Muff's Modules & More cats and modular synths, but mostly cats
| View previous topic :: View next topic |
| Author |
Incompatibility between QPS2 and C101 ? |
komyta Ultra Wiggler
  Posts: 989 Location: France
Posted: Mon May 14, 2012 2:21 pm Post subject: Incompatibility between QPS2 and C101 ? |
Hello everyone,
Here's a long post about an unexpected behaviour I encountered while using my very little MU system.
First, let me introduce the system :
My power supply is a QPS2 from Synthesizers.com.
The modules I've got so far are :
- Corsynth C101 VCF
- MegaOhm Audio MA20 VCF
- Synthesizers.com Q106 VCO
- Synthesizers.com Q108 VCA
- Synthesizers.com Q109 EG
For the casing, I've got a Synthesizers.com 8-MU wide Rack Frame inside an AllMetalParts 5U, 20 cm deep rack cabinet.
In the months to come I plan to add one more Rack Frame / AllMetalParts cabinet solution, with another QPS2 power supply. The idea is to have a very portable system, whose two 8-MU cabinets would work by themselves for the times when I need only one of them, hence the two little QPS2 power supplies. The total module quantity should not exceed 12.
I've decided to begin my MU system with filters that would be close to my all-time favourite monosynths, the Roland SH101 and Korg MS20.
The filters' ability to self-oscillate is very important for me because I want to be able to use the filters as audio sources or audio-rate modulators when they're not used to filter an incoming signal.
And here comes the problem :
When I first plugged my system in and tried my C101 with the "Resonance" knob set fully clockwise, the filter would not self-oscillate, whatever the frequency at which I would set the "Frequency" knob.
The only way to make it self-oscillate (apart from feeding its audio inputs with incoming sound) was to feed the "Res Mod" input with a DC voltage provided by the Q106 "Pulse" output with the Pulse Width set at 100%. But as the C101 is said to be a self-oscillating filter, I was expecting it to self-oscillate without any help from a fellow module.
After a few hours making sure that I wasn't doing something wrong, I sent an e-mail to Pablo (the man behind the Corsynth brand, AKA Thalassa here on Muffwiggler's), explaining the problem.
He responded very kindly the same day, asking me to do a few tests so he could have an idea of where the problem could come from.
After a few tests and e-mails, it seemed that the module could be faulty. Pablo asked me to ship the module to him, so he could test it himself and repair it if it was needed.
When Pablo tested it, the module was working without problem. He told me that after warm-up the resonance decreased a little bit more than it should, so he changed a few resistors to make it stronger, tested it again to be sure that the level was always the same over time, and sent it back to me.
Here let me write a big THANK YOU to Pablo : he was always very nice, answered quickly and kindly to all my e-mails and paid the shipping for the module from my home to his office and back. Also he was very careful with the module : I'm a little picky about the cosmetic condition of my gear, and the C101 was still as new when it came back to me.
So when the module came back home, I plugged it in my rack and
The C101 would still not self-oscillate!
I wrote back to Pablo, and had the idea to tell him that I powered my system with a QPS2 switched power supply. Also I asked him what power solution he had. He answered that he used a QPS1 and thought that maybe my QPS2 would not provide enough current for the filter to self-oscillate when my other modules were also plugged in. To be sure, he asked me to unplug all other modules, leaving only the C101 connected to the QPS2. First I was I little sceptical, but I did the test and surprise there it was : a gentle, pure but strong sine wave coming out of the speakers!
I then plugged other modules in, one at a time, and discovered that the more modules were plugged in, the more quiet the sine wave would become, before disappearing completely when the fourth module was plugged in.
I reported this behaviour to Pablo, who asked me to measure the voltage at the power supply output when all modules are plugged in. That was (and still is) 14.8V. As Pablo told me, the C101 requires no more than +/-14.5V to be able to self-oscillate. With 14.8V, the module should give a nice 10V peak-to-peak sine wave. So he supposed that the problem comes from the switched power supply, whose ripples could be too high to make it a reliable enough power solution for the C101 in self-oscillation.
That's bad news for me, as I do not plan to upgrade my power solution since it works all right with my other modules, including my MA20 filter in self-oscillation.
The QPS1 would be overkill to power only 12 modules, and quite expensive since I would need to buy modules (Q137, Q103) and cables (2x QDH20, QIC-12) to be able to use it.
The QPS2 price tag is perfect for me !
Also each cabinet would not work by itself anymore, and this is important for me.
Finally, as I have no time for it, I know I'm not going the DIY route.
So I decided to let you fellow wigglers know about that.
Am I the only C101 owner to power it with a QPS2 ?
What do you think ?
Maybe I'll have to separate from a module that I like very much in terms of sound, possibilities and ergonomics because of this little incompatibility
That would be a shame, because Pablo is such a nice fellow. He gave me great customer support. |
| Back to top |
diophantine Super Deluxe Wiggler
  Posts: 1427 Location: San Diego, CA
Posted: Mon May 14, 2012 2:48 pm Post subject: |
Quick question while I'm heading back from lunch...
What other modules are you trying to power from the QPS2? You are possibly trying to pull too much current. |
| Back to top |
Posted: Mon May 14, 2012 3:01 pm Post subject: |
Hi diophantine,
the other modules connected to the QPS2 are only the ones listed above :
- DotCom Q106
- DotCom Q108
- DotCom Q109
Only one of each, no more.
Before buying the QPS2 I checked the power consumption of several module configurations using the DotCom SynthInvent software.
Whatever power-hungry config I tried (with only DotCom modules, of course) the QPS2 always seemed to offer high enough headroom... |
| Back to top |
kindredlost Super Deluxe Wiggler
Posted: Mon May 14, 2012 4:41 pm Post subject: |
Sad to read about the QPS2. Sounds like it is less than capable of powering the small system you have. Your best bet is the QPS1. If the rack cab has a back opening, get another rack frame for the Q137. Then you can get by without the Q103, just one QDH20 harness and you will not need the QIC-12 cable. The Q137 will mount in back and you have the modules in front.
Another way to do this is to buy a separate QPS2 and plug both into a power strip inside the cabinet. I'm cheap so I think like this all the time.  _________________ OpenTape
noises4sale
soundcloud
videos |
| Back to top |
Thalassa Wiggling with Experience
   Posts: 285 Location: Spain
Posted: Mon May 14, 2012 5:29 pm Post subject: |
Hello Komyta , thanks for your kind words about the customer support
The current consumption of the C101 is approx 24 mA so in theory the QPS2 should be enough even with other modules connected. As I told you by mail , seems that when you increase the load on the QPS2 the voltage ripple is too high making the C101 unable to self-oscillate. _________________ New C104 Odyssey of Sound VCO now available
http://www.corsynth.com
Online Shop
http://www.corsynth.com/shop
http://www.facebook.com/corsynth
https://twitter.com/corsynth |
| Back to top |
whitewulfe Chaos beckons, I heed the call
  Posts: 1697 Location: C-YXD (Edmonton, Canada)
Posted: Mon May 14, 2012 6:33 pm Post subject: |
I don't really have any advice to give about the module's behaviour, but given that you're looking at picking up another QPS2, why not chat with Vince about his power supplies? 1amp, and around the $100 USD mark -> http://www.muffwiggler.com/forum/viewtopic.php?t=56165
$25 USD cheaper than a QPS2 as well!
Additionally, as an alternate offering to the AllMetalParts 5U metal cases, Christopher Winkels makes some absolutely wonderfully made 14MU wide fir-core plywood cabinets with a maple veneer. I currently have two, and they go together quite well (and quickly too, even with just hand tools, although I'd recommend actual power tools), and are nice and sturdy. Plus one can stain them whatever colour one wishes! -> http://amherstdesign.wordpress.com/
Thought I'd plug them just in case they weren't know (Errr... I didn't see the shipping costs to the UK/europe, eep! Bad Canada Post, Bad!) |
| Back to top |
Putte Wiggling with Experience
  Posts: 439 Location: Örebro, Sweden
Posted: Tue May 15, 2012 3:12 am Post subject: |
It seems the dotcom power supplies handles a lot less than the information says. Synthinvent tells me Iīve got plenty of power. But about half an hour after patching up most of the system, some modules wonīt work normally any more (The Moon modules).
My system is some 80 % dotcom, counting 63 U:s at the moment and a QPS1. Therefore, Synthinvent isnīt completely accurate. But, it tells me Iīm only using half of itīs capacity.
In summa, I say play safe and plan for a system that only uses about half of the power the QPS:s are supposed to provide. I didnīt, but Iīm going for a larger system and was eventually going to add a second QPS1 anyway. |
| Back to top |
fyvewytches pan galactic gargle master
Posted: Tue May 15, 2012 3:42 am Post subject: |
| whitewulfe wrote: | Thought I'd plug them just in case they weren't know (Errr... I didn't see the shipping costs to the UK/europe, eep! Bad Canada Post, Bad!) |
Yeah and don't forget the import duty and vat and "customs costs" we have to add to it all in the EU. |
| Back to top |
Posted: Tue May 15, 2012 6:55 am Post subject: |
| fyvewytches wrote: | | Yeah and don't forget the import duty and vat and "customs costs" we have to add to it all in the EU. |
Totally forgot about that 20% hit too, but VAT's only on the actual cost of the item, isn't it? |
| Back to top |
Posted: Tue May 15, 2012 7:44 am Post subject: |
| whitewulfe wrote: | | fyvewytches wrote: | | Yeah and don't forget the import duty and vat and "customs costs" we have to add to it all in the EU. |
I'm not sure, I'll have to check. I think the import duty is only on the item but VAT is on both item and shipping. But the VAT rate is not 20%, it depends on which country you are in. For me it's 21%.
I just received a QPS2 last week and paid just under 40 euros in various taxes and charges.
Sorry for being OT ! |
| Back to top |
Posted: Thu May 17, 2012 3:58 am Post subject: |
| kindredlost wrote: | | Sad to read about the QPS2. Sounds like it is less than capable of powering the small system you have. |
Well, it works very well within my system until I ask the C101 to self-resonate. I think the QPS2 isn't that much to blame ; I suppose it should work great with any DotCom modules combination (I'm sure Roger made a fair number of tests), but maybe it's not really good at powering other manufacturers'...
| kindredlost wrote: | | Your best bet is the QPS1. If the rack cab has a back opening, get another rack frame for the Q137. Then you can get by without the Q103, just one QDH20 harness and you will not need the QIC-12 cable. The Q137 will mount in back and you have the modules in front. |
Yeah, I'm sure the QPS1 would solve the power problem.
Like you said, I could mount the Q137 at the back of my cab with another rack frame, and use only one QDH20 harness to power all my modules.
But as I plan to have 2 separate 5U tall, 8MU wide cabinets that should work separately (for ergonomics, transport, and to be able to travel with only one of my too cabinets when I want to), this isn't a good enough solution for me, plus it would cost money...
| kindredlost wrote: | Another way to do this is to buy a separate QPS2 and plug both into a power strip inside the cabinet. I'm cheap so I think like this all the time.  |
I often tend to think that way too !
But I'm not willing to buy a separate QPS2 for only one module...
The C101 is (sof far) the only module that isn't happy with the QPS2....  |
| Back to top |
Posted: Thu May 17, 2012 4:08 am Post subject: |
| Thalassa wrote: | Hello Komyta , thanks for your kind words about the customer support  |
You deserve it !
| Thalassa wrote: | | The current consumption of the C101 is approx 24 mA so in theory the QPS2 should be enough even with other modules connected. As I told you by mail , seems that when you increase the load on the QPS2 the voltage ripple is too high making the C101 unable to self-oscillate. |
Yes, I'm far from being an electrical enginner but this seems to be the right technical explanation.
This is why I think that no one is to blame : the C101 is great and works as expected with a linear power supply (and I think that's what most people have in their system), and the QPS2 works well with DotCom modules but shows it limitations when powering some of other manufacturers'. |
| Back to top |
Posted: Thu May 17, 2012 4:33 am Post subject: |
| whitewulfe wrote: | I don't really have any advice to give about the module's behaviour, but given that you're looking at picking up another QPS2, why not chat with Vince about his power supplies? 1amp, and around the $100 USD mark -> http://www.muffwiggler.com/forum/viewtopic.php?t=56165
$25 USD cheaper than a QPS2 as well! |
Mecanikill's power supplies seem to be a really good, space saving and light solution, and it costs less than a QPS2. But I would still need to buy a QDH20 harness and Q137 module, wouldn't I ?
| whitewulfe wrote: | | Additionally, as an alternate offering to the AllMetalParts 5U metal cases, Christopher Winkels makes some absolutely wonderfully made 14MU wide fir-core plywood cabinets with a maple veneer. I currently have two, and they go together quite well (and quickly too, even with just hand tools, although I'd recommend actual power tools), and are nice and sturdy. Plus one can stain them whatever colour one wishes! -> http://amherstdesign.wordpress.com/ |
Yeah, I'm aware of those good looking cabinets from Mr Winkels.
I really like them, but that's too big for my needs. The AllMetalParts ones are the perfect size for me...
They were known, but the shipping costs are bad, that's for sure.
Anyway thanks for pointing them, that's a good reminder for other people as well !  |
| Back to top |
Posted: Thu May 17, 2012 5:05 am Post subject: |
| Putte wrote: | It seems the dotcom power supplies handles a lot less than the information says. Synthinvent tells me Iīve got plenty of power. But about half an hour after patching up most of the system, some modules wonīt work normally any more (The Moon modules).
Good to know.
So far I planned to use only 6 modules per QPS2 (6 modules per cabinet, one QPS2 per cabinet) and Synthinvent tells me that any of the two little DotCom systems i plan to get should use about +/-165 mA out of the +/-250 mA provided (the +5V consumption is negligible in my case).
Could it be too much ?
We'll wait and see... |
| Back to top |
Posted: Thu May 17, 2012 6:18 am Post subject: |
| komyta wrote: | | Mecanikill's power supplies seem to be a really good, space saving and light solution, and it costs less than a QPS2. But I would still need to buy a QDH20 harness and Q137 module, wouldn't I ? |
Correct, you would need power distribution of some kind with Vince's power supplies.
| komyta wrote: | Yeah, I'm aware of those good looking cabinets from Mr Winkels.
I really like them, but that's too big for my needs. The AllMetalParts ones are the perfect size for me... |
Good to know I'm definitely looking forwards to picking up a few more from Mr Lord of Tweed Manor in a feverish attempt to take over the living room with my "ancient microwave" as one friend called it  |
| Back to top |
wsy Veteran Wiggler
 Posts: 705 Location: near Boston Massachusetts USA
Posted: Thu May 17, 2012 8:01 am Post subject: Occasionally, you just get a cranky module/PSU |
Occasionally, you can just get a cranky module or PSU that don't play well together.
I had a quantizer that would *not* power up correctly 9 times out of 10.
I sent it back, they were unable to reproduce the problem. I figured "solder ball".
Nope. Problem back.
Moved it to two other (independently powered) cabs - worked fine.
Moved it back to the Evil Cab. Problem returns. But the oscilloscope and DVM
show that the power supply is in spec.
I started pulling modules; it got better but never got "right". I finally soldered
a 100 uF capacitor across the +5V to the module and now it powers up
correctly 90+ % of the time, even with the "evil" PSU.
So- you might want to try that. Add some bypass capacitors in the 100 uF
range between ground and +15, -15, and +5 *right at the module*, on the back side
from where the MTA156 (power connector) is. Yes, this is
soldering to the module, so make sure it's OK with the seller first.
But, as they say, "It Works For Me."
- Bill _________________ "Life is short. But we can always buy longer patchcords." - Savage |
| Back to top |
Henfield Better Chemistry through Sound
    Posts: 621 Location: Detroit, MI
Posted: Thu May 17, 2012 9:59 am Post subject: |
| From what I can surmise here, the problem is with the newer " line lump" type of QPS2, which looks like a computer adapter and can accept International voltage? Has anyone had a similar issue with the older style "wall wart" type of QPS2 that only worked with North American voltage/mains? |
| Back to top |
Posted: Wed May 23, 2012 4:22 am Post subject: Re: Occasionally, you just get a cranky module/PSU |
| wsy wrote: | Occasionally, you can just get a cranky module or PSU that don't play well together.
- Bill |
Thank you Bill for your interesting advice and sharing your experience, but I've decided to not follow the DIY road at all...
It's part of my strategy to be able to make music instead of spending my time fixing issues like this one.
I would LOVE to dig in the guts of these mysterious machines
...But sometime you have to make choices if you want to eventually arrive somewhere someday.
Of course it is only a personal statement.
So, as I have no money to buy a bigger / more stable power solution and as my other modules work flawlessly with the QPS2, I think I will sell the C101 and get a Q150 as a kind of replacement (I really need a 24dB/oct LPF)... |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
