Using POWER module with Metasonix R-series?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
maticmatics
Post by maticmatics » Fri Apr 20, 2012 4:25 pm
Hi all,
Does anyone have any experience using the Flight of Harmony POWER module with Metasonix modules (particularly the R-51)?
I'm trying to find an alternative to the Tiptop uZeus in terms of convenience of use/installation in an open-frame eurorack (Tiptop Z-ears/rails). The uZeus failed to power my R-51 :(
Thanks for your help.
HeWhoWantsJeans
Post by HeWhoWantsJeans » Fri Apr 20, 2012 6:45 pm
According to the specs on the f(h) website entry for POWER, the POWER (with a 12VAC, 1A adapter) outputs 12v +/- at 1A.
And according to the Metasonix page - the R51 requires 12v +/- 150mA.
Going through the manual for the POWER, it would seem that (with a 12VAC 1A adapter) the optimal power consumption of all the modules to be used would be around 600mA. That said, I think you could run it just fine.
The POWER manual also says that a 12VAC 1.5A adapter is recommended, which would likely give you about a full ampre of power to play with.
So - I think it'd work. :hihi:
I've archived over 400 answering machines, and the best of which is constantly updated on Tumblr. Public domain! Enjoy! Donate, too!
http://answerphone.tumblr.com/
http://www.answer-phone.org
maticmatics
Post by maticmatics » Sat Apr 28, 2012 6:56 pm
Great, thanks for the feedback!
Return to “Flight of Harmony”
