| View previous topic :: View next topic |
| Author |
[Orders Closed] - Euro Panel for Serge Resonant EQ |
thetwlo Super Deluxe Wiggler
     Posts: 1882 Location: San Francisco, CA
Posted: Mon Apr 23, 2012 12:21 am Post subject: |
| clarke68 wrote: | | The only other thing I'd warn you about is that synth DIY is extremely addictive! |
yes, and also the FUMES! proper ventilation is a good thing! |
| Back to top |
spotta Needs more wigglin' time
 Posts: 328 Location: Essex. UK
Posted: Mon Apr 23, 2012 1:16 am Post subject: |
Can you add me to the reorder list for 2 panels.  _________________ --
Spotta |
| Back to top |
Bacchus Wiggling with Experience
   Posts: 381 Location: HKI
Posted: Mon Apr 23, 2012 7:33 am Post subject: |
I'd love to get on the re-order list for 1 panel + 1 sub-board.
Really excited to build this one.  _________________ Lapin |
| Back to top |
Low-Gain Super Deluxe Wiggler
   Posts: 2634 Location: Minneapolis, MN
| Back to top |
negativspace Manhattan Analog
   Posts: 3751 Location: Manhattan, KS
| Back to top |
cleaninglady Veteran Wiggler
   Posts: 690 Location: creeping up behind you
Posted: Mon Apr 23, 2012 8:04 pm Post subject: |
Thanks Low-Gain ! These pics are really helpful.
The power distro makes alot more sense to me now.
One question. Do you think the Euro power would still have enough clearance if i used a Right Angle .156" Header on the RES EQ Board ? _________________ http://soundcloud.com/cleaninglady
http://cleaninglady.bandcamp.com |
| Back to top |
| Back to top |
| Back to top |
| Back to top |
| Back to top |
| Back to top |
bleeps Ultra Wiggler
   Posts: 878 Location: LA CA USA
Posted: Tue Apr 24, 2012 4:44 pm Post subject: |
| Am I crazy for wanting to re-wire a module after seeing someone else's clean work? |
| Back to top |
Posted: Tue Apr 24, 2012 5:23 pm Post subject: |
[s]http://soundcloud.com/low-gain/low-gain-qeseregres[/s]
"Drone set with Serge Resonant EQ via CGS build. Running Harvestman Piston Honda through CGS Serge Resonant EQ. Piston being FM'd via Pokey Module and wavetable modulation by flame clockwork summed CV out. Eventide Space for reverb/delay." _________________ -]|- Low-Gain Electronics -|[-
twitter.facebook.bandcamp.flickr.vimeo.youtube. |
| Back to top |
pulse_divider triangletooth
 Posts: 1243 Location: Akron, Ohio, USA
Posted: Tue Apr 24, 2012 5:42 pm Post subject: |
| man that sounds great, I wish I had nabbed one. someone please trade me one! |
| Back to top |
Rod Serling Fan Club aquatic hitchhiker
   Posts: 3433 Location: Germany
Posted: Tue Apr 24, 2012 5:57 pm Post subject: |
Low-gain, if you haven't tried it yet, the EQ sounds really nice fed-back into its self as a drone machine.
Clarke, if/when you do another run i will probably grab one as well. _________________ DIY panels and PCBs for Buchla and Euro format: http://synthpanels.blogspot.de/
youtube channel: http://www.youtube.com/user/MrPalebluedot |
| Back to top |
chocolatyshatner Wiggling with Experience
    Posts: 307 Location: Brine Shrimp Paradise, Utah
Posted: Tue Apr 24, 2012 7:07 pm Post subject: |
| I have too much diy on my plate right now, but if another one of these panel buys comes up I'm in. |
| Back to top |
Posted: Tue Apr 24, 2012 10:17 pm Post subject: |
I am building the RES EQ with Polystyrene Caps to try and get the sound quality up to highest possible spec.
Anyone have an opinion on whether it's also worth dropping some $$$ on some OPA2134 op amps instead of the TL072's or LF353's to keep the quality up there ? _________________ http://soundcloud.com/cleaninglady
| Back to top |
iopop Ultra Wiggler
   Posts: 932 Location: Malmö, Sweden
Posted: Wed Apr 25, 2012 12:42 am Post subject: |
| Low-Gain: Nice build, what's your reasoning behind having connectors for the 5 pins but the not three in the middle? I have yet to wire it all up and when I do it might make sense. |
| Back to top |
Posted: Wed Apr 25, 2012 12:55 am Post subject: |
| iopop wrote: | | Low-Gain: Nice build, what's your reasoning behind having connectors for the 5 pins but the not three in the middle? I have yet to wire it all up and when I do it might make sense. |
I can't answer for Low-Gain but i reckon the two headers coming from the pads on the CGS202 to the Sub Board would just be so the board could be separated without desoldering.
The middle three wires on the Sub Board are providing power to the CGS202 Board ; that power enters via the Euro Header on the sub board.
No header on the Sub Board in this case just takes one more non-soldered mechanical connection in the Power Buss out of the equation.
Again the Header on the CGS202 Power Input would be to keep it separatable.
How does that sound ? It's just my take on it of course. _________________ http://soundcloud.com/cleaninglady
| Back to top |
Posted: Wed Apr 25, 2012 7:26 am Post subject: |
the spacing of the power connections on the sub board aren't centered the same as the 5 pins.. if they were I probably would have. I think they were likewise too far spaced on the 2 other wires too. If they were spaced the same as the 5 pin, i guess i could have put them on a header as well. No biggy though. Just wanted to keep it as clean as possible. _________________ -]|- Low-Gain Electronics -|[-
| Back to top |
