svf cutoff freq. pot issue
Author svf cutoff freq. pot issue
satindas
Hi,
I seem to have developed what seems like a noisy cutoff freq pot on my svf.
To try and decsribe the fault: in self oscillation, voltage control of cutoff freq gives nice clean sweeps but when using the cutoff freq. knob the sweep becomes noisy and unstable. Are there any other components I could check for misbehaviour before removing the pot from the board.
Synthbuilder
It does sound like a bad pot.
The quickest way to check is to put a 'scope on the wiper of the pot and see what happens when you turn the pot. If the voltage jumps all over the place you need a new pot.
If you don't have a scope - I'd assume it is the pot and replace it anyway.
Tony
satindas
Thanks Tony,
The scope showed the culprit was indeed the pot.
Now replaced and sounding smooth and clean as ever.
