Mutable Instruments - Shruthi-1
Goto page Previous  1, 2 [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Author Mutable Instruments - Shruthi-1
GrobbingThistle
Last Visit: 25 Mar 2013
PostPosted: Sat Jan 14, 2012 12:31 pm    Post subject: Reply with quote Add User to Ignore List
I've seen the CV outs mentioned before but I haven't seen it made coear what exactly they can do. Can it output sequences or work as a primitive midi-cv or what?
smrl
Last Visit: 20 May 2013
PostPosted: Sun Jan 15, 2012 6:09 pm    Post subject: Reply with quote Add User to Ignore List
Yeah, you can assign it to anything in the modulation matrix.
The list:
lfo1, lfo2: LFO output (centered).
stpseq: Step sequencer output.
stpsq1: Step sequencer’s little brother 1: it cycles on the first 8 steps of the sequence.
stpsq2: Step sequencer’s little brother 2: it cycles on the last 8 steps of the sequence.
arp: Rhythmic gate signal, which outputs a high value when the arpeggiator or sequencer contains a note at the current step, or 0 when there is no note.
mwheel: Modulation wheel value read from the MIDI input.
afttch: Aftertouch value read from the MIDI input.
bender: Pitch-bend controller value read from the MIDI input (centered).
offset: A boring constant value. This is useful if you want to output a fixed value to one of the CV outs.
cv1, cv2, cv3, cv4: Control voltages read from the CV input pins. By default, the input pins are floating, so it’s likely that these modulation sources will sound just like noise.
cc A, cc B, cc C, cc D: Value of the Control Change 16, 17, 18 and 19.
noise: Another noise generator! Mapped to the VCA, makes for some super snares!
env1, env2: Envelopes.
velo: Note velocity.
random: A random value updated every time a new note is played.
note: Pitch of the currently played note (centered).
gate: Keyboard gate signal, null when no key is currently pressed.
audio: Digital audio signal produced by the mixer. Please note that since the modulation matrix is recomputed at 976Hz, some serious aliasing is happening here. You’re not going to do FM with this thing, most of the time it sounds like crap, but it’s something fun to experiment with!
op. 1: Operator 1.
op. 2: Operator 2.
"operators" allow you to combine 2 mod. sources with a mathematical operator.
It's great. And I managed to fit 6 1/8" jacks & protection diodes in the standard plexi enclosure. Just.
smrl
PostPosted: Sun Jan 15, 2012 6:14 pm    Post subject: Reply with quote Add User to Ignore List
Regarding using it as a MIDI-CV with 1v/oct note out, if that's what you are curious about - you'd have to shift it with an operator connected to an offset, and then it would still be linear, 0-5v. Gate output would be straightforward, but you'd need an exponential convertor if you wanted to say have oscillators track its pitch properly.
GrobbingThistle
PostPosted: Mon Jan 16, 2012 2:47 pm    Post subject: Reply with quote Add User to Ignore List
Great, that was very detailed and gives me a lot of ideas. I guess I'll still need a midi-cv converter, but it looks like my 2012 performance rig is really coming together (Machinedrum UW, Shruthi-1, modular). I'm excited about how well it seems everthing is going to interface!
krz
PostPosted: Mon Jan 16, 2012 4:47 pm    Post subject: Reply with quote Add User to Ignore List
[quote="GrobbingThistle"]I've seen the CV outs mentioned before but I haven't seen it made coear what exactly they can do. Can it output sequences or work as a primitive midi-cv or what?[/quote]
there is plenty to search for about these cv inputs aka "hack me" inputs @ http://www.mutable-instruments/forum Kenny McCormick
GrobbingThistle
PostPosted: Fri Feb 03, 2012 3:43 pm    Post subject: Reply with quote Add User to Ignore List
So, I'm finally working my way around this thing. Got this running at the exact same time as I got a Machinedrum and an Oberheim Matrix-6 so I've been up to my eyeballs in menus and submenus and user manuals. Is there a way to share patches with the Shruthi-1? Anyone have any that they would like to share? I could use some ideas. I actually really hate working backwards from the presets -- I wish there was a way to wipe them all.
obscurerobot
Turing Tested
PostPosted: Fri Feb 03, 2012 3:58 pm    Post subject: Reply with quote Add User to Ignore List
You can Sysex load/dump the patches. There's a patch sharing thread over at the Mutable forum.
neilbaldwin
PostPosted: Fri Feb 03, 2012 4:32 pm    Post subject: Reply with quote Add User to Ignore List
Shhhhhsh! Stop talking about the good stuff. My kit is still sat in the drawer waiting to be built but I just don't have the time right now.
Really looking forward to building it though applause
http://marmotaudio.co.uk
http://soundcloud.com/neilbaldwin
http://nes-audio.com
GrobbingThistle
PostPosted: Fri Feb 03, 2012 6:12 pm    Post subject: Reply with quote Add User to Ignore List
It's fun! I set aside an entire day, woke up a little after noon, soldered through a terrible hangover and was wiggling by 8 PM. Very gratifying and extremely well documented.
Oh, and thanks Obscurerobot!
gwaidan
PostPosted: Sun Feb 05, 2012 10:51 pm    Post subject: Reply with quote Add User to Ignore List
Did mine on Saturday-the smoothest, best documented build I've ever done and worked first time. Even flashing it via MIDI to V0.95 (for the nice bitcrusher) was totally painless. Looking forward to a lot of feature exploration this week!
Total contrast to the Quadslope build which I spent a fair bit of January painstakingly handwiring, and then proceeded to fry on powerup last Friday. Dead Banana
lordofthebored wrote:
Any news on this yet? I just sold all my other modules of this type so I could replace it with this different implementation of the same thing!
carynrich
PostPosted: Wed Mar 07, 2012 12:10 am    Post subject: Reply with quote Add User to Ignore List
well, i finally finished the XT kit in about 2 months as it wasn't the easiest thing to build (had a short on the control board, a lot of trouble shooting). i ended up putting three filters in the box, an SMR-4, IR3109 and CEM3379. as expected, both the roland and CEM filters sound pretty good applause
just a word of caution though, you can't use the SVF board with the XT controller as the SVF needs the digital expansion port (i'm not really sure what that means seriously, i just don't get it but it doesn't work - i found out the hard way)
the extra knobs make a world of difference, one of the main reasons why i don't use my Mopho as much.
here's some pics. white davies clones, black/white display, and orange/red LEDs. i'll swap out the black buttons with white ones soon, although i can't seem to find a white rubber knob anywhere.
obscurerobot
Turing Tested
PostPosted: Wed Mar 07, 2012 12:19 am    Post subject: Reply with quote Add User to Ignore List
You should check with the mutable forum to be sure, but I think what is happening is this: The extra knobs are multiplexed over the digital control bus. That bus was intended to be used to control things like the SVF, but it is being used for extra knobs instead.
gwaidan
PostPosted: Wed Mar 07, 2012 1:19 am    Post subject: Reply with quote Add User to Ignore List
You can use the SVF in tandem with the programmer provided you have mechanical switches hooked up where the switch ICs would be on the SVF board so you can control the modes manually. There are markings on the PC board to help you do this.
phonodyne
Last Visit: 05 May 2013
PostPosted: Tue Apr 17, 2012 7:11 am    Post subject: Reply with quote Add User to Ignore List
The new Shruthi-1 4-Pole Mission Edition looks a bit tasty:
http://createdigitalmusic.com/2012/04/open-shruthi-1-synth-evolves-dee p-sound-capabilities-new-4-pole-filter-ice-white-case/
I see they've stopped providing some of the more commonly available parts in the kit (there's now a saved shopping basket at Mouser or Reichelt for those), but they are supplying that rather lovely plexiglass case. I'm not familiar with the filter but it certainly seems versatile. Think this is going to be my first synth build once the kits are available.
krz
PostPosted: Wed Apr 18, 2012 7:05 am    Post subject: Reply with quote Add User to Ignore List
Mission. Sold out. Midipal. Sold out. Sidekick. Sold out. Got a CEM3379
Shruthi thank goodness. Kits are well
done. This co. needs to get a handle on
stocking kits cuz almost everytime I go there it's sold out. Ya gotta watch the forum like a crack addict to get in on most
things. The other drag is the dollar to Euro
exchange but that's an old hurdle. Otherwise roll your own wavetables is
great and the x/or mod possibilities are
endless... almost. ;)
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 2 of 2
