy
PostPosted: Wed Dec 07, 2011 10:18 pm    Post subject: Reply with quote Add User to Ignore List
That is killer! I'll have to look into this. Thanks! applause
Tubeampguy
PostPosted: Sat Dec 10, 2011 4:26 am    Post subject: Reply with quote Add User to Ignore List
I found this online from Elby. Russian Roulette poke Fencing
www.elby-designs.com/panther/euro-frac.pdf
limpmeat
PostPosted: Wed Dec 14, 2011 8:34 pm    Post subject: Reply with quote Add User to Ignore List
Can you use normal rack mounting rails for Frac? Thinking of building a new rack for some frac modules and I have some spare rail lying around.
adamf
Last Visit: 07 Mar 2013
Location: Ya know. Melbourne Orstralia mate! Where people play footy with VB cans and have sex with utes.
PostPosted: Thu Jan 26, 2012 7:13 am    Post subject: Reply with quote Add User to Ignore List
I have been focusing more on my frac than euro of late. I wanted to get a delay module into my frac system. Thinking it over, I realised that my Harvestman Tyme Sefari measured 15 hp, which happens to be a very good size match for two frac spaces. So, with a bit of bravery, I mounted it into my frac case by drilling some appropriately spaced holes in the frac rails and making a little power connector adapter. Powered it on and have been enjoying it ever since. Not sure about the wisdom of running it on 15 rather than 12v, but it works for me (so far...).
Using this same principle, you could mount any combination of euro modules that adds up to 30 hp (ie: 4 frac spaces) into a Frac system, provided they are ok on 15v.
adamf
PostPosted: Sun Jan 29, 2012 11:35 pm    Post subject: Reply with quote Add User to Ignore List
actually, there is another limiting factor: some euro modules have pcbs that take up too much of the 3ru width, so won't fit inside the frac rails.
solitaryzen
Last Visit: 13 May 2013
PostPosted: Mon Jan 30, 2012 3:23 am    Post subject: Reply with quote Add User to Ignore List
The frac Zeroscillator I got also has this problem - had a load of trouble getting it into a Blacet rack. It's not going to be moved anytime soon!
Adam-V
Count Modula
PostPosted: Mon Jan 30, 2012 4:39 pm    Post subject: Reply with quote Add User to Ignore List
Very true. The rails in frac racks are quite a bit closer together than the rails in eurorack.
And FWIW, some euro modules have PCBs that don't even fit between euro rails! I had to grind the edges off the PCB on the uLFO in order to mount it in my Doepfer rack. There are a couple of Livewire modules that are a bit of a squeeze too.
Adam-V
[Digitalis Effect] [Fractured Symmetry] [Cloud of Sounds] [Tape of Mixness][Analogue Synth Tool]
adamf
PostPosted: Thu Feb 02, 2012 7:49 pm    Post subject: Reply with quote Add User to Ignore List
Actually, I'd almost forgotten about this portable Euro/frac system that I set up a couple of years ago:
http://www.flickr.com/photos/14288700@N02/sets/72157616560355458/
http://www.flickr.com/photos/14288700@N02/3427702246/
A lot has changed since then with inevitable module purchases etc.. At that stage I was running the whole system on +/-12v.
Cynthia
Last Visit: 18 Apr 2013
PostPosted: Mon Feb 06, 2012 10:27 pm    Post subject: Reply with quote Add User to Ignore List
We have a new Zeroscillator, ZO Engine Board design coming out in a about three-weeks that is a single surface mount PCB instead of the former block of four circuit boards. This allows mounting in much more shallow cabinets. The whole depth of the module is now around 2.5 inches!
As far as top and bottom clearance of the Front Panel Assembly with it's own pair of circuit boards, maybe I can narrow the vertical height of the FPA with this in mind? I'll have a look, I know it as a tight fit before.
We still have several of the large FPAs for Frac ZOs already assembled here waiting for these new engines to arrive so we can dock and ship.
One of the things that makes the ZO special is that the tuning and exponential converter are not tied directly to the power rails, instead they're fed by a precision Voltage Reference so once calibrated, they will work just fine regardless of 12V or 15V power supplies smile
http://www.cyndustries.com/modules_zero-osc.cfm?type=37
solitaryzen
PostPosted: Tue Feb 07, 2012 12:08 am    Post subject: Reply with quote Add User to Ignore List
Thanks for that info. If you could improve the top & bottom clearance, that would be great, as mine was so tight I couldn't get the bottom screws in properly! If the tracking is improved with the new version, I might just consider getting a second ZO if finances allow down the track Dead Banana Would be nice to have one in my portable case.
noisefor
PostPosted: Tue Feb 07, 2012 2:28 pm    Post subject: Reply with quote Add User to Ignore List
I used an Audiopile 12U case to run both systems in one. The Audiopile stuff is solid and affordable. I mounted 9U Blacet Frac rails/power in combo with a 3U TipTop Happy Ending kit that has its own discreet power source w/wall wart.
The cases are a minimum 10" deep with two lids for access (disadvantage to dual setup is Frac mods tend have PCB's mounted in series and can be as much as 6" deep so you have to accommodate for depth unlike Euro which are generally parallell mounted to face plates).
You can easily DIY something like a TipTop zeus 1200ma powered board for the Euro stuff with the Zrails and ears (which are all mountable on standard rack equip.) if you don't want to use up the 6hp for the TipTop power switch, for example.
The Audiopile cases are a great bang for the buck if not a little bulky and heavy with both lids on - good if you play out with a dual rig as I do. Interior is plywood so you can easily mount stuff too. Both sides have rack rail but you can lighten overall weight by removing rear rails.
http://audiopile.net/products/Cases/RUE_Roadracks/RUE_Case_products_pa ge.shtml
Picture of rig (which has changed a bit...):
Picture file
Tubeampguy
PostPosted: Sun Jul 08, 2012 12:49 am    Post subject: Reply with quote Add User to Ignore List
Thanks for posting these pictures! That's exactly what I was envisioning! applause
reignbear
PostPosted: Sun Jul 08, 2012 8:22 pm    Post subject: Reply with quote Add User to Ignore List
is the tyme sefari still running fine under 15v?
giorgio
NITE MIND
PostPosted: Sun Jul 08, 2012 8:28 pm    Post subject: Reply with quote Add User to Ignore List
maybe randall can help? (hides)
FS in NYC: http://www.muffwiggler.com/forum/viewtopic.php?p=1160656
ddoyen
PostPosted: Tue Jul 10, 2012 4:24 pm    Post subject: Reply with quote Add User to Ignore List
how about getting a paia or blacet rack, and something like a tiptop happy ending..or whatever combination of frac and euro you have in mind and stack and mount em up in a nice wooden box?
i'm thinking that's what I'm leaning towards..(unless I'm missing something and it's a bad idea??)
I got my 9700 together and want to get some of the newer paia modules and some blacet stuff eventually but I think I wanna get a rack of make noise stuff together..shit is just soooo damn cool.
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Fractional Rack Modules All times are GMT - 5 Hours
