Noise/Filters Issue
Author Noise/Filters Issue
wmonk
Hi!
I finished the noise/filters module and only got it partly working. The High pass filter, white noise, pink noise, IR and CVing the HPF work great, but the LPF doesnt seem to work. No output sound at all, and no leaking of the input sound to the other outputs (which is of course OK, but I had to check the wiring anyway).
Any suggestions where to start looking?
Woody
wmonk
Issue is solved. Was a mix of a wiring problem (had switch and signal lugs reversed on the LPF input) and a wrong resistor.
Thanks for this great module Tony!
And as this thread wouldn't be complete without a pic, here it is.
IMAG0628
Woody
