| View previous topic :: View next topic |
| Author |
BMC001 / Simple CV Quantizer in Euro |
p3t0r Common Wiggler
 Posts: 245 Location: Netherlands
Posted: Mon Feb 13, 2012 3:04 pm Post subject: BMC001 / Simple CV Quantizer in Euro |
Recently built the quantizer from Barton Musical Circuits. Designed a panel to make it fit into my eurorack.
First panel I did myself, so fingers crossed... but quite pleased with the results. Panel is 4hp, but I have 3mm bleed on the left side of it. Just fit it next to a module with some spare room.
Anyway... here are some pics and the FDP file:
Front Design file _________________ Mix of vintage and Eurorack. Some sounds at: http://soundcloud.com/p3t0r |
| Back to top |
frequencycentral Kicking the shit out of your speakers
   Posts: 773 Location: Rick, FC>UK
| Back to top |
valis aliens killed bigfoot
    Posts: 1780 Location: eugene, oregon
Posted: Mon Feb 13, 2012 7:41 pm Post subject: |
| For some reason I never got mine to work. Simple circuit but no go. It's possible something is wrong with the PIC chip. Sadly, I'm using mine as a bias at this point 'cause all it does for me is put out 5v. |
| Back to top |
limpmeat Veteran Wiggler
  Posts: 602 Location: Melbourne
Posted: Mon Feb 13, 2012 8:07 pm Post subject: |
| this looks really interesting. |
| Back to top |
thanatronique Wiggling with Experience
 Posts: 433 Location: Montreal
Posted: Mon Feb 13, 2012 8:38 pm Post subject: |
| Very cool! |
| Back to top |
Barcode Wiggling with Experience
 Posts: 334 Location: Ogden, UT
Posted: Tue Mar 06, 2012 1:26 am Post subject: |
My front panel showed up today. I think it turned out pretty darn good!
p3t0r thanks for posting your FDP file.... I've working on the ticks around the pots for a while and you made it super easy.  |
| Back to top |
regenbot Veteran Wiggler
  Posts: 536 Location: Finland
Posted: Tue Mar 06, 2012 1:59 am Post subject: |
looking good. I have one these waiting to be built, might order second one just because of this panel. _________________ sounds
drawings
free music |
| Back to top |
hpsounds the french icelander
    Posts: 1465 Location: Iceland
Posted: Wed May 23, 2012 3:45 pm Post subject: |
| Barcode wrote: | My front panel showed up today. I think it turned out pretty darn good!
Would you mind sharing your "corrected" FDP file ? It would be nice
Hédi K. _________________ hpsounds.com - flickr - soundcloud |
| Back to top |
mckenic pew!pew!pew!kthnxbye!
  Posts: 3185 Location: Limerick, Ireland
Posted: Wed May 23, 2012 8:36 pm Post subject: |
Just spotted this via the other thread! MAN it looks GREAT!
Read the pdf and it looks like it could be straight forward to do, anything fiddly? Like that thingy about 5v? Any issues hooking up to 12v?
Would love to do a dual too! Really, really cool mate  _________________ DONT FORGET TO DONATE TO KEEP MUFFS ALIVE!
mCKENIC.cOM | mCKENIC Soundcloud |
| Back to top |
Posted: Wed May 23, 2012 10:47 pm Post subject: |
| mckenic wrote: | Just spotted this via the other thread! MAN it looks GREAT!
Would love to do a dual too! Really, really cool mate  |
I run mine off of 12 volts. I was told it can run on 15v as well. |
| Back to top |
Posted: Mon Jul 09, 2012 9:00 pm Post subject: |
Hey folks. I just put together a 6HP version of these for a friend and I must say they turned out pretty nice.
I also attached the FPD file this time.
| Back to top |
diablojoy Veteran Wiggler
   Posts: 518 Location: melbourne
Posted: Mon Jul 09, 2012 9:25 pm Post subject: |
| Quote: | | For some reason I never got mine to work. Simple circuit but no go. It's possible something is wrong with the PIC chip. Sadly, I'm using mine as a bias at this point 'cause all it does for me is put out 5v. |
Valis check your power going in if you have one of the early boards- the pins changed when the board rev did which caught me out as well the old docs were removed so by the time i built mine i went off the wrong documentation end result is you get nothing but 5volts out
worked out ok in the end all 8 that i built suffered no damage and are now working fine _________________ "its not my fault you employ muppets" |
| Back to top |
Posted: Mon Jul 09, 2012 9:32 pm Post subject: |
| Barcode wrote: | Hey folks. I just put together a 6HP version of these for a friend and I must say they turned out pretty nice.
Very nice, thanks for this. |
| Back to top |
asterisk Super Deluxe Wiggler
  Posts: 1449 Location: Burlington VT
Posted: Tue Jul 10, 2012 2:39 am Post subject: |
can i ask how much it cost to make one of those panels?
from front panel express or something?
they look good. id like to get one. |
| Back to top |
Posted: Tue Jul 10, 2012 9:08 am Post subject: |
| asterisk wrote: | can i ask how much it cost to make one of those panels?
Yes, I had it made at Front Panel Express.
The silver with black infill was about $37.00. I thought it was a bit spendy but my friend didn't care.
If you do other colors with no infill you're looking at about $28.00. |
| Back to top |
mOBiTh Veteran Wiggler
| Back to top |
mikecameron Thread Killer
  Posts: 578 Location: Peoria, IL
Posted: Tue Jul 10, 2012 11:53 am Post subject: |
| I'd like to build a couple of these, can anyone comment on the actual performance of the module? |
| Back to top |
Posted: Tue Jul 10, 2012 2:53 pm Post subject: |
| mikecameron wrote: | | I'd like to build a couple of these, can anyone comment on the actual performance of the module? |
I am very happy with mine. From what I can hear it hits all of the scales right on. If you haven't seen what scales it uses.....
STANDARD BANK
1.Bypass - Inputted voltage is outputted
2.Major - Root, 2nd, 3rd, 4th, 5th, 6th, 7th
3.Minor - Root, 2nd, flat 3rd, 4th, 5th, flat 6th, flat 7th
4.Major Pentatonic - Root, 2nd, 3rd, 5th, 6th
5.Minor Pentatonic - Root, flat 3rd, 4th, 5th, flat 7th
6.Blues Scale Root, flat 3rd, 4th, flat 5th, 5th, flat 7th
7.Whole Tone - Root, 2nd, 3rd, flat 5th, flat 6th, flat 7th
8.Chromatic - All 12 notes
OCTAVE BANK
2.Octave - Root
3.Octave and Fifth - Root, 5th
4.Octave and Flat Fifth - Root, flat 5th
5.Major Arppegio - Root, 3rd, 5th
6.Minor Arppegio - Root, flat 3rd, 5th
7.Dominant Arppegio - Root, 3rd, 5th, flat 7th
8.Chromatic
I will say that I use the Major setting most of time. |
| Back to top |
Posted: Tue Jul 10, 2012 3:15 pm Post subject: |
| I love my dual. it works as advertised. |
| Back to top |
Posted: Tue Jul 10, 2012 3:16 pm Post subject: |
can someone upload the FPD for the 4HP version?
thanks! |
| Back to top |
