Blacet EG1 Question
Author Blacet EG1 Question
jjr
Hello All,
Is there a way on the EG1- ( besides the button ) to get the module to self trigger ? Or do you have to send it a gate or pulse ? also I've always been a little confused by the LFO and AD switch - is the LFO function on the sustain knob used to loop the ADSR and if you apply a CV to it in this setting will it change its function?
thanks much
best
jjr
if you patch one of the envelope outs to the gate in you can get it to self trigger. there's also an easy mod for an "end of release - gate on" output you could also use.
in lfo mode, zero sustain means lfo mode is on, whilst a little bit of sustain switches off the lfo mode and you get a regular ADSR.
p.s. also check this thread for loads more useful info:
www.muffwiggler.com/forum/viewtopic.php?t=212
fracmonkey
You can add -CV to the Sustain CV input to turn on the LFO. You just need to add enough to counteract the pot setting.
