Blacet Scanner - bidirectional or not?
Author Blacet Scanner - bidirectional or not?
chamomileshark
i saw the vid for the sequential switch and scanner - in it I'm sure John says both are bidirectional - the manual appears to say the scanner is only 3 in and 1 out.
anyone know if it is actually bidirectional?
fracmonkey
The scanner is one way only. The video is incorrect.
There is an op amp summer on the output to allow for dithering (overlap) between the inputs and an inverter/filter cap also. This makes it one way.
chamomileshark
ok thanks
Cat-A-Tonic
If you are using Euro alongside Frac,
the Doepfer A-152 might be of use.
It's sequential switch is bi-directional,
and you can VC address it like a scanner.
