| View previous topic :: View next topic |
| Author |
Output to mixer? |
KnobHell Veteran Wiggler
 Posts: 514 Location: SLC
Posted: Sat Feb 18, 2012 10:50 am Post subject: Output to mixer? |
HI,
I'm sure this has been covered before...
What are you guys using to connect the output of your synths to mixers/sound systems? i.e. The voltage output of a synth is 10 volts, standard audio 1v ptp. I assume an attenuator. Do standard modules exist?
Thanks for indulging a newbie.
len |
| Back to top |
dslocum darwin's nemesis
   Posts: 1336 Location: "Exit 89", NJ USA
Posted: Sat Feb 18, 2012 11:19 am Post subject: |
I use a cheap off-the-shelf Alesis mixer, and the 1/4" line inputs seem to be fine with the higher levels. _________________ Doug Slocum
Synthetic Sound Labs
www.steamsynth.com
WTB: TipTop Z-DSP
"I ordered twice as many _______ as I thought I'd need, only to find out that I'm still less than half way to having enough."
"sounds like a scary and demented merry go round." - decaying.sine
"...this whole thing was started by a dream and a mouse." - Walt Disney |
| Back to top |
schmidtc Common Wiggler
   Posts: 228 Location: boston
Posted: Sat Feb 18, 2012 12:40 pm Post subject: |
| Line level audio is a bit more than that. In most applications, the MOTM mixers have a gain <1 and that's a good one to run into a mixer. I settled on using a few mixers with roughly x10, 1x and .4x gain, and it's simple to set these values by swapping the feedback resistors. |
| Back to top |
pugix Super Deluxe Wiggler
   Posts: 1762 Location: Charlottesville, Virginia
Posted: Sat Feb 18, 2012 5:14 pm Post subject: |
I built my own output mixer.
http://pugix.com/synth/matrix-mixer/
It has a jumper to select between unity and 50% gain, which I leave at 50%. The audio taper pots do the work of reducing the nominal 10V p-p synthesizer levels down to line level. I usually have this module patched over to my Mackie mixer.
I also built a smaller version, using the same basic circuit, but with a different approach to the panel.
http://pugix.com/synth/dual-mixer/ _________________ Richard
http://www.pugix.com
"Everything in our world is actually always modulated by everything else." - Peter B |
| Back to top |
Posted: Sat Feb 18, 2012 11:37 pm Post subject: |
Thanks for the replies, I think that helps me better know what to do.
Len |
| Back to top |
