Recommendations on a Strategy for Recording
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear
Author Recommendations on a Strategy for Recording
dzlvs8
Last Visit: 12 Jun 2012
PostPosted: Tue Apr 10, 2012 5:59 pm    Post subject: Recommendations on a Strategy for Recording Reply with quote Add User to Ignore List
Hi, I am a keys and guitar player and have tons of cool crap. ..instruments, that is. I unfortunately have neglected any type of recording setup. So I currently am working with 12 instruments (mainly vintage keys) and only a four channel looper and a Boomerang 3 Phrase Looper.
I would like to acomplish two things and I need advice on both before I make my next move/purchase.
Goal 1: I need to get all 12 of my instruments (11 instruments and a 6 channel drum machine) conveniently mixed.
Goal 2: I would like to now record directly into my computer, instead of using my video camera!!!! I will occasionally want to still use my looper to structure the songs completely and then just record the track into the computer. While other times I may want to record each instrument individually and cut up the tracks in Ableton Live or something.
So, with that said, I assume I need a new mixer and I will also need to buy an audio interface. I assume this is the obvious route to take. Also, I dont use midi (most of everything I have is pre-midi or electromechanical).
I am not a fan of all in one devices unless it saves a ton of cash and I'm not sure if a standard mic/line mixer with an audio interface in it would work when a lot of the time I will just want to send stuff from my mixer to my looper and then to my computer.
I will stop here for now. I unfortunately will have lots of questions about which 16 channel mixers or audio interfaces I should consider. Once I know exactly what type of devices I need to get.
Due to the complexity of my situation. I will reply with a diagram of my setup. If you've made it this far into my confusing post. Congratulations. ...and thanks in advance for your reply/recommendations.
Steve
dzlvs8
PostPosted: Tue Apr 10, 2012 6:42 pm    Post subject: Reply with quote Add User to Ignore List
Here is my flowchart to simplify things. Sorry I have made music so boring with a flow chart.
My concern is how to go about this efficiently and without wasting lots of money. Hope this helps.
mangobob
Last Visit: 21 May 2013
PostPosted: Tue Apr 10, 2012 7:12 pm    Post subject: Reply with quote Add User to Ignore List
A decent mixer will typically have a main stereo outs to go to your recording device (audio interface) as well as separate monitor L/R outs to go to your speakers.
Also read up on how Aux Sends and Returns work. I don't use a looper but that may be an ideal way to hook it up. You could send any combination of mixer input channels (in varying amounts) to the looper input via an Aux Send. The looper output goes back to a input mixer so you can monitor/record it. As long the looper's return channel doesn't send signal via the Aux to the looper input you won't get feedback.
CalvaryBand
PostPosted: Tue Apr 10, 2012 8:09 pm    Post subject: Reply with quote Add User to Ignore List
My advice... No mixer/Amp. Get a really good, multi-channel soundcard. RME UFX is my pick as it is a great piece of hardware and uses very solid drivers. The TotalMix software that comes with it is fucking great as well. Get a MIDI controller (or a couple) that allows for easy control of said in-the-box mixing: these controllers range from more expensive-ish stuff like the Mackie Universal Control series to the more low-end Korg Nanokontrol2. Of course with this setup you will need to have the computer on the entire time but it will make it so you do not need bulky amps/mixers around.
Jordan Passmore - Soundcloud (Old School House/New Wave/Hi-NRG/Techno) - Facebook (I'll be your friend) -
Youtube (Synthesizer/Sampler/Drum Machine Demos)
skipperdean
PostPosted: Tue Apr 10, 2012 8:15 pm    Post subject: Reply with quote Add User to Ignore List
I agree!
saved me some typing. any (simultaneous) multi track interface + daw + midi controller for daw=golden.
dzlvs8
PostPosted: Tue Apr 10, 2012 8:47 pm    Post subject: Reply with quote Add User to Ignore List
Alright, so I got my head wrapped around the basics of a mixer and audio interface setup. It took a 40 minute long conversation with a dude from craigslist in order for me to figure out that what I needed to do will work with no lag (record into the computer and have sound come out of the computer LIVE with no lag...using a PC).
As long as that statement is true. I know what will work but I was thinking there was something slicker out there. Something like what you are suggesting. Here are my questions, issues with that.
1 - I have a high powered laptop (6gb ram, dual HDD, i7 processor), but its a PC, so will I have lag? I didn't think I could run 16 individual channels into a computer at once via usb.
2 Will I experience lag with a midi controller for controlling the software. I have a PC, not a Crapple. ...not yet.
3 Is there any advantage to this if its only me. I can only play one instrument at a time. I know I would gain a small advantage by being able to tweak my drum machine channels individually after the fact. .....but this setup sounds really expensive, without having any advantage.
CalvaryBand
PostPosted: Tue Apr 10, 2012 9:18 pm    Post subject: Reply with quote Add User to Ignore List
You can get lots of channels in and out of USB (these days, anyways). If you're recording at 48k you can do 30 channels I/O on the UFX. Using a PC is fine, there will be no difference in performance, and you should not notice any lag using these midi controllers.
If you're used to using nice keys and a looper, getting into Ableton with something like the UFX or Fireface UC will literally make you lose your shit. It's motherfucking bacon yo
dzlvs8
PostPosted: Tue Apr 10, 2012 9:30 pm    Post subject: Reply with quote Add User to Ignore List
......Wait a minute. I just went and looked up that RME UFX. Thats like $2300 frickin dollars!?!? I should probably explain my setup. Although the price tag of all my instruments combined far exceeds the value of my car, I am looking to not spend much money.
Put it this way. Currently I record with a guitar looper and a video camera. IDEALLY, I would like to spend as little as possible on this. I would like a pretty good quality sound recording. But I want to spend most of my money on instruments. Not recording gear. I am an instant gratification guy. Hence the guitar looper and camera. I enjoy playing instruments.
I would like to make my new setup something that is as easy/quick to use as possible. That is the main goal. I would however like to maximize my features and capabilities as much as possible, within reasons.
With that said, I have learned tonight that I am looking more along the lines of a 16 compact mixer and a m audio fast track pro because it will get the job done and I cant find any advantages to going with anything better....even with a small price upgrade. I am also assuming that the guy I talked to was correct in saying I shouldnt experience any latency with an maudio fast track if I am doing what is shown in the following diagram.
dzlvs8
PostPosted: Tue Apr 10, 2012 9:34 pm    Post subject: Reply with quote Add User to Ignore List
Thanks for the lag info. I assume that the "zero" noticeable latency is still true for the diagram below. If so, that's awesome and I've learned a lot tonight.
......But I don't want to lose my shit. So, no UFX for me.
I used to use ableton and a midi controller and a nord electro and I quickly gave that crap up and went straight analog and the looper. I want to play music. Not sit in front of the computer for 14 hours after I make 10 minutes of music.
But anyway, I know ableton. Like I said in my last post. In not looking to invest thousands of dollars into a recording setup. I don't need others to hear my stuff that bad. And if I want to hear some cool stuff again, I'll just play more. If I invest $1000's of dollars into my music, its gonna be another keyboard. Unless you have a free Andromeda or Jupiter 8 up for grabs.
drewtoothpaste
married to the sea
PostPosted: Tue Apr 10, 2012 10:11 pm    Post subject: Reply with quote Add User to Ignore List
You don't need a mixer, just use a patchbay to hook your instruments straight into your audio interface. If you're playing them by hand and looping/multitracking them you don't need to listen to their audio outputs mixed together.
Get a cheap interface (used) and see if you like using the computer, no need to get anything fancy yet.
Do you wear nail polish?! Super Black Lacquers: Holographic, Glitter & Solid Nail Polish
CalvaryBand
PostPosted: Tue Apr 10, 2012 10:35 pm    Post subject: Reply with quote Add User to Ignore List
There's also the Echo Audiofire 12, that's a pretty good soundcard as well. Don't know if your laptop has firewire (or an expresscard port to expand into firewire), though.
dzlvs8
PostPosted: Tue Apr 10, 2012 10:47 pm    Post subject: Reply with quote Add User to Ignore List
Im still struggling to understand why I want to invest a ton of money into a multi channel (16) interface and have to use my computer as a mixer and buy a midi controller to make controlling the computer easier, and by a patch bay. When I could just buy a mixer and a fast track pro. I dont see the advantage. I understand that it would be great for the few times when I am playing my clavinet and rhodes at the same time and I want to go back and do something to only one instrument, but it sounds like a huge investment.
Is there a cheap solution for everything ($600 if I have to buy a mac to avoid latency. ...preferably around $300...). The mixer / audio interface combos seem like theyd do all of what you are describing but Ive heard that there is latency issues. i would take the advantage of multi channel direct recording for $400. I found the alesis multimix 16 channel usb 2.0. But Ive heard of latency issues there too. I swear to god if I invest $600 into anything that makes playing my odyssey lag, Im gonna freak out. That is NOT the direction i want to take.
CalvaryBand
PostPosted: Tue Apr 10, 2012 11:28 pm    Post subject: Reply with quote Add User to Ignore List
Well, you could either use a multi-channel soundcard or a lower channel count soundcard with a patchbay. The Audiofire 12 will sound better than any mixer/audio interface combo in a similar price-range and being able to multi-track record to me, is priceless, especially when you factor in how many incredible vst effects there are in this day and age.
Manual Gain Rider
PostPosted: Wed Apr 11, 2012 12:36 am    Post subject: Reply with quote Add User to Ignore List
Second the Audiofire 12!
Hermetech Mastering | Discogs | SoundCloud | Bandcamp | Facebook | Pathmusick
dzlvs8
PostPosted: Wed Apr 11, 2012 7:10 am    Post subject: Reply with quote Add User to Ignore List
Damn this is good info. the audiofire 12 looks very affordable. unfortunately my laptop doesnt have a pcmia slot OR fire wire, so im out of luck at the moment. I probably will get a desktop replacement. I dont like my laptop anyways.
the only thing I dont think I like about the audiofire is that it doesnt have one output. I dont understand how that works? do I just assign one of the 12 outputs to carry all sound or does each channel output strictly only output what it receives from its input after being processed in the co
puter?
It sounds like i need a mixer after my outputs of the audio interface with the audio fire.
That would be a no no for me because a majority of the time, i would still like to bypass the computer when playing. I have done some research and am excited about the benefits of the multi channel recording, but I absolutely do not want to be a slave to the computer for even just diddling around.
Light you suggest a mixer with a separate output for each channel so i can run each channel separately to the multichannel interface but still have the capability of using the otb mixer main out for dissling around? Areyou getting frustrated with my stupid questions yet?
Manual Gain Rider
PostPosted: Wed Apr 11, 2012 7:49 am    Post subject: Reply with quote Add User to Ignore List
re audiofire stuff:
you do all the routing with the audiofire in software. there is a software mixer, where you can assign NONE/ONE/ANY/ALL of the inputs to NONE/ONE/ANY/ALL of the outputs. might take a little while to get your head around it, but once you do you can pretty much route things however you like.
i had mine setup with outputs 11 and 12 hard panned L and R, and used as my "main" PC outputs, going to the monitors. outputs 1 and 2 fed my two bus/mastering chain, outputs 3 and 4 fed my innerclock systems sync lock etc. was a very flexible system.
inputs were from the mastering chain, from the modular, from the various effects returns etc. it certainly was VERY easy not to have to deal with a physical mixer any more.
you can also use it in "standalone" mode, which means that however you have the software mixer configured when you power down, it will stay like that even when the PC is not on. so you can have a setup you like for tweaking and playing, and not be tied to the PC.
only sold it as i upgraded my converters and didn't need all the ins and outs any more. you should be able to find one second hand for around $400.
there a million ways of doing what you want to do, but it's about narrowing it down for what's most ergonomic for you.
lilakmonoke
PostPosted: Wed Apr 11, 2012 7:58 am    Post subject: Reply with quote Add User to Ignore List
if the rme ufx is too expensive just get a fireface uc, they are around 600 used. now that the ufx and its smaller version the ucx are out prices should even come down more. nothing beats total mix especially for complex multi input setups. my fireface uc is really the most important part of my studio.
http://soundcloud.com/lilakmonoke
im buying 90s sequencers/samplers in europe, yamaha QY, kawai Q-80, alesis mmt-8, roland mc-4 or SQ10 etc. i need them all!
dzlvs8
PostPosted: Wed Apr 11, 2012 8:08 am    Post subject: Reply with quote Add User to Ignore List
Wow I love you guys. Something like the audio wire sounds perfect. When I do quick recording and playing around with the looper, I never tweak my mixer so something like the audio wire would be perfect. I assume having the audiowire "disconnected" from the computer would then allow me to just jam along with youtube videos with my normal sound card like normal too!
So is there anything comparable to the audiofire 12 that is usb 2.0? Will it have latency? I may just want to test something like this out before I go all gung ho and sell my laptop to get something with fire wire (although I am totally fine with selling my laptop) I dont need it. It sits under my coffee table 24/7 and is connected to my tc and klipsch rrf7 eference speakers. i used to need a laptop so i could take it to the can with me grin but I use my cell phone now. tmi?
Can anyone recommend a good knobby midi controller (not a keyboard) that I can use for controlling mixing on the pc? I havent seen anything like that besides the crappy $40 Korg Control thingys? and i assume I will need a midi interface for this?
ive come a long ass way in a day. this is sweet!
Manual Gain Rider
PostPosted: Wed Apr 11, 2012 8:24 am    Post subject: Reply with quote Add User to Ignore List
i've been lusting after one of these for ages:
http://www.kentonuk.com/products/items/midicontrol/kmix-mini.shtml
pipwilliams
Last Visit: 20 May 2013
PostPosted: Wed Apr 11, 2012 9:32 am    Post subject: Reply with quote Add User to Ignore List
Behringer XENYX X2442 mixer (or ones with fewer channels) will record straight into computer via USB. Much cheaper and will bypass audio interface
http://soundcloud.com/pipwilliams
shamelesstoady.com
dzlvs8
PostPosted: Wed Apr 11, 2012 11:05 am    Post subject: Reply with quote Add User to Ignore List
Ive seen those. My current mixer is a small Berhinger xenyx and although it LOOKS like a mixer its really just a pile of crap. From a quality standpoint, Iv'e never had any audio product as pathetic as a berhinger.
So i wont go with that x2442. But I am interested in an all in one deal if its way cheaper and I can bypass a midi controller. I have a feeling that the sound quality may not be as good.
I saw an alesis multimix 16 that interested me but I dont know if there is an audio return channel from the computer to the mixer. This is a must because I need to record to the computer while playing along with recorded loops that are on the computer....and I want all the sound to come out of my amp without sending sound back out of my crappy laptop sound card. I will figure out how this works and if an all in one is ok for me.
But for now, I think I have a somewhat clear idea of my options. My last question will allow me to take the first step towards building a much mess pathetic recording setup, without getting too complex.
My question is, if I am looking to record up to 16 channels in and one channel out simultaneously and my laptop already has a wireless usb mouse, a wireless usb keyboard, and a few things charging off of a usb splitter, I probably cant go with something that is USB 2.0 without introducing latency or errors in the audio. I aasuke I need to go with firewire and that means my first step is to get a different computer (since my laptop has no firewire OR pc card slot!!!!) ...and I assume its still ok to use a pc without introducing any lag over a 7ms or whatever.
If someone can answer that I think i will be all set....for now......on that issue. I really appreciate all the quick help.
...oh yeah, and if a new computer with firewire is what I need, given my high concern for lag, should I buy a high end PC or a 5 year old Crapple Mac? If latency will be marginally different and still extremely undetectible/unsensible, Id much rather stick with pc.
Manual Gain Rider
PostPosted: Wed Apr 11, 2012 11:53 am    Post subject: Reply with quote Add User to Ignore List
i'd agree with your fine assessment of behringer gear. steer well clear and you can't go wrong! never owned any and never will, for so many reasons.
Manual Gain Rider
PostPosted: Wed Apr 11, 2012 11:55 am    Post subject: Reply with quote Add User to Ignore List
i think usb 2 could struggle. ditch your laptop and get a desktop with pcie and firewire, loads more reliable choices then.
dzlvs8
PostPosted: Wed Apr 11, 2012 12:31 pm    Post subject: Reply with quote Add User to Ignore List
Babaluma wrote:
i think usb 2 could struggle. ditch your laptop and get a desktop with pcie and firewire, loads more choices then.
awesome. VERY good to know thst before I became frustrated with the wrong purchase. Due to my very high concerns about latency, am I better off with a high end pc or a 5 year old apple computer?
If I even SENSE the slightest bit of delay or mushiness in my live playing when going through the computer I will be reverting back to the ol looper pedal and video camera. Like this sloppy funk track.
[video]https://www.youtube.com/watch?v=0L1sLfZBpzw&feature=youtube_gda ta_player [/video]
and this EXTREMELY sloppy synth track. Bcuz of the looper I end up being stuck with loops with major errors. Hence the 5/4,4/4,3/4 ryhthm and atrocious live drums on a drum machine while hitting the record button on the looper. haha. >:( <---not actually funny.
[video]https://www.youtube.com/watch?v=v-tGNo0VFFI&feature=youtube_gda ta_player[/video]
Manual Gain Rider
PostPosted: Wed Apr 11, 2012 12:39 pm    Post subject: Reply with quote Add User to Ignore List
i'm mainly mastering 2 channel stereo, and monitoring the output, so latency is not so much a concern for me, but i have a new carillon audio PC, with an RME HDSPe AES interface (with external crookwood converters), using audiomulch 2.0 as my main DAW, and i can get very low latency without glitches or drop-outs. i can play guitar with effects and monitor it all in real-time through the ADC/DAC chain output without noticing any delay.
dzlvs8
PostPosted: Wed Apr 11, 2012 1:00 pm    Post subject: Reply with quote Add User to Ignore List
wow, I dont know what half that stuff ia, but it sounds nice! haha. i wohld love to hear of other peoples high count multi channel audio interface / computer setup and their latency iasues, or lack there of.
CalvaryBand
PostPosted: Wed Apr 11, 2012 4:16 pm    Post subject: Reply with quote Add User to Ignore List
Put together a PC; don't worry about getting an Apple. They make decent laptops but PC desktops pretty much trounce Apple desktops these days, ESPECIALLY since you can turn them into a hackintosh and run OSX straight off of a PC (if you use the right components, that is). I just setup a new desktop with both Win7/Lion and it was actually quicker to install Lion than Win7...
I think having a bias towards firewire is unnecessary in this most recent age of audio interfaces. There have been legitimate strides in the technology put into place in some of the newest USB 2.0 interfaces. I actually prefer USB interfaces as I seem to run into less hassle when it comes to power/sleep/hot plugging compared to Firewire. There is no benefit when it comes to latency either; my laptop runs the USB RME Babyface at 4ms roundtrip.
dzlvs8
PostPosted: Wed Apr 11, 2012 6:37 pm    Post subject: Reply with quote Add User to Ignore List
Oh thank god! I didn't want to have to buy an apple. But what components do I need to have in order to be able to dual boot windows and osx?
4 ms is awesome. I really cant believe just one crazy dude who tells me usb 2.0 will be fine when I want to run a 12-16 channel interface. Its hard to judge this because all the google search results that i find on the topic of usb 2.0 performance are from a few years back. Or the posts are always about someone having an issue with their usb setup.
At any rate, I dont think it will cost much to add firewire to the PC I will build. I needed something to push me over the edge and get rid of this laptop and now I will finally do it. My non-audio centric friend is going to help me build a pc online tomorrow. Does anyone have any pointers on specific audio related pc hardware to buy when building a new pc? Specifically the sound card, and anything else I need to be concerned about.
Here's what I will get (at a minimum):
i7 processor (the one i will get will be fine
6gb ram (
pci-e fireware card
GTX 460 graphics card.
7200 rpm or higher hard drive (should I get two and do raid0? for faster access/writing of 16 channels simultaneously?)
Oh yeah, and after some of the recommendations on audio interfaces, I feel that it is necessary to state my computer budget. $800 MAX
...I don't know what i need to be concerned with for specs as far as audio is concerned. I do know that for movie and gaming purposes, I need an optical out for multichannel digital audio (no hdmi on my audio receiver) but thats all I know I need/want. I know nothing that i need to be concerned about for audio related purposes.
Dammit, a few posts back I said I had only one more question. I guess I lied. But if I can get some help on building my PC, I will be busy building that for a week or more. So I will have to shut up unitl its built and all I can do is think about whats to come. fap fap fap... fap fap fap... fap fap fap... fap fap fap... fap fap fap... fap fap fap... fap fap fap...
lilakmonoke
PostPosted: Wed Apr 11, 2012 7:35 pm    Post subject: Reply with quote Add User to Ignore List
RME fireface UC is usb 2! ... and nobody records with 12 synths at the same time. the UC will give you 8 ins and is easily expandable via ADAT to 16. firewire on a PC with windows 7 has been a nightmare for me until i switched to usb. its ok on apple but basically a discontinued format.
dzlvs8
PostPosted: Wed Apr 11, 2012 8:09 pm    Post subject: Reply with quote Add User to Ignore List
Hmmm, I want to believe your opinions on USB, but the statement above is somewhat false. People record 12 ins at once a lot. I will definitely do at least six at once because my drumtraks drum machine has six channels on it.
I also have everything under the sun plugged into USB on my current laptop. Firewire or usb doesn't matter, I'm still going to build a desktop for multiple reasons and sell my laptop.
If I understood correctly, someone mentioned (maybe not here) that i can install a USB 2.0 that runs separately from the other USBs. As is, the bandwidth of the USB connection is not shared with the bandwidth from the other usb connections (similar to how firewire works). Therefore, more bandwidth for everything?
I WILL be doing six channel recording at once and will have my phone, keyobard, and mouse at the least connected to USB. I don't know if this is a situation where someone would want to go with a usb audio interface, rather than fire wire?????
I have a drumtraks drum machine that has six channels on itl
CalvaryBand
PostPosted: Wed Apr 11, 2012 8:35 pm    Post subject: Reply with quote Add User to Ignore List
Well if you're looking to do OSX/Win7 this page should help you out when deciding on parts. You have to read up on it a bit but there are really good guides on getting OSX on your PC. I would personally skip out on harddrives and get a SSD (or two). The performance difference is pretty huge when loading/auditioning samples. The parts you have listed sound good, only changes I'd make is get 8 GB RAM rather than 6 GB and unless you have a spare 460 around or can find a really good deal on one, get instead a Radeon 6850 or 6870. When shopping for a firewire card, look for a TI chipset model. An easy way to tell is by checking out a picture of said unit and looking at the biggest chip (usually located in the middle of the card); it should have the TI logo right on it. These have been known to perform better than the VIA and other assorted chipsets.
If you're worried about the USB on your mobo becoming saturated you can get an additional USB PCI-E expansion card. This and the firewire card can be found on eBay for next to nothing.
dzlvs8
PostPosted: Wed Apr 11, 2012 8:49 pm    Post subject: Reply with quote Add User to Ignore List
Thanks for the great info, I think I am pretty confident on what to do for my PC hardware now!!!!
but in regards to whats said above, if I put in a new/2nd usb pci-e card, it wont share bandwidth with the other USB ports on another card correct? Therefore, if only my interface is on the usb ports that are part of the new PCI-E card than it wont share bandwidth with anything else and I will have less risk of crashing.
Also, I've heard through the internet that firewire is capable of high constant bandwidth. Does anyone have an opinion on where USB 2.0 on a dedicated PCI card should be able to support 6 or more channels in at once with less than 7ms of lag between what I play and what I hear? or between what I hear and what is recorded?
CalvaryBand
PostPosted: Wed Apr 11, 2012 9:31 pm    Post subject: Reply with quote Add User to Ignore List
Yeah, on my RME Babyface I have had 8 channels going in at once at 4ms. I have also had 8 going into my Allen & Heath USB controller/interface at around 7ms. Keep in mind also that this is not being done on a separate USB card and I have several other things connected at the same time (Maschine, RME Babyface, A&H controller, USB 3.0 external drive, mouse, keyboard, etc). I would not buy the card first and see how it works for you. You may not need it.
lilakmonoke
PostPosted: Sat Apr 14, 2012 8:48 am    Post subject: Reply with quote Add User to Ignore List
the point is not usb or firewire, its the quality of the hardware and the drivers that run the I/O. thats why i keep mentioning RME. there is a reason why practically everybody i know uses rme interfaces. this stuff is rock solid! and again, there is nothing wrong with only plugging in the stuff you are actually using or using a small submixer for drum machines. just keep thing simple is the best advice i can give.
dzlvs8
PostPosted: Sat Apr 14, 2012 12:43 pm    Post subject: Reply with quote Add User to Ignore List
Son of a bitch. I am deeply sorry but I have failed you. I am about to cancel my computer order, not buy an audiofire 12 and go the route of buying a 16 channel mixer and a fast track pro interface or something.
Reasoning:
audiofire 12 channels is not enough
I still would need to buy a new mixer in order to run all my stuff through my Roland Chorus Echo before I went to my computer. I also have no way to run 16 channels separately out of the Chorus Echo. Therefore, in order to use a multichannel interface properly, I would need to swap cables constantly or buy a patch bay, I think. Those both defate the need of needing multi channel anyway.
I also really dont want to be in the box anymore than I have to anyway and I don't want to slow down my creating process anymore than I have to.
I started thinking Nutter! about selling my Arp Odyssey in order to fund the recording setup and thats when I stopped this mess. An Arp Odyssey recorded via a kareoke machine sounds a million times better than recording nothing through an audiofire 12.
So I am just going to run one channel (or maybe two channels for P08) via usb into my current laptop. Assuming I wont get latency on the output.
The price was getting out of hand, and in the end i would only have a more tedious and time consuming setup and more recording features than I currently need.
Question:
Does anyone have a recommendation on a cheap compact mixer with no dsp stuff or other BS. The only feature I am looking for is a quick way to have an output that only outputs a few specified channels (for recording purposes). I think the Yamaha MG16/4 has what I am looking for with "on/off" buttons next to the sliders. I really dont want to have to adjust my mains for each channel when I go to record on one channel
Again, I am sorry. But since I love my current setup, I need to take baby steps back into the box. I get mad when I have to even look at the P08 menu screen, to make music, let alone a computer screen.
jonah
searching for "switch nipples"
PostPosted: Sat Apr 14, 2012 1:21 pm    Post subject: Reply with quote Add User to Ignore List
In regards to your new question I just got an allen and heath zed 10 that I'm finding very useful and pleasant sounding. It has knobs rather than faders, but I only really prefer faders when doing a final mix.
dzlvs8
PostPosted: Sat Apr 14, 2012 1:33 pm    Post subject: Reply with quote Add User to Ignore List
I need at least 12 channels. Preferably 16 channels and it needs to be compact. I noticed that the mackie 1402 has a solo button for each channel. Thats what I'm looking for as far as a feature for recording!
Also, is there any problems with using my crappy, half busted, 6 channel behringer as a mixer for my SCI drumtraks, and then chaining the 6 channel mixer output to one input on a bigger mixer. It seems like that would be ok, but I never see people with that ghetto of a set up.
Manual Gain Rider
PostPosted: Sat Apr 14, 2012 1:59 pm    Post subject: Reply with quote Add User to Ignore List
mackie 1202 vlz3
Rudy D.
Last Visit: 07 May 2013
PostPosted: Sat Apr 14, 2012 2:01 pm    Post subject: Reply with quote Add User to Ignore List
I would get a emu interface and a behringer ADA8000 - the converters are without a doubt good - there are several converter treats on GS - i also worked with this setup until i got myself a linx aurora 16 - Never A/B'd the converters but my tracks doesn't sound better since i got the linx for what my ears tell me - Interfaces with numerous in/out possibilitys are expansive - get the behringer along with a "cheap" 4/4 or 8/8 interface with adat in and out - i would directly record all the tracks to the pc and monitor the stereo out of the daw. Other Possibility - Get the Mackie VLZ 1642 - there you got 8 Direct Outs and 4 Sub-Outs - so you got to record 12 tracks and monitor them over the mixer - it's the pricyest mixer i know which offers these possibilitys... Cheers Rudy
jonah
PostPosted: Sat Apr 14, 2012 2:09 pm    Post subject: Reply with quote Add User to Ignore List
Oh, sorry, I thought you were going to use a patchbay.
dzlvs8
PostPosted: Sat Apr 14, 2012 2:54 pm    Post subject: Reply with quote Add User to Ignore List
Rudy D. wrote:
I would get a emu interface and a behringer ADA8000 - the converters are without a doubt good...
Since you started out with a Behringer recommendation, My first reaction is to ignore your recommendations. but..
I was wondering if mixers had direct outs for its channels. Seems like it kinda defeats the purpose of a mixer but thats what I need. I wish it had more direct outs though...or was more compact. Ideally I would like it to fit on top of my Space Echo, or I will have to build a stand in the only spot left I have for another synth.
Rudy D. wrote:
Get the Mackie VLZ 1642 ......it's the pricyest mixer i know which offers these possibilitys... Cheers Rudy
Im not looking for the most expensive mixer. In fact, something other than a Mackie would be nice, as long as it doesn't break within a year, like my Behringer did. Yamaha, Mackie, ????, ?????
I'm trying to keep the price down on this setup, because I can see my self someday slowly working towards a multi chan interface....maybe.
syzygywell
aligned wiggler
PostPosted: Sat Apr 14, 2012 4:12 pm    Post subject: Reply with quote Add User to Ignore List
I use the 12 chained with an echo audiofire 8 for my studio set up and its quite sufficient.. if I wanted to go with better converters I would really bite the bullet and invest in something very high end.. but these sound good and the price point cannot be beat.
I got mine used for $375 which is probably a little less than usual.
It's been a long time since someone wrote a really good book in jail.
dzlvs8
PostPosted: Sat Apr 14, 2012 11:27 pm    Post subject: Reply with quote Add User to Ignore List
Well, I have bad news and I have not so bad news.
Bad news:
There was a guy from Craigslist the other night that told me everything he could think of related to recording gear. I mentioned that here. Today I bought his Yamaha MG16/4 and Fast Track Pro for $200. Its a small investment that gets me taking a baby step into making a decent recording and if I decide to, I can sell it and not lose money. But I think this setup may be the most convenient for me (I still have a real mixer!)
Not so bad news:
I like how the MG16/4 has a separate ?out? for 8 of the channels. This means that in the future if I feel the need, I can get a new computer with firewire and get an audiofire 12 or an 8 channel rme. ....as long as the outs on the first 8 channels occur AFTER the fx loop.
So thanks for the help. Sorry I didn't take the plunge to multi chan, but this was a quick, cheap fix and is probably all I need. I dont want to be in the box while I'm in the middle of playing music.
By the way, since this thread is about recording gear; the dude I bought the stuff off of seemed to get a bigger boner from mixing and recording rather than from playing. That means he had some pretty cool stuff though. He had sonar running and then as we were there he tried out the wifi/midi app for the ipad that has a midi controller specifically for sonar. THAT is a midi controller I can live with because every knob and button is labeled specifically for sonar and the song you are in. Each track had its name next to it.....man it was sweet. My next purchase may actually be an iPad because I finally saw a use for it. Only problem is that its like a $600 midi controller.
Anyway, I gotta go hook up my new gear and get to fap fap fap... fap fap fap... fap fap fap... fap fap fap...
dzlvs8
PostPosted: Mon Apr 16, 2012 7:56 am    Post subject: Reply with quote Add User to Ignore List
Yep, its me again. So I now have a yamaha mg16/4 and fast track pro and bypassed getting a computer with firewire. .....But last night I actually found an awesome deal and bought a desktop with firewire. So, I am already looking to improve my setup to a multi channel recording setup. Id rather go multi channel than deactivating all channels on my mixer that im not recording
But the problem is i still want to have the capability of the fx routing of my mixer because I use a roland chorus echo. How do I acheive this in the simplest and cheapest way possible if I decide to buy an audiofire 12.
I thought the separate outs for each channel of my mixer would acheive this but the separate outs send the signal out BEFORE it is routed through the effects processor.
Basically I think the easiest way to do this is to get a mixer that has individula outs for most channels (aka, not a mixer) and those outs send the effects loop signal too. any ideas?
lilakmonoke
PostPosted: Mon Apr 16, 2012 9:20 am    Post subject: Reply with quote Add User to Ignore List
:-) there you go! basically everybody has to work his way through a big pile of stuff until you find something that works ... and there are no shortcuts. now that you have the mixer, ever thought about getting a good tape machine/deck? im serious, a direct mix through tape will always sound great.
Manual Gain Rider
PostPosted: Mon Apr 16, 2012 9:58 am    Post subject: Reply with quote Add User to Ignore List
patchbay! lol
a lot of good mixers have individual outs on each and every channel, and they are really mixers. wink
quoting myself from earlier in this thread:
you'll probably need a lot of trial and error, and planning it all out on paper used to really help me a lot.
i recently made things a helluva lot easier for myself by getting rid of all patchbays and mixers, and only ever recording a maximum of two channels at once. twisted
dzlvs8
PostPosted: Mon Apr 16, 2012 10:26 am    Post subject: Reply with quote Add User to Ignore List
what kind of tape recording are you talking about? cassette tape or reel to reel?
In regards to using my delay in the setup, its not possible. Unless i bought 16 space echoes. Theres only one out on a roland chorus echo. so i cant utillize a multi channel interface, and use external effects without doing tons of cable swapping while tecording. Which defeats the whole purpose of multi channel recording. I can just as easily use the channel on off buttons on my yamaha mixer and send only what I am recording. i dont think a patchbay would help.
Now that I will have fire wire is there anything better to use for dual channel recording than my fast track pro usb. I dont care about anything over 48khz.
sydilaxe
PostPosted: Mon Apr 16, 2012 10:40 am    Post subject: Reply with quote Add User to Ignore List
Behringer ADA-8000 isn't a terrible bit. It sounds extremely mediocre, but it is far from useless. Name something else that does what it does for the same price...
dzlvs8
PostPosted: Mon Apr 16, 2012 11:26 am    Post subject: Reply with quote Add User to Ignore List
My feeble little brain is starting to understand exactly what I need. Ultimately I would like an 8 channel interface (2 for my mixer and six for my drumtraks that will never be routed through my tape delay).
So what is a cheap but good 8 channel interface? Is there something cheaper than the audiofire 12? i dont need any mic inputs. what about going with a hard wired pcie card based unit? Anything like that on ebay for less than an audiofire?
jeannot
Ghost Beach
PostPosted: Mon Apr 16, 2012 6:59 pm    Post subject: Reply with quote Add User to Ignore List
This is also how I record. I have an RME Babyface, and its breakout cable just lays on my desk.
I was like you, obsessing over options, and in the end simplicity was the most elegant, and fidelity wise, the best choice I could make.
www.soundcloud.com/jeannot-q
www.4mspedals.com
www.jeannot.tumblr.com
www.jeannotquenson.com
dzlvs8
PostPosted: Mon Apr 16, 2012 9:27 pm    Post subject: Reply with quote Add User to Ignore List
What I'm doing is not obsessing. I'm trying to learn about whats out there. It's called making an informed decision.
dzlvs8
PostPosted: Mon Apr 16, 2012 9:50 pm    Post subject: Reply with quote Add User to Ignore List
SO I've figured out a bunch of stuff and got this stupid piece of crap fast track pro working. The latency at 24/48 with one channel recording is 8.9ms and it is VERY noticable when hearing two tracks that I played the exact same thing on. One track was pre recorded and I played along with it on the second track and there was a noticable delay when on playback of both tracks. This in the box recording seems like a major frickin step backwards with my music. And its really not cool if 2 channels are going to be 17. If my assumption is correct, I should be investing in firewire and something with better a/d converters. Correct? or will I have the same problem with firewire (like, its a HDD write problem and I should just use the feature to shift the track after recording live?
Also, it seems like I can't get very loud before the stupid bast*rd starts clipping. What I mean, is that there is not a very large range of volume between not hearing the stuff and having it clip. Is this me being stupid with the fast track settings or should something like this be expected of lower end devices..or expected of all a/d devices? I'm dumb, but I'm thinking this is what people call head room, or lack of head room?
Probaly my favorite feature of the fast crap pro is the sonic boom it sends to my amp when I power it off or on. >:(
lilakmonoke
PostPosted: Tue Apr 17, 2012 2:22 am    Post subject: Reply with quote Add User to Ignore List
like babaluma said you are riding the horse in reverse. its not about the options you have its about what works for you to get the music you are hearing. once you have that figured out do it as simple as possible.
here is how i work at the moment: i compose strictly by ear, no grid, no scales, no seperate tracks. just one single sculpted sound cloud, if you know what i mean. so all my synths go into the fireface and then are being mixed into one stereo channel with a midi controller. another mix goes into the modular and effects and a tape delay. those two mixes go into a looper vst called moebius that records everything i do. i keep stacking sounds until i like something, then i hit save loop and have an audio file. then later i remix those files into a "finished" track.
that way i can do it all from one midi controller and keys and dials and never have to look at the computer. thats a very fast way of doing ambient music for me. if i did techno i would have to completely redesign the whole process. dig?
dzlvs8
PostPosted: Tue Apr 17, 2012 7:51 am    Post subject: Reply with quote Add User to Ignore List
Dude, that doesnt make any sense. You I need ti understand what is out there and how it works before I can figure out what works best for my needs. Maybe you should start from the begining and see how this started. it started with me listing my needs and then people have been making suggestions on what might work best for my setup.
Im first testing out this fast track pro, to see how i like everything, but Im trying to find out why more expensive interfaces are more expensive, besides because they have more inputs.
Does something like an audiofire 12 or presonus firepod have better sounding a/d converters. I dont know if its just me but the fast track seems to sound pretty terrible. Also the head room seems shitty. Maybe I just need to do more tweaking of the knobs??? Will something like an audiofire 12 or firepod have noticeably better head room and a/d converters resultinging in sonic improvements even if still recording at 48khz?
jonah
PostPosted: Tue Apr 17, 2012 11:36 am    Post subject: Reply with quote Add User to Ignore List
I know the focusrite and rme software has a feature where you can send audio from the inputs to the outputs with no latency for monitoring and what have you and still send that audio into a DAW for recording. I think MOTU can do something like this and from reading other people's posts the Echo seems to be able to do this too.
RME's software felt way less maddening to me than focusrite's.
I'm curious as to why you want to get so many separate tracks into the computer at once? I only ask because it sounds like you don't want to do a lot of post recording mixing and editing.
I can think of some ways to integrate live playing and computer recording, but I really think you're going to go mad with timing issues if you try to get any processed or recorded audio out of the computer without stopping playback.
Now, if you don't mind stopping playing and syncing your live playing to the computer you could do something like use the AUX sends on a mixer into the computer and send a few separate tracks into Live, do a rough mix, send the stereo out of live into the mixer, start playing along, repeat the process of sending AUXs to new tracks in Live, stop re-sync, rough mix, go back to playing, etc.
I'm the same about like liking to work live and quickly and I run a bunch of smaller mixers on the way into a zoom r24. Maybe if I had a second computer and an engineer to record and mange tracks for me I could make it work, but when I tried to use the computer for recording, playback, sequencing and effects I'd always end up making some stupid audio routing error.
dzlvs8
PostPosted: Tue Apr 17, 2012 12:56 pm    Post subject: Reply with quote Add User to Ignore List
my fast track pro seems to be lag free for playback from the computer and live playing. its just the recording issue with latency thwt I have and I havent been able to get the auto correct to work in cubase yet.
Im just concerned about head room and a/d conversion sound quality.
I want 8 inputs because I want stereo in for my synths and i want six more channels for my sci drumtraks, which is a six channel drum machine.
jeannot
Ghost Beach
PostPosted: Tue Apr 17, 2012 1:43 pm    Post subject: Reply with quote Add User to Ignore List
Why not just mix down before you send to the audio interface.
A few people here have been suggesting that, and from the sound of it, you also would like to be mixing out of the box. In which case, a 16 channel mixer, like a Yamaha MG166 would do just fine to sub mix all of your tracks before sending the stereo outs (mixer) to the audio interface. You won't be experiencing the same kind of latency problems, since you will only be listening to the roundtrip latency of two inputs.
You could still use the fast track pro as your interface for the mixer outputs, so all you'd need to find is a decent 16 channel mixer like the MG166, or something equivalent by Mackie, like Babaluma suggested, and you should still be in your price range.
As far as A/D headroom on your interface, obviously make sure you are sending a hot signal from all of your synths. If so, and headroom problem still persists, look for another interface.
edit: also make sure you aren't sending TOO hot of a signal out of the synths. Many will output much higher than a 1.2V line level signal, which is what the interface inputs are looking for.
www.4mspedals.com
dzlvs8
PostPosted: Tue Apr 17, 2012 2:16 pm    Post subject: Reply with quote Add User to Ignore List
I have a spare six channel mixer to mix down the druntraks. the drjm traks also has its one volume level for each drum. BUT after I record the drums I would like to omit the high hat at points, change the levels at other points, etc. and it would be way easier to do with an 8 channel. I know what I want as far as channels. Im just making sure my head room concerns and questionable a/d conversion sound quality thoughts about the fast track pro are valid.
Heres the head room issue explained again:
Basicall if I pump any more signal IN from the mixer/keyboards its loud enough but it starts clipping. If I kee the signal at a reasonable level so Im not in danger of clipping I have to crank up the output to hear it loud and the signal to noise ratio gets really bad.
dzlvs8
PostPosted: Tue Apr 17, 2012 7:17 pm    Post subject: Reply with quote Add User to Ignore List
I spent some more time tweaking and although the method of using a fast track causes a higher signal to noise ratio, its not really that bad. I found a sweet spot. I just really think this is all becoming a pain in the ass because there my signal does this shit.....
synth to mixer gain, to channel level, to mixer level, to fast track input level, to fast track output level, to amp level.
I also fixed the latency issue. Although Cubase was set to auto correct recording latency, it didn't automatically calculate the latency. WTF?!?!?! Why the heck wouldn't Cubase just auto calculate it based on the maudio latency call out and sample rate?!?!
Anyway, I'm all set for now. I will end up getting a multi channel as soon as I save up for one. Now it's on to Microphones.....
Manual Gain Rider
PostPosted: Wed Apr 18, 2012 3:36 am    Post subject: Reply with quote Add User to Ignore List
your interface should have more than enough headroom to record sound at a reasonable level without clipping (unless it's broken), as that is what it was designed for.
if it is recording fine but SOUNDS too quiet in your room, then you need to adjust the monitor gain upwards in order to compensate. everyone should get used to using their monitor gain frequently. it's necessary to have different monitor gains for tracking, mixing, mastering and listening back to commercial albums. the gain knob on my monitor controller is the most used knob in my studio. smile
pipwilliams
PostPosted: Thu Apr 19, 2012 9:54 am    Post subject: Reply with quote Add User to Ignore List
Yep the RME UCX has firewire and USB2 as well as the Total Mix FX software for very flexible routing. There is virtually zero latency and it sounds unbelievable.
I was never convinced when people told me to get a real quality audio interface, but now I have one I don't know how I got by without it! A HUGE difference to what I was using before in terms of quality, so clean and no noise at all. A lot of money but it's an investment.
shamelesstoady.com
dzlvs8
PostPosted: Thu Apr 19, 2012 10:42 am    Post subject: Reply with quote Add User to Ignore List
Thanks for the tip. It better be nice, for ten times the price of an ok/shitty interface.
Is there anything thats good a very clean, high quality, sound that ia cheaper that can be installed in my pcie slot on my new desktop. Ive seen some cards that have ?serial? ports on the and then you plug in some dingle dangle type thingy that gives you a bunch of analog ins. Or those any good. Ive had an maudio mdii controller keyboard before and it was a big pile of shhit, so I dont trust maudio. but to give an example of the type of cadd Im talking about, there is an maudio delta 1010. I know rme makes one too and its cheaper than a fireface. Anyone had experience with them?
CalvaryBand
PostPosted: Thu Apr 19, 2012 11:39 am    Post subject: Reply with quote Add User to Ignore List
I had the RME Multiface for a while; it is that kind of PCI w/ Breakout Box solution that I believe you're speaking of. Look for a Multiface II, they're great.
dzlvs8
PostPosted: Thu Apr 19, 2012 12:28 pm    Post subject: Reply with quote Add User to Ignore List
Dude thats still like $850. I dont want to spend more than $500. anything more and id rather spend it on a synth. no matter how unbelievably amazing the $1k piece records. Ive heard albums that aound good with a firepod and those arent near $1k
Manual Gain Rider
PostPosted: Thu Apr 19, 2012 2:04 pm    Post subject: Reply with quote Add User to Ignore List
then buy a firepod? lol
dzlvs8
PostPosted: Thu Apr 19, 2012 2:57 pm    Post subject: Reply with quote Add User to Ignore List
YEAH WOW thats funny!?!?! i only asked about a firepod a few posts ago with no response on sound quality of it. SOOOOOO is a firepod any better than my fast track pro, if I ignore the fact that I gain more inputs? Is there something in the same $400 price range that is better? MAYBE SOMETHING thats in the pcie card form factor?????????
Manual Gain Rider
PostPosted: Thu Apr 19, 2012 3:34 pm    Post subject: Reply with quote Add User to Ignore List
Om
twisted
lol
dzlvs8
PostPosted: Thu Apr 19, 2012 3:42 pm    Post subject: Reply with quote Add User to Ignore List
very frustrating pcie?
Manual Gain Rider
PostPosted: Thu Apr 19, 2012 3:48 pm    Post subject: Reply with quote Add User to Ignore List
i think pcie should be more reliable and have greater bandwidth than any usb or firewire device, but not sure so don't quote me.
i've been pretty amazed with how great and smoothly things have gone since i switched from echo to rme last summer. i thought echo was great (and it is), but the driver stability with rme is just incredible, as is the bundled digicheck software, and overall "invisibility" of it all (as far as user interface and sound qulity goes). i currently use an hdspe AES with external converters btw.
CalvaryBand
PostPosted: Thu Apr 19, 2012 7:33 pm    Post subject: Reply with quote Add User to Ignore List
Just buy a multitrack recorder and be done with it. It sounds like you don't want to spend that much on a soundcard and when combining that with the fact you have stated you do not like working with computers anyways, it's a pretty obvious choice. Multitracks are cheap as hell now that everyone uses computers.
dzlvs8
PostPosted: Thu Apr 19, 2012 8:59 pm    Post subject: Reply with quote Add User to Ignore List
Sorry, Id like to cut up tracks and stuff once in a while. Bybsaying that its sounds like I dont want to spend much money on an interface and therefore shouldnt get one, are you saying I cant get a decent 8 channel interface for $400 used????!!!!?
pipwilliams
PostPosted: Fri Apr 20, 2012 3:27 am    Post subject: Reply with quote Add User to Ignore List
How about the mAudio 2626? You can pick them up on eBay for around £250
I was tempted with that myself but I've cut so many corners with audio interfaces in the past that I decided to shell out on the RME. I'm not disappointed in the slightest. I guarantee you will notice a difference the more you spend... In fact I did an A/B with the RME and a friends 2626. Big, big difference. But like you say good music is released using cheaper gear. The 2626 would still give you good results.
EDIT: typos hihi
shamelesstoady.com
CalvaryBand
PostPosted: Fri Apr 20, 2012 2:28 pm    Post subject: Reply with quote Add User to Ignore List
I have gone through a lot of soundcards in that range looking for something adequate to bring on the go with me; M-Audio, MOTU, NI, Alesis, Mackie, god, so many others I don't even remember. They were all not-so pleasant of experiences, either because of technical glitches, odd limitations (latency usually) or crappy build quality. I'd get something Echo or save up for an RME (I guess I have already said this, yet here we are). Do what I did and just sell one of your old keyboards to make your recording chain complete. Your other 11 will thank you for it.
dzlvs8
PostPosted: Sat Apr 21, 2012 12:19 am    Post subject: Reply with quote Add User to Ignore List
Yeah, its me again. I'm going to F'ing lose it. So I got my new desktop computer and as soon as I plug in the fast track pro I get high pitched whines, static, and chirps, that are in sync with hard drive activity and video card activity! F--- YEAH! Guinness ftw! Guinness ftw! Guinness ftw! Guinness ftw! very frustrating very frustrating very frustrating
I dont even need to have the fast track turned on or have anything plugged into the input. I think it has something to do with my computers power supply or something else. My laptop doesn't do cause these sounds and these sounds are not crackles and pops of the sound cutting in and out. Like I said, I can have the power off on the fast track and have nothing plugged into the input of the fast track. As long as the computer is powered on (doesnt even need to be fully booted) and I have the usb plugged in, I get static and high pitched noises and chirps....LOTS. The more activity I do on my computer, the worse it gets, and if I boot up a game, I get really freakin bad buzzes, but nothing is 60hz.
So ANYWAY, my question is, has anyone ever ran into this and will a different/better interface not have these issues. I'm pretty sure it has to do with the fast track receiving dirty power. I have a feeling a different/better interface wont help.
dzlvs8
PostPosted: Sun Apr 22, 2012 7:41 pm    Post subject: Reply with quote Add User to Ignore List
Well.....some of you may not be surprised by this but confused
....I broke my fast track pro. hyper
That thing is a piece of crap. When I get some more money, I am going to buy something better. I have found out that on some of the higher end stuff, the companies actually call out there signal to noise ratio and their dynamic range. Those were the two things that I thought were poor with my fast track pro.
I'm still not going to step into the $1000 range. I want to stay at $500 or below and I guess 8 or more inputs would be nice,, but I really only need one input. I cant take advantage of multiple inputs because of how i want stuff set up (effects loops) Btw, I cannot afford anything that is RME.
I'm REALLY leaning towards the audiofire 12 but I wish it had a mic input. If its not the audiofire, I have been looking at one RME item. The HDSP 9632. Its only PCI and not PCIe, ....so whats that gonna mean for me? I don't care about recording lag because Cubase adjusts for the latency, but I do care about live monitoring lag. I cant afford the PCIe version of the card. Not sure why it costs so much more. ....Well, what I mean is, I'm not sure why PCIe is better than PCI if Cubase compensates for latency.
FYI, These are what I have come up with so far for choices in the $500 and under ebay price range.
Echo Auofire 12
Delta 1010
mauido Profire 2626
Maudio Prostudio 610
RME HDSP 9632
If anyone hasn't lost hope in my quest, thanks in advance for the reply.
lilakmonoke
PostPosted: Tue Apr 24, 2012 1:40 pm    Post subject: Reply with quote Add User to Ignore List
this is hilarious, i think by now we have gone through every possibility and you are back to square one. just buy a few more crappy interfaces and find out for yourself ... or buy quality and start working. an rme fireface uc is around 600 and on the way down but i said that before. im done with this thread.
Manual Gain Rider
PostPosted: Tue Apr 24, 2012 2:11 pm    Post subject: Reply with quote Add User to Ignore List
lol
exactly, me too!
"you get what you pay for", i learnt that a LOOOOOOONG time ago.
jeannot
Ghost Beach
PostPosted: Tue Apr 24, 2012 2:18 pm    Post subject: Reply with quote Add User to Ignore List
RME HDSP 9632
You would still need an ADAT or SPDIF channel strip to expand beyond the single stereo input it comes with. Which should give you an idea of how the quality of the other sub $500 interfaces you listed, stack up against the RME.
very frustrating
www.4mspedals.com
Manual Gain Rider
PostPosted: Tue Apr 24, 2012 2:27 pm    Post subject: Reply with quote Add User to Ignore List
i was kinda freaked out when i bought my last interface. it's an RME but contains no preamps, no line ins or outs, and no converters, and yet still cost me about $1000. wink does it's job EXCEEDINGLY well though.
jeannot
Ghost Beach
PostPosted: Tue Apr 24, 2012 2:45 pm    Post subject: Reply with quote Add User to Ignore List
Looks like we've all exhausted the options
Let's dance The Chewbacca Defense The Chewbacca Defense
www.4mspedals.com
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear All times are GMT - 5 Hours
Page 1 of 4
