malekko JAG for vector synthesis
Goto page 1, 2  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules
Author malekko JAG for vector synthesis
matttech
Last Visit: 24 May 2013
PostPosted: Thu Mar 08, 2012 7:19 am    Post subject: malekko JAG for vector synthesis Reply with quote Add User to Ignore List
hi all
so.....am STARTING to get my head round this thing a little
if i wanted to do vector synthesis, mixing continuously between 4 different oscs/ signals, would i just need the following:
JAG
4 x linear VCAs (am thinking about 2 x a132-1, as i have one already)
is that it?
cheers
matt
WTB: Focusrite Octopre/ Saffire PRO40, Rubicon/Dixie, modcan dual delay
EXPERIMENTAL MODULAR SYNTH MUSIC:
http://soundcloud.com/spitezoo-experimental-lab
MODULAR DEMOS:
https://soundcloud.com/matttech-offcuts
NON-MODULAR MUSIC (mainly):
http://soundcloud.com/blue-light-fever
http://www.last.fm/music/Blue+Light+Fever
OLD COMMERCIAL RELEASE: http://www.saltrecords.com/recordings/discography/?id=2&cid=11
Monobass
thonk.co.uk
PostPosted: Thu Mar 08, 2012 7:22 am    Post subject: Reply with quote Add User to Ignore List
or a couple of Intellijel ufades maybe? maybe the Toppobrillo Mixiplexor?
you don't quite have a the flexibility of 4 vcas with those, but it's maybe a lot more compact/simple in terms of CV control.
Thonk - Modular Synth DIY
258J Euro kit - Manhattan Analog Kits- 4ms Kits - Clarke68 Panels - Expert Sleepers Glow Cables - Banana Jacks
READYdot
controlled by voltage!
Last Visit: 23 May 2013
PostPosted: Thu Mar 08, 2012 8:04 am    Post subject: Reply with quote Add User to Ignore List
Wow, never occured to me to try vector synthesis with my modular... now I know why i NEED a JAG! Dead Banana
WANT uATT, TTA BD808 CB808 HT909
mudlogger
PostPosted: Thu Mar 08, 2012 8:41 am    Post subject: Reply with quote Add User to Ignore List
also some good stuff here :
http://www.muffwiggler.com/forum/viewtopic.php?t=5306
soundcloud.com/mudlogger
mudlogger.muffwiggler.com
video
Hoan Kiem Chess Team - Lonbardier Album
Carci
PostPosted: Thu Mar 08, 2012 9:07 am    Post subject: Reply with quote Add User to Ignore List
Or a 4ms VCA matrix.
http://soundcloud.com/carci
TURTLE project : http://vimeo.com/23648701
http://www.facebook.com/TURTLEPROJECT
cillianjohn
PostPosted: Thu Mar 08, 2012 9:20 am    Post subject: Reply with quote Add User to Ignore List
Good timing, I was trying out some vector synthesis for the first time last night using choices and my cwejman 4vca-mx.
http://soundcloud.com/cillianjohn
algorhythm
PostPosted: Thu Mar 08, 2012 9:40 am    Post subject: Reply with quote Add User to Ignore List
Yup, a Choices stick and the VCA Matrix or HexVCA work great for this...
slow_riot
PostPosted: Thu Mar 08, 2012 9:50 am    Post subject: Reply with quote Add User to Ignore List
you might want to look into the Boogie filter as well. With that set up you can use the joystick to morph between all manner of filter types.
for me the perfect VCA for the JAG is the Blacet Super VCA which is basically like the Fonitronik Attenuverting Mixer but with voltage control (and no inversion). The main difference with this and the Doepfer VCAs is the addition of a built in mixer but you might already have that functionality somewhere else.
matttech
PostPosted: Thu Mar 08, 2012 10:45 am    Post subject: Reply with quote Add User to Ignore List
so do i not actually NEED the JAG to do this then?
god this confuses me for some reason....
i've got loads of VCAs and Choices already (and inverters)...maybe i can just do it with them then
if so, could someone describe the patch? (the more detail the better)
i don't see how you could go between 4 different oscs with simply a joystick, 4 vcas and inversion (of two of them)
because.....if you had Choices set up in unipolar mode and then sent say X to the CV input of OSC1, and the inverted version multed out to the CV of OSC2, you could then fade between those 2 oscs. you could then do the same with the Y axis to mix between OSCS3 and 4.
so....in the middle you would get an equal blend of all 4 oscs.
but if you took the joystick all the way to the left of the X axis to get only OSC1, you would be half the way up the Y axis, due to the circular nature of the joystick travel
is this why you need the JAG?
or am i hopelessly confused about this again?? seriously, i just don't get it
what i want to be able to do is have any of the oscs on their own (soloed), and then blend gradually into the next one round the circle
MODULAR DEMOS:
Carci
PostPosted: Thu Mar 08, 2012 11:04 am    Post subject: Reply with quote Add User to Ignore List
I can't see a simple way to do what you're describing.
The JAG makes it simple AND sexy.
ersatzplanet
Synthwerks Design
PostPosted: Thu Mar 08, 2012 11:13 am    Post subject: Reply with quote Add User to Ignore List
The need of the JAG is when you want to do quadraphonic panning that follows the stick movement. With the typical 4-VCAs and a joystick you get places where the +/- nature of the axis of the joystick don't align with the Quad sound field. You need six VCAs to do it without a JAG. Two sets of left and right (for front and rear sets of speakers) and another set of VCAs to do the front and back (feeding the other two sets). Think of the joystick axis as + and - so the four corners are ++(FL), +-(FR), --(BR),-+(BL) and the middle as 0,0 (if you have a bi-polar joystick which most are not - you will have to add bias voltages to get these results). Now think of what 4 VCAs in the corners need to see as control voltages to pan a sound around. What happens in the BR position for instance? The joystick is turning everything off at this point. This is what the JAG is for - turning a two CV system into a four CV system.
The JAG with a VCA Matrix would be a ton of fun since the jag has many simultaneous outputs that all can be used with the VCA matrix.
-James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
james@synthwerks.com
synthwerks@me.com
"It takes about a week to learn how to play a synthesizer, but several years to learn how *not* to play it." - Brian Eno
View user's profile Send private message AIM Address
matttech
PostPosted: Thu Mar 08, 2012 2:33 pm    Post subject: Reply with quote Add User to Ignore List
right....ok.....so the general gist is that i need a JAG (or, to be more precise.....would "like" a JAG)
by the way James, any word on when the faders will be available in the EU? (might PM you about this actually). may be getting a skiff soon, which i may dedicate to real-time control stuff, and a couple of faders would be sweet!
MODULAR DEMOS:
ersatzplanet
Synthwerks Design
PostPosted: Thu Mar 08, 2012 2:43 pm    Post subject: Reply with quote Add User to Ignore List
To mix with four sources and use a joystick like those on a typical vector synth, you will need something to do the conversion. The only other way may be to find a joystick with dual pots in it instead of singles and make two sets of CV outs and wire them opposite but I haven't really tried that yet. Hmmm... A mechanical project.
Basically it is totally up to the distributors over there - they have to ask for them to get them. I guess enough people have to ask them before some threshold is reached. I for sure am not refusing to ship anything! If shipping and customs wasn't such a hassle (usually the distributor handles all that) then I would ship direct. You are not the only one asking for stuff in the EU.
-James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
synthwerks@me.com
Leoespejo
PostPosted: Fri Mar 09, 2012 4:38 am    Post subject: Reply with quote Add User to Ignore List
Mmmmm ...... Great information in this topic
A most try patch.. applause
flashheart
PostPosted: Fri Mar 09, 2012 1:07 pm    Post subject: Reply with quote Add User to Ignore List
You can do this with crossfaders, but you actually need more than you think....
1st Xfader is between Osc 1 / 2, let's say X-axis
2nd Xfader is between Osc 3 / 4, X-axis again
3rd X fader - Y-axis is between the outputs of the 1st 2 Xfaders
Assuming your corners are:
Osc 1: Osc 2
Osc 3: Osc 4
TL gives you Osc 1, TC = 1+2, TR = Osc 2
CL gives you 1+3, centre = 1+2+3+4, CR = 2+4
BL gives you Osc 3, BC = 3+4, BR = 4
If you've the Doepfer dual Xfader you're 1/2 way there. X CV to both, then a couple of VCAs & and inverter to mix between the outs using the Y CV.
Using 4 VCAs gets more complex, fading between 1+2 or 3+4 is easy but how do you mix between the pairs? You need to actually control the CVs themselves with the joystick before they get sent to the VCAs (I think hmmm..... ). See I'm confused now.
I suspect this kind of headscratching is exactly what the JAG was designed for, but shirley you don't need to buy something else?
do you? Guinness ftw!
matttech
PostPosted: Fri Mar 09, 2012 1:32 pm    Post subject: Reply with quote Add User to Ignore List
Osc 1: Osc 2
Osc 3: Osc 4
cheers for that. am starting to think that patching it may be more hassle than it's worth. OBVIOUSLY i need to buy more modules!!
the main thing is: i've got a credit note to spend at Escape From Noise, birthday money coming (my 40th) to spend at schneiders in berlin in april....and i've just sold my Les Paul
so i've got £800-odd to spunk, should i choose to (which i will, obviously...)
luxury items, that's what i want. and a cv to midi converter (i think)
MODULAR DEMOS:
pulse_divider
triangletooth
PostPosted: Fri Mar 09, 2012 2:05 pm    Post subject: Reply with quote Add User to Ignore List
Yes, JAG with VCA Matrix = SlayerBadger!
ersatzplanet
Synthwerks Design
PostPosted: Fri Mar 09, 2012 2:46 pm    Post subject: Reply with quote Add User to Ignore List
Osc 1: Osc 2
Osc 3: Osc 4
Here is the layout to do it with 6 VCAs or 3 VC panniers or Segue/X-fader arrangements.
I just kind of whipped this out and haven't really tested it yet but they should work in theory.
EDIT - Opps- Forgot some inverters needed if VCAs are used - picture updated.
-James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
synthwerks@me.com
30ohm
PostPosted: Fri Mar 09, 2012 4:16 pm    Post subject: Reply with quote Add User to Ignore List
Ok, here's my question that has been puzzling me:
Why the hell doesn't the JAG have a joystick built-in???? d'oh!
RubberCityNoise
PostPosted: Fri Mar 09, 2012 4:26 pm    Post subject: Reply with quote Add User to Ignore List
Because this works awesome with LFOs and envelopes. Using a joystick is too predictable. Feed any 2 VC into it and get 12 separate outs! SlayerBadger! SlayerBadger! SlayerBadger! SlayerBadger! SlayerBadger! SlayerBadger!
Life without synthesis has no meaning!
http://www.rubbercitynoise.com
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Eurorack Modules All times are GMT - 5 Hours
