Euro power cable advice
Author Euro power cable advice
Bass Clef
Last Visit: 23 May 2013
PostPosted: Fri Apr 26, 2013 6:21 am    Post subject: Euro power cable advice Reply with quote Add User to Ignore List
Hey Wigglers
I'm going to build some CGS modules for my euro system, so going to have to make some cables to plug into a doepfer busboard.
Does this look like the right part to have at the busboard end of the cable?
I think I need a 16-way header, i.e. 2 rows of 8.
16 way IDC header
any help appreciated, my head's spinning from looking at too many different options!
Also, do I really need ribbon cable, or can I just wire +ve -ve and ground wires into that header?
the bad producer
Last Visit: 22 May 2013
PostPosted: Fri Apr 26, 2013 6:46 am    Post subject: Reply with quote Add User to Ignore List
That's the one indeed... Yeah, I think you have to use ribbon cable, soldering wires to that would probably be the worst thing in the world! I've got yards of ribbon cable so I can send you a metre or so for the cost of postage if you like (rather than order a reel yourself) and this would be good for me as I've got so much it does my head in!
BTW for plugging CGS into euro I make a little power adaptor like this:
http://loudestwarning.tumblr.com/
Bass Clef
PostPosted: Fri Apr 26, 2013 7:51 am    Post subject: Reply with quote Add User to Ignore List
Thanks for the tip, and I certainly won't say no to a super generous offer like that!
ashleym
PostPosted: Sat Apr 27, 2013 5:00 am    Post subject: Reply with quote Add User to Ignore List
Dont forget to get one of these to insert the ribbon cable
http://www.rapidonline.com/Tools-Equipment/IDC-Connector-Crimping-Tool -86-0860/?sid=469eca36-8a9f-46c3-bbb5-723d1c248eff
Insulation displacement cable, ie the slits you slide the cable into cut through the insulation and bite into the conductive part of the cable. its a gas tight join- a very good one. It keeps most of the worlds telephony working.
http://soundcloud.com/for-mash-get-ash
RobotDad
PostPosted: Sat Apr 27, 2013 12:55 pm    Post subject: Reply with quote Add User to Ignore List
the bad producer I'm new to modular DIY and that panel wiring is very neat looking to me. It looks like you've brought the wire and insulation up through some of those holes. Is that a form of strain relief and it's soldered on the other side?
the bad producer
PostPosted: Sat Apr 27, 2013 1:10 pm    Post subject: Reply with quote Add User to Ignore List
Hi robotdad, it's not my innovation but Ken Stone's, see his description here:
To use the wire anchor holes:
1) Trim off the end of a suitable gauge of hookup wire
2) Pass it through the larger (pad-less) hole from below and pull a couple of inches through.
3) Strip the insulation from the end of the wire, twist and tin it.
4) Bend the wire over and pass the tinned part through the associated pad hole. Trim as needed.
5) Flip the board and solder the tinned wire to the pad.
6) Pull the excess wire back through the first hole so only a short length remains between the hole and the second pad. Make sure this is the LAST step, or the insulation will peel back from the wire as it is soldered.
I believe there are some pics somewhere on his site, but can't remember where!
(This description is taken from the Gated Comparator page btw...)
daverj
Vintage Video Wiggler
PostPosted: Sun Apr 28, 2013 1:42 am    Post subject: Reply with quote Add User to Ignore List
It's an old trick used on perfboard to strain relief wires.
Dave Jones Design | http://www.jonesvideo.com
