| View previous topic :: View next topic |
| Author |
Can someone explain logic modules to me pls... |
simulcast Common Wiggler
 Posts: 160 Location: Brisbane, Australia
Posted: Wed Apr 18, 2012 11:52 pm Post subject: Can someone explain logic modules to me pls... |
So apparently I need a logic module. I have a vague idea of how they work but can someone break it down for me as if I had no clue at all...btw, I have no clue at all
I figure it's a great way to create variations using a set of rules yeah?
I'm specifically looking at the Plog so any guidance on this module would also be ace.
Cheers! |
| Back to top |
rico loverde Super Deluxe Wiggler
  Posts: 3535 Location: Portland, Oregon
| Back to top |
30ohm Wiggling with Experience
  Posts: 315 Location: SF
Posted: Thu Apr 19, 2012 12:46 am Post subject: |
| The plog is great, i just got one - but yeah watch the cigler vids, they give a great explanation of applications. |
| Back to top |
BrotherTheo Veteran Wiggler
  Posts: 527 Location: Portland, Oregon
| Back to top |
Ray Diode El Popo
 Posts: 206 Location: Crab Nebula, AUS
Posted: Thu Apr 19, 2012 7:40 am Post subject: |
here's your logic module  _________________ Alphatown | Phonku Bot | Oscillator Repair Team
| Weird Fiction Records | |
| Back to top |
hiawog Ultra Wiggler
 Posts: 917 Location: screwston tx
Posted: Thu Apr 19, 2012 11:36 am Post subject: |
logic is realz fun. this might help to start?
| Back to top |
| Back to top |
shaft9000 is dead
      Posts: 2719 Location: Van Nuys, California
| Back to top |
hiacynt Learning to Wiggle
 Posts: 3 Location: Lodz, Poland
Posted: Thu Apr 19, 2012 12:20 pm Post subject: |
shaft9000 ---> You are THE BEST!  |
| Back to top |
albiedamned Wiggling with Experience
 Posts: 386 Location: Maryland
Posted: Thu Apr 19, 2012 1:22 pm Post subject: |
| I understand the logic itself (I'm a computer programmer so I better), but what I need help understanding is the musical application of logic modules. Anyone care to take a crack at that? What patches do you use these modules in, and in what roles? |
| Back to top |
newgreyarea Super Deluxe Wiggler
    Posts: 1236 Location: Downtown Los Angeles
| Back to top |
bodo Wiggling with Experience
  Posts: 406 Location: Antwerp, Belgium
Posted: Thu Apr 19, 2012 4:47 pm Post subject: |
Well, the Plog is a great generator of clocks.
Using its several inputs you can get all kinds of interesting clocks (I mainly use mine to trigger the X & Y inputs of a René).
The different logical functions can be modulated, and that's where the fun really starts. A great way to get quite random yet quantized clocks.
But there are many other uses for it of course, the Flipflop works great with a comparator or for resetting trigger sequencers, Pressure Points direction, etc. _________________ http://soundcloud.com/bodo
http://soundcloud.com/bedsore-poet
my setup
| Dr. Sketch-n-Etch wrote: | However, in the meantime, just imagine a synthesizer going "doooooooo" and "eeeeeeee" accompanied by green lines on a scope making perfect triangles, sines, etc.  |
| Back to top |
Posted: Thu Apr 19, 2012 5:37 pm Post subject: |
Thanks for the info...
Got some reading to do. But yes, was also interested in patch ideas for the Plog. I've seen the one in the Plog manual - anyone care to throw up some more?
According to Booleen Hair Logic I am most like an OR output..more of a goatee tho...longer hair on top too! |
| Back to top |
xpander Super Deluxe Wiggler
    Posts: 1048 Location: los gatos, california
| Back to top |
shaft9000 is dead
Posted: Thu Apr 19, 2012 5:47 pm Post subject: |
| hiacynt wrote: | shaft9000 ---> You are THE BEST!  |
thanks for the ego-queef
i didn't create or even host that handy lil' graphic, though. merely passing it on.
a wiser man than i created that gem, and i'm a fool for forgetting who gets proper credit!
| albiedamned wrote: | | What patches do you use these modules in, and in what roles? |
one way to think of it for musical purposes is, say as rhythm generator - a common use of logic. you feed it gates, the output can resemble 'random'...or as random that has some variability based in input selection. whatever it outputs is ordered according to how the logic selects it, and that's that. WHAT you feed it determines it's behavior. it really comes into it's own when teamed with dividers and mixers/busses for "juggling the signals musically", so to speak.
but that's just rhythm/lfo modulation...there also many apps for logic involving audio-rate as well, but i've hardly explored them enough to say what they are good for  _________________ youtube.com/shaft9000 ◄ modcan+euro demo:study
shaft9000.muffwiggler.com ◄ singles:mp3
shaft9000.bandcamp.com ◄ album |
| Back to top |
Mefistophelees USB Cat
 Posts: 305 Location: UK
Posted: Thu Apr 19, 2012 5:58 pm Post subject: |
I got one as an audio processor. Logicing waveforms produces some strange results. The typical detuned oscillators aren't that useful but push their tuning apart more and you can get more interesting results.
You can use the toggle outputs to generate sub octaves. You can then use one of these as a modulator for the original waveform in a different module. _________________ --
http://soundcloud.com/mefistophelees |
| Back to top |
Veqtor Super Deluxe Wiggler
    Posts: 2100 Location: Malmö, Sweden
Posted: Thu Apr 19, 2012 7:42 pm Post subject: |
You could use it for less esoteric stuff like, if A or B is playing then do not play C.
That is: C = (NOT(A OR B)) AND CLK (if A and/or b are driven by this clock)
brackets mean that the function inside the brackets is performed before the one outside, so start with A OR B, then invert it using NOT gate, then AND it with a clock.
Also a lot of fun can be had with comparators, cv and logic _________________ http://www.veqtor.se |
| Back to top |
| Back to top |
