VBrazil Systems - Aether System One
Goto page Previous  1, 2, 3, 4  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Modular Synth General Discussion
Author VBrazil Systems - Aether System One
pointsource
is banned
is banned
Last Visit: 30 May 2012
PostPosted: Fri Feb 17, 2012 8:09 pm    Post subject: Reply with quote Add User to Ignore List
One more demo, this time featuring the MultiPhaser module.
Note that it's a continuous note being fed into the input of the MultiPhaser, all the crazy modulations going on are made by this module.
Aether Oscillator into MultiPhaser:
[s]http://soundcloud.com/point-source/multiphaser-by-vbrazil-system[/s  ]
Guitar into MultiPhaser:
[s]http://soundcloud.com/point-source/guitar-into-multiphaser[/s]
Pads into MultiPhaser (first dry, then wet):
[s]http://soundcloud.com/point-source/pads-into-multiphaser[/s]
pointsource
is banned
is banned
PostPosted: Sun Feb 19, 2012 2:17 pm    Post subject: Reply with quote Add User to Ignore List
Hey guys! I just got an email from Vinicius regarding the "hybrid" factor. Someone asked how his oscillators works, and a lot of people, when read the word "hybrid vco" or whatever, thinks that the sound is digitaly generated. This is not the case. (I'm gonna try my best to translate this, maybe this will make sense to electronic engineers and stuff, cause I don't understand jargons):
"All the modules are made using 100% discrete parts, with the exception of the Multi LFO's (2 lfos are 100% analog, 1 is hybrid), LIZARD (all 8 LFO's are 100% analog, the VCO is hybrid) and the Aether Oscillators. The S&H and Quantizer also uses digital parts, it's the only way to do it.
The Aether Oscillator is a extremely powerful hybrid VCO, it generates 6 simultaneous waveforms: SINE / SAW / TRIANGLE / PULSE / SUB1 / SUB2.
The SUB1 outputs a square wave 1 octave below the one being played, and the SUB2 2 octaves.
Each OSC has it's own dedicated LFO, wich generates 8 selectable waveforms: PositiveSaw / NegativeSaw / Sine / Triangle / Square / Stepped PositiveSaw / Stepped NegativeSaw / Stepped Triangle.
CV inputs are standard 0 - 10 volts / 1volt per octave
Aether Oscillator is a hybrid VCO.
Two major issues with 100% 1v/octave analog VCOs are the tuning instability and linearity. And those issues are not generated by the oscillator. They are generate by the linear/exponencial converter, basically made by a pair of transistors, using the exponencial transfer attribute of the ("base-emitter junction"???), wich is extremely temperature dependent. A lot of artifices are used to compensate this dependency. To avoid those deficiencies, the exponencial/linear conversor and time base of the Aether Oscillators are digital, but ALL the waveforms are analog generated.
The core of the oscillatores generates a protosaw, and from it, SAW and TRIANGLE are analog generated. The SINE wave is analog generated from the TRIANGLE.
Most of the modern synths have a frequency sample rate between 44.1kHz or 48kHz, and a few goes up to 96KHz.
For the real "analog experience", the real sample rate of the DSP (exponential/linear and time base core) is 500KHz!! 10 times more!!
As the dedicated LFO operates in the same manner, it's also digitaly implemented, allowing the generation of it's 8 waveforms."
I hope that elucidates the "hybrid" part...
pointsource
is banned
is banned
PostPosted: Sun Feb 19, 2012 4:54 pm    Post subject: Reply with quote Add User to Ignore List
Two very disturbed oscillators:
[s]http://soundcloud.com/point-source/two-disturbed-oscillators[/s]
smetak
Last Visit: 18 May 2013
PostPosted: Sun Feb 19, 2012 7:18 pm    Post subject: Reply with quote Add User to Ignore List
Señor PointSource,
Sexta que vem vou baixar lá e checar isso tudo pessoalmente - ao vivo e a cores.
até, w.
http://soundcloud.com/wsmetak
pointsource
is banned
is banned
PostPosted: Mon Feb 20, 2012 6:52 am    Post subject: Reply with quote Add User to Ignore List
smetak wrote:
Señor PointSource,
até, w.
Irado!!! O meu, leva uma câmera e faz um vídeo pra gente postar aqui!!!!
All the best!!
pointsource
is banned
is banned
PostPosted: Mon Feb 20, 2012 7:16 am    Post subject: Reply with quote Add User to Ignore List
Now presenting some LIZARD demos!!!!! Rockin' Banana! It's motherfucking bacon yo Rockin' Banana!
1st demo:
[s]http://soundcloud.com/point-source/lizard-seq-mode-level[/s]
1st segment:
LIZARD module in SEQUENCER + LEVEL mode (8 steps) modulating only one Aether Oscillator (via CV input) outputing a triangle wave.
2nd segment:
LIZARD module in SEQUENCER + LEVEL mode, but this time modulating the oscillator thru it's FM input. MIDI2CV output into OSC CV input, thus LIZARD is working as arpeggiator!!
2nd demo:
[s]http://soundcloud.com/point-source/lizard-seq-mode-lfos[/s]
LIZARD on SEQUENCER (8 steps) + LFO mode =Lizard's master output going into the CV input of only one Aether Oscillator, with some random knob adjustments.
1st segment: TRIANGLE wave
2nd segment: PULSE wave
3rd demo:
[s]http://soundcloud.com/point-source/lizard-vco-mode-wave[/s]
The true power of the LIZARD!
VCO mode + WAVE!!
1st segment:
SINE wave ouput of Aether Oscillator fed into WAVE1 input of Lizard, with some manual freq knob adustments. Lots of crazy timbres.
2nd segment:
Two more Aether Oscillators are fed into WAVE2 and WAVE3 inputs, also SINE waves.
Can you imagine using PULSE and SAW waves????
Download is enabled for the mp3 files.
smetak
PostPosted: Mon Feb 20, 2012 5:28 pm    Post subject: Reply with quote Add User to Ignore List
Tentar-lo-ei.
cheers, w.
(Did you receive my PMs? Did you get my e-mail? Drop me a line, B.!)
pointsource
is banned
is banned
PostPosted: Fri Feb 24, 2012 11:28 am    Post subject: Reply with quote Add User to Ignore List
LOW PASS FILTER DEMOS: w00t
Aether Oscillator fed into LPF, with some freq and ressonance knob tweaking. This example showcase a bit of the ADSR generator as well.
[s]http://soundcloud.com/point-source/low-pass-filter-by-vbrazil[/s]
Self Oscillating LPF, ressonance at maximum, generating a pure sine wave.
[s]http://soundcloud.com/point-source/self-oscillating-lpf[/s]
Subtle difference between the 12 - 18 and 24 db outputs:
[s]http://soundcloud.com/point-source/low-pass-12db-18db-24db[/s]
Lizard modulating the LPF cutoff and Aether OSC:
[s]http://soundcloud.com/point-source/lpf-lizard[/s]
Some percussive sounds:
[s]http://soundcloud.com/point-source/lpf-24db-perc[/s]
[s]http://soundcloud.com/point-source/lpf-24db-perc-2[/s]
pointsource
is banned
is banned
PostPosted: Fri Feb 24, 2012 6:47 pm    Post subject: Reply with quote Add User to Ignore List
Aether OSC being fed into LIZARD's WAVE 1 & 2 inputs, then into LPF:
[s]http://soundcloud.com/point-source/aether-osc-lizard-lpf[/s]
pointsource
is banned
is banned
PostPosted: Sat Feb 25, 2012 9:39 am    Post subject: Reply with quote Add User to Ignore List
STATE VARIABLE FILTER nanners
Aether pulse output into BP filter, ADRS into CV1 and LIZARD LFO into CV2:
[s]http://soundcloud.com/point-source/statevariablevcf-2[/s]
Aether pulse output into State VCF, first HP, second LP and then BP.
Some ressonance tweaking.
[s]http://soundcloud.com/point-source/statevariablevcf[/s]
pointsource
is banned
is banned
PostPosted: Sun Feb 26, 2012 5:20 am    Post subject: Reply with quote Add User to Ignore List
BAND PASS FILTER OUTPUT:
[s]http://soundcloud.com/point-source/statevariablevcf-band-pass[/s]
pointsource
is banned
is banned
PostPosted: Sun Feb 26, 2012 7:04 pm    Post subject: Reply with quote Add User to Ignore List
MORE STATE VARIABLE FILTER:
[s]http://soundcloud.com/point-source/statevariablevcf-3[/s]
Aether Pulse output into State Variable VCF.
1st : LPF + ADSR + LFO
2nd: LPF's cutoff being sweeped by LFO
3rd: BPF's cutoff being sweeped by LFO
4th: HPF's cutoff being sweeped by LFO
5th: BPF + ADSR + PWM modulated by LFO
pointsource
is banned
is banned
PostPosted: Tue Feb 28, 2012 6:53 pm    Post subject: Reply with quote Add User to Ignore List
RING MODULATOR: hyper
[s]http://soundcloud.com/point-source/ring-modulator[/s]
1st segment:
Two Aether OSC outputing triangle waves into ring modulator. Random notes played in the keyboard, with some OSC freq knob tweaking.
2nd segment:
Aether oscillators being modulated by their own LFO's and fed into Ring Modulator
lightworks
Last Visit: 25 May 2013
PostPosted: Tue Feb 28, 2012 9:21 pm    Post subject: Reply with quote Add User to Ignore List
Muito bom!
O Lizard parece ser incrivel!
Parabéns malta!
smetak
PostPosted: Mon Mar 05, 2012 7:26 am    Post subject: Reply with quote Add User to Ignore List
Grato pelo elogio - agora é rezar para o Vinicius terminar isso tudo o quanto antes.
O Lizard é paulada - é uma espécie de "sequeciador" (apesar de, no fundo, não ser um; tanto assim, que há um sequenciador de 32 steps em separado) que faz variações contínuas em cada sequência. É, realmente, muito interessante - criação única do Vinicius.
Agora, é rezar para que eu e o "pointsource" meta logo as mãos nisso - a espera está nos matando!
lombrose
PostPosted: Thu Mar 22, 2012 10:34 pm    Post subject: Reply with quote Add User to Ignore List
Soooooo, is there a video already? hmmm.....
Have been talking with Vinicius and can´t wait to put my hands on one of his osc.
I asked him about the hybrid thing with the osc and he told me that the sound generated by the aether one doesn`t pass through digital path. the digital part is just to control the tune stability.
He told me that the aether osc will track 10 octaves with no noticeable drift. SlayerBadger!
And to make me more anxious, sent me today pdf manuals for the monsterdrone, Lizard and Multi LFO. MY ASS IS BLEEDING
smetak
PostPosted: Fri Mar 23, 2012 7:28 am    Post subject: Reply with quote Add User to Ignore List
Hum....video...yes. No doubt, there will be a video.
Hopefully, we'll get a video together for Youtube, ect. soon. I'm planning to have a video shot with my system, which will contain a few modules from other manufacturers (Doepfer, Make Noise, Tip Top, ES, etc.) as comparison with what he's doing.
But the video might take a while. He's furiously working, adding the final touches, to PointSource's system - because this is the first one, its taking a tad longer than expected; it should be finished and ready to ship in about a week or two.
With this done, I believe it will be faster for all future orders and, who knows, a video sooner than later.
lombrose
PostPosted: Fri Mar 23, 2012 7:37 am    Post subject: Reply with quote Add User to Ignore List
Hummmm, hope he finish it soon, I´m about to pull the trigger on a osc, and like what he showed me, the problem is that the gas level is increasing, I´m trying to resist but it´s becoming harder, rs help
Search for Mrlombrose on youtube and you`ll see a couple videos I did with my little system. Guinness ftw!
smetak
PostPosted: Fri Mar 23, 2012 8:05 am    Post subject: Reply with quote Add User to Ignore List
I believe it won't take long for getting an oscillator from Vinicius - the PCBs are all up and ready, with the panels all nice and printed. The mounting is extremely quick, no big deal, just some screws and knobs and there, ready to go. I, myself, have been to his studio many times and have seen everything stacked and ready to for mounting.
Once Pointsource's system is completed, he'll probably be able to ship any of the several modules he has designed in very short time.
I'm to drop him a line, later in the day, and ask when he will be able to ship the modules.
I'll keep you posted on this. cheers, w.
lombrose
PostPosted: Fri Mar 23, 2012 8:18 am    Post subject: Reply with quote Add User to Ignore List
Guinness ftw!
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Modular Synth General Discussion All times are GMT - 5 Hours
Page 3 of 4
