Sequantizer
MUFF WIGGLER Forum Index -> Wiard
Author Sequantizer
Pascal
I am surely missing something here but here it goes: Sequantizer has seperate gate outputs for each step but how do you combine them to trigger a single vco like the waveform city hmmm.....
sandyb
i'm presuming you want to trigger the vco each time the sequantizer steps?
if so, i'd be inclined to use whatever i was clocking the sequantizer with to trigger the vco as well.
rezzn8r
from the manual...
These eight output jacks go "high" whenever
the respective sequence stage is current.
These jacks are diode-isolated, so several
outputs can be simultaneously connected
(using the Multiple jacks) for pulse programming.
Pascal
true, thank you sandyb
chamomileshark
hi, yes, as said, I clock usually via an LFO and use the LFO to then trigger say an envelator, the envelator to the filter mod and/or z mod of the Mixolator for the standard monosynth type patch.
I use the gate outs from the sequantiser to perhaps add emphasis in a sequence
Pascal
rezzn8r: thank you for this, have already everything printed and do some homework, great vids on tube, thanks for sharing
Mark: thank you, sounds nice
rezzn8r
Guinness ftw!
A handful of TipTop stackables would be great for this.
Pascal
I have the TipTop stackcables, only the Wiard 300 is missing
