| View previous topic :: View next topic |
| Author |
[IN STOCK] L-1 VOCODER |
L-1 Super Deluxe Wiggler
 Posts: 1144 Location: Belarus
Posted: Thu Mar 29, 2012 4:58 pm Post subject: [IN STOCK] L-1 VOCODER |
Info here http://l-1.su/Vocoder.html
Build thread http://www.muffwiggler.com/forum/viewtopic.php?t=75707
I have decided to post about my new project I'm working now. Maybe it will help me to get some advises and to avoid some mistakes.
I have written somewhere on the forum I repaired 1988 soviet 24 band vocoder. Now I made one channel based on its schematic but with changes. It works, but very hard to understand how it sounds because I have only one channel now. My channel sounds different than soviet analog, I think better but will can say exactly when will make all filterbank.
I replaced crappy old soviet single opmaps with TL074, and replaced transistor pairs VCA with THAT2180 VCA. Anyway DIP trans pairs cost equal to 2180 IC. The channel has turned out much more compact.
I already drew in Eagle filterbank board. 6 channels fit on the eurocard (160x100). So will be 5 boards - 4 for filterbank and one for in-out circuits and controls.
I made CV in and out pads on board for every channel, so if someone wants can make patch matrix.
In-outs circuits I plan completely remake. I think about THAT based mic amp, then (maybe) one knob limiter (THAT), then simply output summing amp (OPA2604) and 4-band EQ.
I drew simply sketch. Green are pots. Blue is hole for mic. connector. Red are 3.5mm jacks and I will make connector for 5U users to connect their BIG jacks. Dimensions between pots will be by MOTM standard http://www.dragonflyalley.com/images/MOTMtech/m440_panel.jpg
Pots:
- mic amp gain
- carrier level
- modulator level
- limiter treshold
- 4 bands of EQ
jacks
- carrier
- modulator
- out.
maybe switches to bypass limiter and EQ, and maybe limiters makeup gain pot.
I like these pots from Smallbear. They are 15 mm - not small as 9 mm and not big as regular 16 mm (they are already sick), and have possibility to mount funny LEDs.
http://www.smallbearelec.com/Detail.bok?no=1186
I think module deep will not exceed max for Doepfer case 14 sm. It can work from 12 and 15 V with minor changes - some resistors values.
I will order next week filterbank prototype boards, they will be ready in one week. Will inform about progress. Please write your comments. Not needed to write who are in, the project is still in its infancy and no one knows what will happen as a result of.
Я ТВОЙ РОБОТ. Я ТВОЙ РАБОТНИК. _________________ http://L-1.su
| Back to top |
Revok Wiggling with Experience
 Posts: 322 Location: Brooklyn
Posted: Thu Mar 29, 2012 5:39 pm Post subject: |
| I don't have anything to add besides the fact that I really want to see this happen! |
| Back to top |
JP Super Deluxe Wiggler
   Posts: 1084 Location: NJ
Posted: Thu Mar 29, 2012 6:38 pm Post subject: |
| I was just researching vocoders yesterday. Nearest idea I had was picking up one of the many sub $200 pedal vocoders and converting it so it lived behind a eurorack panel. This project sounds WAY more serious. I'll be following along, and will be tempted as long s it's not crazy complex (is that really 4 stacked PCB's). |
| Back to top |
Posted: Thu Mar 29, 2012 6:42 pm Post subject: |
It's not crazy complex. All 24 channels are identical except for the caps values. Some trimming required - 3 trimpots for every channel to set levels.
And no 4 but 5 boards, one for controls and in-out circuits.
The project will be quite expensive. I think build cost will be about 500$.
Therefore I plan to release first limited quantity, maybe 10 sets.
This is original one. 5 channels don't work and can't trimm properly because old rusty trimpots.
It is very rare - not more as 100 were produced in 1988, and not many survived until today. My has 25 serial.
| Back to top |
Posted: Thu Mar 29, 2012 8:04 pm Post subject: |
His voice (carrier - two square waves (I tweak freq a bit), modulator - sample) _________________ http://L-1.su |
| Back to top |
emdot_ambient Super Deluxe Wiggler
   Posts: 2386 Location: Frederick, Maryland USA
| Back to top |
limpmeat Veteran Wiggler
  Posts: 602 Location: Melbourne
Posted: Thu Mar 29, 2012 9:30 pm Post subject: |
| looks really interesting, a lot more compact than the haible vocoder |
| Back to top |
LoFi Junglist Wired for sound
  Posts: 1083 Location: Adelaide, Australia.
Posted: Thu Mar 29, 2012 10:22 pm Post subject: |
Don't forget a filter stack can be used to implement a Barber Pole filter.
It would be great if these boards allow for this option, if the user adds a "Shepard controller" such as the old discontinued(?) Doepfer module (I'll probably be in the market for 16 or 32 filters pretty soon) |
| Back to top |
raisinbag Super Deluxe Wiggler
Posted: Thu Mar 29, 2012 11:39 pm Post subject: |
Cool, so If I am getting this correct it will be a 24 band unit (4 cards with 6 bands on each one) and it will fit in euro! SWEET!
When you say "release" this, do you mean the 5-PCB set? And it uses THAT and 074s and noting super rare, WOW
Well the Sound clip is great, can't wait to see this one come together. |
| Back to top |
sanders Wiggling with Experience
Posted: Fri Mar 30, 2012 1:03 am Post subject: |
Great demo! That sounds fantastic!
This is really impressive, nice work. I'd be interested, but I couldn't lay out $500 all at once.
I had been thinking recently how the Korg VC10 would make a great DIY Vocoder. It sounds great, and had 22 bands + envs all on one medium-large sized PCB, with preamps, compander, and divide down synth on a second PCB. There was a salvaged filter PCB on ebay not long ago, but I lost the bid. It went for only $75.
I wouldn't be super surprised if this soviet design was derivative of the Korg.
PS-- are you still planning to offer you VC Compressor PCB? I was getting interested in that one also. |
| Back to top |
astroschnautzer Super Deluxe Wiggler
    Posts: 1539 Location: Finland
| Back to top |
Posted: Fri Mar 30, 2012 2:50 am Post subject: |
| Quote: | | Great demo! That sounds fantastic! |
This is not mine yet. This is sound of vintage soviet vocoder which is the base for mine. As I written above 5 channels don't work and can't trimm properly because old rusty trimpots. And I completely removed in and out circuits, so it connected direct to my gear.
| Quote: | | PS-- are you still planning to offer you VC Compressor PCB? I was getting interested in that one also. |
Compressors PCBs are still in producing. I hope will receive next week. The company makes PCBs within a month, its time is running out soon.
| Quote: | | if the user adds a "Shepard controller" |
Can't find any info about this controller (
I made pads on PCB - CV out from modulator and CV in to carriers VCA for each filter. Can't imagine what I can do more.
| Quote: | | When you say "release" this, do you mean the 5-PCB set? |
Yes, 5-PCBs set.
| Quote: | | I wouldn't be super surprised if this soviet design was derivative of the Korg. |
Filters are similar (first two opamps and associated parts) but not identical. The rest of the circuits are different.
I think those caps should be matched in pairs for better results. How do you think? They all have identical values.
| Quote: | | There was a salvaged filter PCB on ebay not long ago, but I lost the bid. It went for only $75. |
I think my PCBs set will be double that price.. _________________ http://L-1.su |
| Back to top |
Altitude909 Wiggling with Experience
Posted: Fri Mar 30, 2012 6:20 am Post subject: |
| This is relevant to my interests.. Been looking for a vocoder project for a while |
| Back to top |
Luka Super Deluxe Wiggler
    Posts: 4910 Location: melbourne
Posted: Fri Mar 30, 2012 6:41 am Post subject: |
Nice - would love to get this _________________ .
melbourne australia
soundcloud
lastfm
vimeo
wtb:
220/230/240v Broken Dp4
20x20 ghielmetti matrix
taking offers on (melbourne pickup)
revox pr99 mk2
allenheath zed420 |
| Back to top |
ndkent Super Deluxe Wiggler
Posted: Fri Mar 30, 2012 7:38 am Post subject: |
Looks interesting and on a good track. Eventually you'd want to look into voiced/invoiced, but you don't need that to get the vocoder bands all working. Also, while I know you are improving the specs on the Soviet original its worth finding out what the good ones did right.
As for other comments -- $200 pedals? what's analog in that range and in a pedal??
As for the Doepfer Shepard Module. Please fill me in on a Shepard filter?? I have that module. I thought since there's a micro controller inside it had 2 separate modes. The Shepard generator did like 15 LFOs from a master tempo that are all triangles and ramps with different phases. You'd use some of them with gear that has a VC frequency like multiple phasers or VCOs though nothing stops you from opening and closing a vocoder decoder for a sort of smooth fixed bandpass cross fading. Can't do a Shepard effect with a vocoder decoder since you can only open and close fixed bands though you can do a Moogerfooger murf fx. The other Doepfer mode is Midi CC to 0-5v in 15 or whatever channels. So you could connect that and MIDI each band to open and close.
Anyway one thing that can be said us it really opens up options if you have a normalized jack out of each envelope follower and a normalized hack into each VCA _________________ http://nickkent.net
http://twitter.com/ndkent
http://www.myspace.com/ndkent
http://www.youtube.com/user/itisnick
http://soundcloud.com/nicholas-d-kent/
| Back to top |
samuraipizzacat29 adadadadadadadsr
 Posts: 836 Location: Allentown, PA, USA
| Back to top |
NS4W Wiggling with Experience
Posted: Fri Mar 30, 2012 9:57 am Post subject: |
I'd be interested.
The mp3 you posted of the soviet vocoder sounds so good! Please don't make your version too clean and soulless - it's the raw gritty sound that's appealing!  _________________ http://soundcloud.com/ns4w/ |
| Back to top |
Posted: Fri Mar 30, 2012 10:54 am Post subject: |
| ndkent wrote: |
As for the Doepfer Shepard Module. Please fill me in on a Shepard filter?? |
If each filter of the vocoder had a separate input for freq modulation then you could use the Shepard generator to modulate them and create the psychoacoustic illusion called "the barberpole effect"
The easiest way to look at a Shepard generator is to consider a Quadrature LFO, which has four identical waveforms out of phase by 1/4 of the period. An (8 stage) Shepard generator would have 8 identical waveforms, each out of phase by an equal amount; 1/8 of the normal period.
If the Shepard generator is creating upward saw waveforms each filter it modulates would sound like its being swept up, and the frequency we hear would sound like going up in pitch.
Once you start overlapping that effect with 8 filters your brain cant tell when one filter is reaching the peak of its sweep, and when another filter is starting its sweep, it all blurrs and we actually think the sound is continuously going up in pitch when the source Audio is really staying constant.
If the Shepard generator was modulating the filterbank with a downwards saw waveform, the output would sound like its getting lower and lower.
you don't hear it often because a simple 4 stage quadrature lfo isn't tricky enough;our brain can separate and recognise each filter individually. The effect is only available to people with huge filter banks
If we had a Filter bank of 24 or 36 filters like L-1 is proposing (or 48, RAWR), the effect would be even smother and trickier for our brain to comprehend and would probably cause people to freak out
Not everyone can get hold of a A-191, and I realise a Jack on the front panel for every filter would waste a huge amount of space, but if the L-1 vocoder has input (headers) for each filter's critical frequency on the boards, then an expansion board could be released later to add the option between traditional vocoder and Shepard Filter Bank (the first in Euro I believe, There's an old Buchla version). |
| Back to top |
ersatzplanet Synthwerks Design
    Posts: 2368 Location: Seattle WA
Posted: Fri Mar 30, 2012 11:12 am Post subject: |
| LoFi Junglist wrote: |
My only real experience with Vocoders is with the one on the Nord Modular. The most fun was the re-patching of the spectrum to different filters from the original ones. Reversing the spectrum so low frequencies in the control would open high frequencies in the program. That is where the fun really is. The EMS Vocoder had the best setup for this with a patch matrix to link the CV outs of the carrier filter banks to the CV ins of the VCAs in the program banks. You could run multiple program filters with single carrier bands ad things like that - super versatile.
I would suggest bringing all the carrier and program CV lines out to easily reachable headers and then all sorts of external add on boards and patch panels cant be connected easily. _________________ -James
James Husted
Synthwerks
www.synthwerks.com
info@synthwerks.com
james@synthwerks.com
synthwerks@me.com
"It takes about a week to learn how to play a synthesizer, but several years to learn how *not* to play it." - Brian Eno |
| Back to top |
Popski The Cake is a Pie
    Posts: 1734 Location: Shame Tunnel
Posted: Fri Mar 30, 2012 11:18 am Post subject: |
I'd love one of these.. _________________ Soundcloud | Tumblr | Aux | SO4 | have you ever felt like you've crossed the line into fuck - Matos |
| Back to top |
