| View previous topic :: View next topic |
| Author |
Silent Way+Multiface to send CV/Gate to Moog Rogue |
pr0t0 Common Wiggler
 Posts: 195 Location: Sao Paulo - Brazil
Posted: Thu May 17, 2012 5:09 pm Post subject: Silent Way+Multiface to send CV/Gate to Moog Rogue |
Hi all on Muff
I'm trying to send CV and gate to my moog rogue with Silent Way trough the Multiface Headphone outs, which I heard is DC coupled. Here's what's cooking.
The cabling is a bit fiddly (provided Silent Way support is right):
TRS on my RME multiface headphone out
T to R on one TRS to Rogue's STrigger/VTrigger
R to R on another TRS to Rogue's CV In
that's what i've been told. Set up Silent way on Live as in the tutorials, but can't generate pitch, just a few pops with MIDI and calibration, guess the gate is working, but not the keyboard cv in.
any tips??
all the best
Rodrigo |
| Back to top |
os Super Deluxe Wiggler
Posted: Fri May 18, 2012 3:45 am Post subject: |
As I always say in these situations, simplify things by not attempting to use the Voice Controller right away.
Use Silent Way DC. Route its output to your headphone outs. The two channels of the plug-in should now give you manual control over CV and gate.
By changing the Out level on the gate channel, you should be able to make the synth play.
By changing the Out level on the pitch channel, you should be able to change the synth's pitch if you manually trigger it (e.g. by holding down a key on the keyboard). _________________ http://www.expert-sleepers.co.uk/
http://twitter.com/expertsleepers
http://www.darkroomtheband.net/ |
| Back to top |
bil_g Common Wiggler
  Posts: 160 Location: WV
Posted: Fri May 18, 2012 11:19 pm Post subject: |
Hmm, I didn't realize the Multiface I headphone outs are DC-coupled. It appears the II headphone outs are not(see here).
It might be easier to have the T to the R of the CV In(tip is usually channel one-Left...correct?). It'll make it easier with the default Silent Way routing. That is, if I am understanding your wiring correctly.
...and what Os said. |
| Back to top |
Posted: Mon May 21, 2012 3:52 pm Post subject: |
Hi guys, and thanks in advance.
I tried with DC, but still with no success. I'll try to explain what happens.
I cannot make the synth play by itself by changing DC output values, just pressing a Rogue Key I'm able to control it with a midi keyboard or hear the calibration with voice controller. Channel L with DC changes the pitch. Channel R does nothing, so I assume gate is not working.
In this scenario I'm connecting the T to R stereo cable in the CV in of Rogue. By changing cables on the moog or in the RME matrix, I get the same inversed. Pitch control on the Right channel of DC, nothing on left.
With Voice Controller, after calibration, i get about 2 octaves, but can't trigger the synth with Midi - I just hear it playing when pressing a Moog key.
Could be the cabling? the Ins on Rogue? or its the multiface that can't send proper DC?
hope this helps. thanks again. |
| Back to top |
| Back to top |
Posted: Mon May 21, 2012 10:46 pm Post subject: |
nice... if that's the case, is there ways to multiply this voltage? maybe some inside tweaking on the interface?
cheers |
| Back to top |
giorgio NITE MIND
   Posts: 2411 Location: BRAND NEW YORK
| Back to top |
Posted: Mon May 21, 2012 11:01 pm Post subject: |
hum... is this voltage doubler possible for 1 TRS to 2 TRS cables?
any circuits or links?
thanks |
| Back to top |
| Back to top |
Posted: Tue May 22, 2012 9:47 am Post subject: |
No, there's no volume on the headphone outs on the mUltiface I. For what I understood, that's one of the reasons the 1st multiface has this DC coupled out - the multiface II has a volume knob on it, and it's AC coupled. there's only digital volume in the RME matrix, default -6db, but I can get it to 0db.
I'm a total dumb when it comes to schematics and circuits, but I'll print this and take to someone to make it. Can you specify the right pieces to buy, diodes, etc?
For what I've got I have to make a half-wave rectifier http://www.play-hookey.com/ac_theory/ps_rectifiers.html and place it on... the tip? the ring? or both?
sorry for all these noob questions, I'm just trying to figure out a nice way of playling live with my moog and ableton, without many additional costs.
thanks again
EDIT - I turn the digital out to 0db, and now I get the moog to trigger properly with MIDI, calibrated with Voice COntroller and now I'm getting 4 octaves, which is all I need. So many thanks for your support, now it's time to buy silent way.
all the best for you wigglers!! it's a shiny day!  |
| Back to top |
| Back to top |
Posted: Tue May 22, 2012 5:09 pm Post subject: |
"paypal processing not available" on license manager.
any thoughts OS?
tks |
| Back to top |
| Back to top |
Posted: Wed May 23, 2012 12:01 pm Post subject: |
gone. thanks!
fiddling now, it came to a more specific question regarding live use... What's the best way of changing saved presets (i.e. sequences) on the fly?
should I use several instances of different step LFO/quantizer presets on a big instrument rack, changing the active one with midi?
other thing I wonder is the best way of controlling the step values... I have a 64 knob dopefer dhrebank, thinking about making it my sequencer/quantizer control station...
thoughts appreciated. |
| Back to top |
Posted: Wed May 23, 2012 2:53 pm Post subject: |
| pr0t0 wrote: | | should I use several instances of different step LFO/quantizer presets on a big instrument rack, changing the active one with midi? |
That's a valid approach certainly.
Also, you can use the 96 steps of the Step LFO to hold a number of shorter sequences, then scroll/switch between them with the Start/End parameters.
Or, depending on how much live tweaking you want to do, you could even bake out the sequences to audio clips, and then just trigger them in Live like any other clip.
| pr0t0 wrote: | | other thing I wonder is the best way of controlling the step values... I have a 64 knob dopefer dhrebank, thinking about making it my sequencer/quantizer control station... |
IIRC the first 16 step controls are pre-mapped to MIDI CCs in Silent Way v1.7, and you could extend that with a custom MIDI script. _________________ http://www.expert-sleepers.co.uk/
| Back to top |
Posted: Wed May 23, 2012 4:37 pm Post subject: |
| Quote: | Also, you can use the 96 steps of the Step LFO to hold a number of shorter sequences, then scroll/switch between them with the Start/End parameters.
i guess it's more difficult to change according the song. on live I can have a dummy clip telling to pick a certain LFO sequencer instance as you trigger the scene...
| Quote: | | Or, depending on how much live tweaking you want to do, you could even bake out the sequences to audio clips, and then just trigger them in Live like any other clip. |
i prefer to have the filters and modulation of the synth in hand. that's the beauty of all this
I'll make a midi mapping with the dhrebank to see how it cooks.
thanks |
| Back to top |
Posted: Thu May 24, 2012 2:56 am Post subject: |
| pr0t0 wrote: | | Quote: | | Or, depending on how much live tweaking you want to do, you could even bake out the sequences to audio clips, and then just trigger them in Live like any other clip. |
i prefer to have the filters and modulation of the synth in hand. that's the beauty of all this |
I think you misunderstood. I don't mean record the output of the synth - I mean record the output of the Silent Way modules. Then you can play those clips back as CV automation, still retaining live control over the synth's sound. _________________ http://www.expert-sleepers.co.uk/
| Back to top |
