| View previous topic :: View next topic |
| Author |
2012 SDIY GLOAT THREAD |
sonicwarrior Super Deluxe Wiggler
   Posts: 1454 Location: Cologne, Germany
Posted: Thu Jun 07, 2012 5:30 am Post subject: |
I have nothing fancy, just a MFOS Dual VCA with a frontpanel from Bridechamber (the CV2 and audio inputs are normalled):
edit:
The first day I was able to finish two modules. Here is a 4ms SCM built from a kit:
 _________________ Soundcloud
For sale: V/Oct to Hz/V converter PCB
WTB: Dr. Octature |
| Back to top |
corex scare the dog!
  Posts: 577 Location: vegas
Posted: Thu Jun 07, 2012 5:34 pm Post subject: |
| photon wrote: | | First module of a new suitcase I've been planning a while, a 6 stage CGS Programmer/Seq. |
What are those buttons you're using? They look like tiny arcade buttons. Can you share a part #? Thanks! |
| Back to top |
photon Common Wiggler
    Posts: 90 Location: Boston
Posted: Thu Jun 07, 2012 7:09 pm Post subject: |
Thanks everyone.
The pushbuttons are from Mouser: 10PA005 for the red ones. They also come in black and white.
If you use them in the prog/ seq be aware they interfere somewhat with one of the buss wires that run thru all the boards. Some teflon tubing will keep it from shorting. |
| Back to top |
frozenkore Ultra Wiggler
   Posts: 969 Location: Schererville, IN
Posted: Fri Jun 08, 2012 11:01 am Post subject: |
Finally! Definitely learned a few things on this guy. Such as, don't give yourself such a tight space to work in. Don't make mounting a PCB harder than it needs to be. Lastly, test everything before you mount it! Luckily I figured out that last one before I assembled the second half!
 _________________ Cheers!
Brian |
| Back to top |
fonik Super Deluxe Wiggler
    Posts: 2286 Location: Germany
| Back to top |
sduck WTF?
    Posts: 4466 Location: Vortepexaion, TN, USA
Posted: Sat Jun 09, 2012 12:19 pm Post subject: |
Ok, here's one that wasn't in my backlog but I fixed Dude's version of this for him and then he sent me a pcb in thanks and I already had most of the parts on hand and the panel basically designed itself and before you know it there it is.
Another beautiful and cheap roof flashing bracket. This was also an experiment of sorts - I've been looking for a cheapo panel to try FPE's powdercoat process with, and this is it. It looks and feels really nice, and seems a lot more durable than the usual anodized panels. And it's REALLY black. I'm not sure it's worth the extra 15.50$ they tacked onto the price - that didn't show up in the design program.
CGS Quad Gates front by sduck409, on Flickr
CGS Quad Gates profile by sduck409, on Flickr
CGS Quad Gates back by sduck409, on Flickr _________________ What they do is this: They leak current in proportion to the frequency of the signal. The ramifications of this can only be truly appreciated when solving nodal current balances in the Laplace domain, unfortunately.
flickr cloud of sound touyube |
| Back to top |
Cat-A-Tonic Lobsters love Muff
     Posts: 2652 Location: Yokohama, Japan
Posted: Sat Jun 09, 2012 11:17 pm Post subject: |
Blacet I/O
with hand-stamped 1FU panel,
and Frac-ear mounted short-bat switches for the TR 1/4" input settings.
AC/DC
470k/100k Impedance
Tip +5V
Ring +5V
Tip - Signal
Ring - Signal
 _________________ http://soundcloud.com/decay-generator
| stk wrote: |
We "deserve" exactly what we get, if we leave it up to somebody else to determine our destiny.
| Back to top |
SepticUnderground Zombi Wiggler
   Posts: 1015 Location: Netherlands
| Back to top |
iopop Ultra Wiggler
   Posts: 932 Location: Malmö, Sweden
Posted: Sun Jun 10, 2012 5:48 am Post subject: |
So far this weekend,
YuSynth Pulse delay
cgs Sub Osc
YuSYnth Comparators
Feels quite good to have the sub osc assembled, its around 4 years ago I ordered that pcb! One of the first ones that I ordered from Ken. Back then I had my goal set on making a euro sized banana - didn't turn out that way.
Yesterday I had this one up and running,
| Back to top |
falafelbiels still learning to wiggle
   Posts: 2686 Location: Rotterdamm son
Posted: Sun Jun 10, 2012 5:53 am Post subject: |
iopop
Are you in a hurry? With the nice work and all... |
| Back to top |
sduck WTF?
Posted: Sun Jun 10, 2012 9:42 am Post subject: |
| SepticUnderground wrote: |
Looks very fresh, are those characters now more "on" than "in" the panel? |
The process they use is: makebasic rectangular panel, then powdercoat that, then drill and engrave, then infill the engraving as needed. So it still looks about the same as usual. _________________ What they do is this: They leak current in proportion to the frequency of the signal. The ramifications of this can only be truly appreciated when solving nodal current balances in the Laplace domain, unfortunately.
| Back to top |
hank Common Wiggler
 Posts: 211 Location: San Francisco, CA
Posted: Sun Jun 10, 2012 3:15 pm Post subject: |
Finally got around to doing the panel wiring on my CVP - had the PCB stuffed and ready to go for a month at least. Yay! |
| Back to top |
iopop Ultra Wiggler
Posted: Sun Jun 10, 2012 3:30 pm Post subject: |
| falafelbiels: Thanx, no hurry, have no deadline, but I figure since it feels like I wait on parts most of the time, I better finish things up when possible. |
| Back to top |
| Back to top |
LoFi Junglist Wired for sound
  Posts: 1084 Location: Adelaide, Australia.
Posted: Mon Jun 11, 2012 12:58 am Post subject: |
Not the most exciting DIY, but still
| Back to top |
| Back to top |
Posted: Mon Jun 11, 2012 1:50 am Post subject: |
The regulators (LM2575 & 7805) are all rated at 1 amp, but the Polycaps limit +/- 12v to 500mA each and the 5v rail is limited to 200mA. (I'm only doing the Regulation & Soak tests at 450mA/150mA)
These boards will end up in two ABS Camera cases for some portable fun. |
| Back to top |
Tombola Ultra Wiggler
  Posts: 906 Location: London, England
Posted: Mon Jun 11, 2012 2:28 am Post subject: |
Where are those PSU boards from? They look great, do they run off a AC / AC adaptor? _________________ http://musicthing.co.uk/modular/ |
| Back to top |
Posted: Mon Jun 11, 2012 2:37 am Post subject: |
They run off 9-15v DC.
I'm putting together Kits atm, but the documentation is taking ages. There will be something in th DIY forums next week  |
| Back to top |
kindredlost Super Deluxe Wiggler
Posted: Mon Jun 11, 2012 12:41 pm Post subject: |
Maybe a yawner for some here but it was a pretty difficult logic puzzle for me. Of course it still has bugs but that is going to be fun to tidy up.
Dual LFO / Analog Shift Register (x2) in a 3 space MOTM 5U.
Ken Stone's Utility LFO is the dual LFO here. Nice module in itself. The ASR's use the square out from each channel of the LFO for their master clocks until a break-in jack for external clock.
There are some goodies involved here. Mute switches for each register stage and a Loop and Series function. The LFO has a Hi/Lo speed range boost.
The Loop function has some problems. It submits the last register voltage over the first one right now. Hmm...
The Series works well. It forces the clock from A to B to keep timing across all six stages.
The logic puzzle was how to get both Loop and Series to work and all the variations of each on and off. Two 4PDT switches were used. Hopefully I can get it all perfected soon.
Here are a couple of videos. I'm unable to post pics to this thread right now but there are a couple of snapshots in the "demo" vid.
DEMO first...
"First sound"...
_________________ OpenTape
noises4sale
soundcloud
videos |
| Back to top |
