Adjusting starting pitches in Harvestman Oscs?
MUFF WIGGLER Forum Index -> The Harvestman
Author Adjusting starting pitches in Harvestman Oscs?
joey
Hey all - quick question!
I am using my cwejman s1 as a midi cv converter for my PH and HD. When using the cwej, you can have the master tune knob on the HD and PH all the way CCW and they track the pitch the cwej is set to, but they are always a bit sharp.
How can I adjust their starting pitch so that they are a bit more pitch accurate? This is not about tuning stability, just lowering the starting pitch (i.e. the full CCW rotation of the pitch knob) a tad so it falls directly on the note I want.
Thanks in advance!
bsmith
Couldn't you just run the cwej into a mixer with an offset and nudge it down like that?
Rod Serling Fan Club
Use an offset like the center 2 channels of a MATHs. Or adjust your fine-tune so they aren't sharp?
joey
at the lowest setting of the coarse and fine tune knob they are sharp...
Ted
Fine should primarily be at noon, though, no?
