piston questions
MUFF WIGGLER Forum Index -> The Harvestman
Author piston questions
sentimentalist
Hi,
I just pick up a Piston Honda together with the rom expander and have two questions:
1.
I can use the morph discontinuity (point in the digital display), for each channel separately.
If I want to use the interpolation, (the 2 led´s) for each channel separately, then it is not working. The 2 led´s are burning always together.
Is that normal, because there are two led´s?
2.
How do I know witch room I had chosen in "select-mode", when I am back in "playmode" and modified the knob´s? Just my ear?
governor blacksnake
Hello,
The interpolation is only able to be used on both channels at once. The two LEDs are leftovers from the module's development, in the future it might be used to indicate an LFO mode with a firmware update.
2. Yes, you have to use your ear. With the upcoming "super expander" the ROM selection is indicated by LEDs on the expander panel.
sentimentalist
Thank you governor for your answer!
So, no need to worry for me and my piston.
Have a nice day.
