Buchla format panels discussion
Goto page Previous  1, 2, 3 ... 11, 12, 13 ... 20, 21, 22  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY
Would you be interested?
yes
84%
 84%  [ 49 ]
no
15%
 15%  [ 9 ]
Total Votes : 58
Author Buchla format panels discussion
Rod Serling Fan Club
aquatic hitchhiker
Last Visit: 24 May 2013
PostPosted: Wed May 30, 2012 2:20 pm    Post subject: Reply with quote Add User to Ignore List
Julian, the zthee panel is different, smaller.
DIY panels and PCBs for Buchla and Euro format: http://synthpanels.blogspot.de/
youtube channel: http://www.youtube.com/user/MrPalebluedot
aquatic hitchhiker
PostPosted: Wed May 30, 2012 2:23 pm    Post subject: Reply with quote Add User to Ignore List
diophantine wrote:
Regarding the pulser, I have a PCB and could try to order the parts needed to build it up. I have an idea for getting the pulse width too.
That would be really helpful! If your PW mod worked out I'm sure people would be excited about that. I could always start working on the design and flesh it out later pending your findings.
Last edited by Rod Serling Fan Club on Wed May 30, 2012 3:30 pm; edited 1 time in total
julian
i like synthesisers...
Last Visit: 25 May 2013
PostPosted: Wed May 30, 2012 2:28 pm    Post subject: Reply with quote Add User to Ignore List
iopop wrote:
That Klee panel was desgined by Muff member jooks.
Thats exactly what i initially thought - thank you.
_________
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
julian
PostPosted: Wed May 30, 2012 2:37 pm    Post subject: Reply with quote Add User to Ignore List
Thank you.
I understand now. Its been confusing me for some time!
I have permission to cut the larger panel, should anyone want that one.
_________
diophantine
Last Visit: 14 May 2013
PostPosted: Wed May 30, 2012 3:08 pm    Post subject: Reply with quote Add User to Ignore List
That would be really helpful! If your PW mod worked out I'm sure peopel would be excited about that. I could always start wokring on the design and flesh it out later pending your findings.
Not a problem! I just put together the BOM & ordered the stuff from Mouser (needed to buy some stuff for the Synthasystem anyways...). I'm away on the weekend, but hopefully I can put it together and start testing things early next week.
aquatic hitchhiker
PostPosted: Thu May 31, 2012 9:22 pm    Post subject: Reply with quote Add User to Ignore List
On the 291 subject: I played with hole alignment with some real jacks tonight and 3 outputs would just be too close together. Arranging the holes in anything but a straight line looks odd and moving the print looks worse. So 2 holes it is.
diophantine
PostPosted: Sun Jun 10, 2012 12:36 pm    Post subject: Reply with quote Add User to Ignore List
I talked to RSFC about it last week, but now that I've done a bit more work on it I wanted to follow up with the group re: the 245.
I've just been playing around with the Easel Pulser PCB to see if I can get all the functionality of the Pulser section of the 245.
FIrst, there's a few things that I'm not certain about, but where I'm making a few assumptions:
- What is the 245 Pulser's "ref" output? I'm not really sure, from looking at the 245 schematic, but I'm thinking it is the oscillator output, in which case we could connect it to the Pulser PCB's saw output.
- Is the Pulser connected internally to the sequencer part? I don't think so, given that the 245's "Pulse Out" jack is right next to the sequencer's "Advance In" jack. The original schematics are separate too.
- Is the 245 Pulser's PW range truly from 0% (never on) to 100% (always on), as the panel would indicate? I hope so.
So, the functionality missing from the Easel pulser board was: Pulse Width (manual + VC), Start (manual + VC), and Stop (manual + VC).
I have these all working now - the PWM part I've bread-boarded, but simulating the stuff on the board that I'll be changing. I also haven't fully tested the VC aspect, but all of the switches & pots I'm adding just supply voltages, so it should work no problem. While there's no trace cutting involved, there's a number of part changes, jumpers, etc. that are necessary.
What I'd like to know is:
(1) Is there enough interest in building a 245?
(2) If so, are you willing to make these changes, or would you prefer some alternative?
Bear in mind that I haven't looked too much at the sequencer part of the 245: most of it looks straight-forward, but there are a few oddities.
While I have the changes in full in my notebook, they're a bit messy so I won't publish them yet, but I'll summarize what the changes involve:
Omitting 3 resistors.
Omitting 1 capacitor.
Replacing 4 resistors with links.
Replacing 1 capacitor with link.
Changing the value of 2 resistors.
Adding 2 resistors (there's suitable pads).
Adding 1 diode (you'll have to use a bit of creativity).
Adding 1 cross-board jumper.
Adding 2 resistors off-board (for panel components).
Adding 4 diodes off-board (for panel components).
And, finally, lifting 1-2 legs from one of the ICs (so they're no longer in the socket), and soldering them to connections.
Is it ugly? Yeah. Could it be worse? Yeah. smile
Let me know your thoughts!
demian
PostPosted: Sun Jun 10, 2012 4:21 pm    Post subject: Reply with quote Add User to Ignore List
I would be interested in at least 2x 245's. w00t
WTB: Any cool DIY PCB (+euro rackpanel)
303monkey
Last Visit: 23 May 2013
PostPosted: Sun Jun 10, 2012 5:04 pm    Post subject: Reply with quote Add User to Ignore List
Did anyone mention a 227 applause
Boba Fett
zoot horn rollo
Last Visit: 26 May 2013
PostPosted: Mon Jun 11, 2012 12:32 am    Post subject: Reply with quote Add User to Ignore List
That's:
(1) Yes! and
(2) Yes
from me.
Thanks!!
equalpyramid
PostPosted: Mon Jun 11, 2012 1:16 am    Post subject: Reply with quote Add User to Ignore List
Yeah, that pulser circuit seemed like a really cool module. Personally, I'd be more interested in a module incorporating a bunch of small Buchla modules (Easel or not). Or maybe doing a 140-ish module?
Also, anyone thinking of resurrecting the 257?
dar303
PostPosted: Mon Jun 11, 2012 4:25 am    Post subject: Reply with quote Add User to Ignore List
I have a 245 at work, I can check the pulsewith and ref outs.
The pulser and seq are separate.
I would be interested in a 245-like module for my own system!
diophantine
PostPosted: Mon Jun 11, 2012 10:28 am    Post subject: Reply with quote Add User to Ignore List
OK, sounds like there is interest here. I will continue pursuing this!
Bear in mind, panels are not up to me, nor are they in my domain. I'm just seeing if a 245 would be possible, circuit-wise!
3 things I forgot to mention:
- A gate-to-trigger converter will be pretty much be a necessity for the Start, unless you want the first cycle to be funny; I think that Ken Stone's design should be fine, and will test it.
- On start-up, the sequencer is running. I don't think this should be a big deal?
- I haven't played with the LEDs at all, which I believe were in the buttons of the original, and just indicated if it was running or not running. This seems like the least critical feature to me - I'm sure something can be figured out.
The 245 is not really that big, only 2 spaces wide. (The 246, however, was 5 spaces wide.)
The 140 would be hard to reproduce with the Easel Pulser - the modes are slightly different, plus the alternating outputs. (It is really crazy to me how the 140, the 245 pulser, and the Easel pulser are all fairly different, circuit-wise!)
I've been working on a PCB for this, but the 245 (and a couple of other things) are taking priority. Hope to get back to it soon.
Awesome, thanks! I may have some questions on the seq functionality, and will PM you once I get to that.
valis
aliens killed bigfoot
PostPosted: Mon Jun 11, 2012 11:29 am    Post subject: Reply with quote Add User to Ignore List
@ diophantine That is all really fantastic info. I have two of the Lanterman pcbs but haven't thought much about them. It is very interesting, like you pointed out, that Buchla has three different pulsar circuits. Thanks for all the research and reporting back.
PF
PostPosted: Tue Jun 12, 2012 10:38 am    Post subject: Reply with quote Add User to Ignore List
245, yes
If you donīt ask, you donīt get......
Musik
http://www.myspace.com/pouppeefabrikk/music
_______________________________________
Videos
http://www.youtube.com/user/ThePF412
Record Label
http://www.alfa-matrix.com
amnesia wrote:
So I am questioning if I need the Easel. But I bet I buy it being such a Buchla fanboy.
303monkey
PostPosted: Tue Jun 12, 2012 12:54 pm    Post subject: Reply with quote Add User to Ignore List
Boba Fett
I agree a 227 would be a good idea nanners
303monkey
PostPosted: Tue Jun 12, 2012 1:02 pm    Post subject: Reply with quote Add User to Ignore List
Or a 246
Boba Fett
djs
PostPosted: Sun Jul 08, 2012 12:21 pm    Post subject: Reply with quote Add User to Ignore List
not sure if this came up already, but how about a wogglebug panel? using the pcb from bridechamber? Might be an interesting complement to the 266.
"Noise is what the Earth is made of" - David Bowie
aquatic hitchhiker
PostPosted: Sun Jul 08, 2012 1:20 pm    Post subject: Reply with quote Add User to Ignore List
I did bring it up at one time. I think I could make a 265 looking panel for it if people were interested.
batchas
Switched on Buchla
PostPosted: Sun Jul 08, 2012 1:49 pm    Post subject: Reply with quote Add User to Ignore List
Before I can dream about new modules, I would really like to find the Mouser References for the 194 components!
I posted 3 times here: http://www.muffwiggler.com/forum/viewtopic.php?t=37298&postdays=0&post order=asc&highlight=194&start=280 to ask for help, but no reactions...
IMO it's a great idea you have to ask here about a wogglebug for the Buchla. I like the wogglebug too!
FS/FT: Monomachine SFX-60+ MKII +Drive $999 incl. shipment
FT: Eardill Slew + Pulse Balloons for your Morphun / Other trades here
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Music Tech DIY All times are GMT - 5 Hours
Page 12 of 22
