Mididac setting up
Author Mididac setting up
rarecomponent
Ive populated the Mididac board and double checked everything....
I want to pre-check for a GATE signal but have not connected the TUNE or BEND / DEPTH or SLIDE TIME pots or the two switches. At the moment the LED doesnt flash with Midi signal in on any channel.
Will the PCB Gate LED function without these connected?
Also I'm using a REF195GPZ:IC VOLT REF 5V in U3 which I'm not sure is correct
rarecomponent
problem solved....would you believe I had a dud LED ???!!!!!!
Midi in and gate signal is working fine.
