| View previous topic :: View next topic |
| Author |
The Ax+By+C control voltage processor? |
akrylik Veteran Wiggler
 Posts: 611 Location: Hong Kong and Tokyo
Posted: Thu Mar 29, 2012 8:48 am Post subject: The Ax+By+C control voltage processor? |
(In the following lower case letters are inputs and UPPER CASE letters are knobs.)
I often find that I need to attenuate and offset my (bipolar and other) modulation sources (e.g. lfo) like this:
Ax+B
and then I often want to mix two such attenu-offsetted cv's together like this:
E(Ax+B)+F(Cy+D)
but then the two offsets and the two mixing levels become redundant so I really just want a module that does this:
Ax+By+C
and hopefully in dual and then voila! I can chain a bunch of these together get maximal shifting/attenuating/mixing control with a minimum number of knobs.
So here is my question. Does this module exist? The A-183-2 is really close but lacks the mixing part. _________________ Disclaimer: If it seems like I know what I am talking about its because I got lucky. I'm a noob in this electronics DIY stuff but I'm working hard to fix that.  |
| Back to top |
VortexRanger reticulating splines
  Posts: 1898 Location: North Carolina
Posted: Thu Mar 29, 2012 8:59 am Post subject: |
I'm not sure I fully understand your equation, but Synovatron's CV Tools might be close? I haven't used it but I think you could attenuvert your two signals on the first two channels, then offset with the 3rd and take the sum output. _________________ http://vortexranger.muffwiggler.com
http://soundcloud.com/vortex-ranger |
| Back to top |
bphenix Wiggling with Experience
  Posts: 412 Location: austin, tejas
| Back to top |
Posted: Thu Mar 29, 2012 9:27 am Post subject: |
Thanks guys! I did not realize it at first but the cv tools will definitely fit the bill because all the inputs are normalled to a voltage reference for generating offsets, sweet! The channels are cascaded and the cascade is interrupted when you insert a jack, double sweet!
This got me thinking that maybe other cv mixers also have their inputs normalled to a voltage reference and hence able to create offsets. Turns out the A-138c has just channel 1 normalled to vref, so you can add one offset. Again sweet!
The birds are singing again.  _________________ Disclaimer: If it seems like I know what I am talking about its because I got lucky. I'm a noob in this electronics DIY stuff but I'm working hard to fix that.  |
| Back to top |
Posted: Thu Mar 29, 2012 9:36 am Post subject: |
| akrylik wrote: | | This got me thinking that maybe other cv mixers also have their inputs normalled to a voltage reference and hence able to create offsets. Turns out the A-138c has just channel 1 normalled to vref, so you can add one offset. Again sweet! |
A-138b does this too. And of course Maths. _________________ http://vortexranger.muffwiggler.com
| Back to top |
Human Koala Common Wiggler
Posted: Thu Mar 29, 2012 9:41 am Post subject: |
EDIT : I'm a little bit late
Doepfer A138C,
first input can give an offset if empty
you have 3 input :
First one empty give C , the two other AX+BY+C
HK |
| Back to top |
Posted: Thu Mar 29, 2012 10:18 am Post subject: |
| Quote: | | A-138b does this too. And of course Maths. |
Ah yes. The Maths. I keep forgetting about channels 2 and 4 on that thing...it just never occurs to me to use the Maths for such a mundane purpose. Maths just looks so glamorous and bitchy next to those demure Doepfer modules  _________________ Disclaimer: If it seems like I know what I am talking about its because I got lucky. I'm a noob in this electronics DIY stuff but I'm working hard to fix that.  |
| Back to top |
flashheart Veteran Wiggler
Posted: Thu Mar 29, 2012 10:28 am Post subject: |
Maths can't do complex maths like AX + BY + C, only AX + BY or AX + B  |
| Back to top |
Posted: Thu Mar 29, 2012 10:49 am Post subject: |
| flashheart wrote: | Maths can't do complex maths like AX + BY + C, only AX + BY or AX + B  |
Yeah depending on the type of signals you are using your ability to free a mid-channel for offset may vary. But in general, that offset is a great thing to have! Use it with the sum output to turn your envelopes bipolar, for example.
Actually offset was the reason I bought Maths. At the time I didn't have many sources of it - of course, I had not explored the possibilities of an unclocked Z8000. _________________ http://vortexranger.muffwiggler.com
| Back to top |
tommi Wiggling with Experience
  Posts: 413 Location: Milan, Italy
| Back to top |
John Noble Pining for the fjords
  Posts: 2207 Location: Sandy Eggo, California
Posted: Thu Mar 29, 2012 11:37 am Post subject: |
Doepfer's A-138m can do Ax+By+Cz+D
The first row can be normalled to +5V, and the columns can be polarizing if necessary. I want one. _________________ Variable Resistor at The Eurorack Database: http://eurorackdb.com
Ask me about custom passive Euro modules!
Music: http://soundcloud.com/prettyhowtown/ |
| Back to top |
synthomaniac Wiggling with Experience
  Posts: 384 Location: Portsmouth UK
Posted: Thu Mar 29, 2012 1:49 pm Post subject: |
I like the way this question has been posed in maths notation
Thanks to Bphenix and VortexRanger for the recommendation - CV Tools can do Ax+By+Cz+D or Ax+By+C and Dy plus loads of other combinations and then smooth (slew) the output too. Here's a full list I did for the manual, sadly not in maths notation (any input can provide an offset providing it is not patched):-
Hope that helps
Tony Steventon _________________ Synovatron Electronic Music
http://synovatron.blogspot.com
Eurorack DIY kits, modules (CV Tools, CVGT1), AS-Doepfer Adaptors, Ribbon cables
http://soundcloud.com/monakrome
Synths: Minimoog Voyager, Roland SH09, SH5, 100m modular, 2 Sequential Circuits Pro Ones, Eurorack modular, Novation K-Station, Novation KS4 |
| Back to top |
