| View previous topic :: View next topic |
| Author |
E.A.S. "miss10" HADSR PCB [SOLD OUT] |
raisinbag Super Deluxe Wiggler
Posted: Fri Feb 10, 2012 8:17 am Post subject: |
| snow (or not so snowy right now) white north "Canada". I can grab a 4007 near me, so I will try that when it comes time, thanks. |
| Back to top |
E.A.S. Wiggling with Experience
  Posts: 430 Location: Brooklyn, NY
Posted: Fri Feb 17, 2012 12:39 pm Post subject: |
Just a quick update:
After making adjustment to the pcb and checking over it all several times we have finally placed the order with the PCB house for both the HADSR and the noise-lfo-s/h boards!
The boards should be arriving here in a little under 2 weeks and will be shipped out to you guys shortly after!
Thanks for your patience and support!
-Mike |
| Back to top |
Posted: Mon Mar 05, 2012 3:30 pm Post subject: |
First post updated.
These are in stock and will be shipping to those who have already paid shortly!
I will keep these in stock for anyone to order.
When I start running low I will update the first post. Otherwise these are available.
Thanks all!
-Mike
Miss 10 HADSR by itsfatmike, on Flickr |
| Back to top |
emdot_ambient Super Deluxe Wiggler
   Posts: 2378 Location: Frederick, Maryland USA
| Back to top |
negativspace Manhattan Analog
   Posts: 3739 Location: Manhattan, KS
| Back to top |
aladan Desperately Seeking Sondra
 Posts: 234 Location: Australia
Posted: Mon Mar 05, 2012 5:56 pm Post subject: |
1 x ordered & paid  |
| Back to top |
Posted: Fri Mar 09, 2012 3:37 pm Post subject: |
UPDATE:
Clean your work benh and heat up those soldering irons!!
All Paid PCB orders have been shipped!!
-Mike
p.s. I ordered extras this time, so if you feel 'left out', its not to late to join the solder party!  |
| Back to top |
Posted: Thu Mar 22, 2012 3:48 pm Post subject: |
First post updated with some wiring info!
-Mike |
| Back to top |
| Back to top |
demian Wiggling with Experience
  Posts: 278 Location: da Lowlands
Posted: Wed May 09, 2012 5:12 pm Post subject: |
I want 1.  _________________ WTB: Any cool DIY PCB (+euro rackpanel) |
| Back to top |
| Back to top |
brother303 Wiggling with Experience
   Posts: 364 Location: Ruhr-Area/Germany
Posted: Wed Jul 11, 2012 7:24 am Post subject: |
Hi,
is it possible to use a CD4007 instead of a MC14007? Datasheets look similar.
Can somebody confirm this?
Greg _________________
| Peake wrote: | | DIY is all about the backlog. If you don't have a huge backlog, you aren't trying hard enough. |
| Back to top |
| Back to top |
Dego Veteran Wiggler
    Posts: 653 Location: Sweden
Posted: Wed Aug 22, 2012 2:14 pm Post subject: |
| Any changes for 12 volt? |
| Back to top |
| Back to top |
Posted: Thu Sep 13, 2012 8:30 pm Post subject: |
| brother303 wrote: | Hi,
Greg |
Can anyone confirm that 4069 and 4007 works instead of 14069 and 14007? I am making an order and would can order the "14" versions but rather wouldn't if I can use the CD version as I have some in hand.
Cheers |
| Back to top |
ringstone antipodean experimentalist
   Posts: 2691 Location: Trudging through the Capital Wasteland
Posted: Thu Sep 13, 2012 8:42 pm Post subject: |
| raisinbag wrote: | | brother303 wrote: | Hi,
Greg |
Cheers |
I used CD4069 ok, used MC14007 though. Actually I will try and do a write up of how I wired this and how to switch between long/short envelopes soon, I've just got to get around to doing the LED indicator.
Blair _________________ Ecclesiastical Scaffolding Facebook
Mindless Eye * Soundcloud
some noise |
| Back to top |
Posted: Thu Sep 13, 2012 8:45 pm Post subject: |
Ok Ill grab the 14007 then just to be sure.
I would love to see how you did it. And ya if you figure out an LED do let us know, that would be a welcome add on. |
| Back to top |
Posted: Fri Sep 14, 2012 1:26 am Post subject: |
First I tried ken stones led driver but did not get that to work then I used this from Foniks schematic:
http://electro-music.com/forum/phpbb-files/woollastonadsr_147.gif
And it worked great as a LED driver. I used it directly to the output after discussing that with negativespace. He recommended using a high insensitive LED. Works good.
To mount the electrolytes I put two legs in the same hole for the chosen two electrolytes. Then I leave one leg without soldering it to the pcb on one of the electrolytes. The other electrolyte is mounted as usual. Then I solder the legs of the two electrolytes to the switch and after that I solder the leg of the second electrolyte that is not attached to the pcb with its leg to the switch.
I have built two of them  |
| Back to top |
Posted: Fri Sep 14, 2012 1:41 am Post subject: |
Thanks, I was actually going to try Ken's circuit - I'm surprised it didn't work here. The circuit you posted is pretty similar to how I've done it before so I'll go with that.
Blair
EDIT: And the cap to switch for envelope length is C35 (6.8uF) - I'm using tantalums as per the original and switching between 2.2uF (short) and 10uF (long). _________________ Ecclesiastical Scaffolding Facebook
some noise |
| Back to top |
