[SHIPPING] Euro Mixer/Addon PCB for RSFC's Buchla CVP Panel
Goto page 1, 2, 3, 4  Next [all]
Author [SHIPPING] Euro Mixer/Addon PCB for RSFC's Buchla CVP Panel
negativspace
Manhattan Analog
Last Visit: 21 May 2013
PostPosted: Fri Nov 23, 2012 11:27 am    Post subject: [SHIPPING] Euro Mixer/Addon PCB for RSFC's Buchla CVP Panel Reply with quote Add User to Ignore List
So... I've recently been tasked with building a couple of these for some fellow wigglers. The CVP is easy - I've built like 200 of them before - but it's designed for Euro and some of its features just don't make a lot of sense in the Buchla thanks to banana jacks. (Buffered multiple jack, 2 outputs?) So it seems like some modification is in order. First, one needs to mix the two inputs per channel. Second, the lower output per channel should really be inverted relative to the top output. All of this requires active circuitry, and that brings us to the point of this thread - I'm going to make a PCB to handle all of that.
The functions onboard are simple: 4 2-input mixers and 4 inverters. This will let you seamlessly complete the Buchla panel build as described above, but with some normalled jacks, pots and switches one can construct any number of useful utility modules in a standalone situation.
The circuitry is also simple - 3 TL074s and some resistors are all that we'll need. So the PCB is just about exactly the same size as the CVPs. The power footprint is the same too, either to facilitate bussing with the Buchla panel or to facilitate use in a standalone situation.
Here's my first stab at the layout... I need to doublecheck the inverters and reroute the power traces through the capacitors by the beads, but otherwise I think it's good. w00t
Analogue HavenCTRLEquinoxOZEFNFoxtone MusicPostModularSchneidersbüro
negativspace
Manhattan Analog
PostPosted: Fri Nov 23, 2012 11:28 am    Post subject: Reply with quote Add User to Ignore List
The boards have been ordered. I expect delivery sometime around 12/20 and will probably ship immediately after the Christmas postal break.
The PCBs are silk-screened and masked, and will be $18/ea. Shipping is $3 domestically or $5 internationally. The PayPal address for payment is jcoates42@gmail.com.
Order List (blue indicates paid, red indicates shipped)
negativspace [4]
303monkey [2]
RSFC [2]
pfurmel [1]
Junk Rhythm [2]
jooks [1]
fluxmonkey [1]
djs [1]
Votek_Mendo [1]
keninverse [1-2]
janvanvolt [2]
bsmith [1]
xerxl [2]
msprigings [1]
frozenkore [1]
djangosfire [2]
monokinetic [1]
rosch [2]
valis [1]
wavehead [1]
mattrick [2]
nangu [3]
303monkey
PostPosted: Fri Nov 23, 2012 11:49 am    Post subject: Reply with quote Add User to Ignore List
I would be up for two!!
Boba Fett
WTB: Digisound 80 modules & pcb's.
Haible FS-1A PCB's
ARP 2500 Matrix panels, panels etc
Rod Serling Fan Club
aquatic hitchhiker
PostPosted: Fri Nov 23, 2012 12:17 pm    Post subject: Reply with quote Add User to Ignore List
I need 1 or 2. If you have room, a dc mixer might be nice. I was planning on using the right bottom jacks as mixed output, just using a different color nanner jack differentiate from the "format jumbling" jacks.
DIY panels and PCBs for Buchla and Euro format: http://synthpanels.blogspot.de/
youtube channel: http://www.youtube.com/user/MrPalebluedot
negativspace
Manhattan Analog
PostPosted: Fri Nov 23, 2012 12:37 pm    Post subject: Reply with quote Add User to Ignore List
I'll see what I can do... another dual opamp shouldn't be too hard to squeeze in there. My initial idea is to keep the power connector in the same place so you can bus all 5 boards together, but if I have to widen it a bit to accommodate all of the ICs then so be it. Function over form. (Well, at least behind the panel!)
negativspace
Manhattan Analog
PostPosted: Fri Nov 23, 2012 12:39 pm    Post subject: Reply with quote Add User to Ignore List
You know, now that I think about it, why don't I just use standoffs and mount it to the bottom CVP board? Ha, ok, this just got even easier. hihi
Pfurmel
PostPosted: Fri Nov 23, 2012 12:57 pm    Post subject: Reply with quote Add User to Ignore List
I'm in for 1 fo sho
http://boxemissions.tumblr.com/
http://sioraigeimhreadh.bandcamp.com/
bf wrote:
Some fart in an office on the other side of the country who's hobbies include golf and passive-aggressive spousal abuse likely won't understand my obsession with unicorn penis.
Junk Rhythm
Big Bottom Shaker
PostPosted: Fri Nov 23, 2012 1:47 pm    Post subject: Reply with quote Add User to Ignore List
I'll take 2.
[toppobrillo] [twitter] [blog] [flickr] [audio]
valis
aliens killed bigfoot
PostPosted: Fri Nov 23, 2012 2:06 pm    Post subject: Reply with quote Add User to Ignore List
Would you need one daughterboard per Buchla-ish panel or one per CVP PCB?
jooks
PostPosted: Fri Nov 23, 2012 2:29 pm    Post subject: Reply with quote Add User to Ignore List
Wow! Im in for one!
diophantine
Last Visit: 14 May 2013
PostPosted: Fri Nov 23, 2012 3:02 pm    Post subject: Reply with quote Add User to Ignore List
Doh! 24 hours after I finished building mine. hihi I left mine w/the buffered copy of the input, and multed outputs - figured it would make it simpler for chaining some of these together.
negativspace
Manhattan Analog
PostPosted: Fri Nov 23, 2012 3:30 pm    Post subject: Reply with quote Add User to Ignore List
One per panel. Each daughterboard will give you 4 2-input unity mixers and 4 inverters.
Once nice thing about this board is that you can always retrofit a built module with one... it'd just be a matter of doing a little rewiring.
janvanvolt
PostPosted: Fri Nov 23, 2012 4:13 pm    Post subject: Reply with quote Add User to Ignore List
are those for eurorack or buchla ? if they are for eurorack i'll take two.
negativspace
Manhattan Analog
PostPosted: Fri Nov 23, 2012 4:46 pm    Post subject: Reply with quote Add User to Ignore List
They're for Buchla, but I suppose you could build one in Euro as a standalone if you need inverters and mixers.
fluxmonkey
PostPosted: Fri Nov 23, 2012 5:09 pm    Post subject: Reply with quote Add User to Ignore List
i'd like one, please & thankyou!
www.fluxmonkey.com
please email (rather than PM) with any direct correspondence
negativspace
Manhattan Analog
PostPosted: Fri Nov 23, 2012 6:05 pm    Post subject: Reply with quote Add User to Ignore List
I've updated the first post with an image of the PCB.
valis
PostPosted: Fri Nov 23, 2012 6:32 pm    Post subject: Reply with quote Add User to Ignore List
That's great. I'll take one.
PF
PostPosted: Fri Nov 23, 2012 6:42 pm    Post subject: Reply with quote Add User to Ignore List
Im in Jason ....,
If you don´t ask, you don´t get......
Musik
http://www.myspace.com/pouppeefabrikk/music
_______________________________________
Videos
http://www.youtube.com/user/ThePF412
Record Label
http://www.alfa-matrix.com
amnesia wrote:
So I am questioning if I need the Easel. But I bet I buy it being such a Buchla fanboy.
djs
PostPosted: Fri Nov 23, 2012 8:15 pm    Post subject: Reply with quote Add User to Ignore List
i'll take one
is the invertor between +v and zero, or inverts to -v?
"Noise is what the Earth is made of" - David Bowie
Votek_Mendo
PostPosted: Fri Nov 23, 2012 10:10 pm    Post subject: Reply with quote Add User to Ignore List
One for me please, Thanks!
Page 1 of 4
