TM3030 midi out spec ?
Author TM3030 midi out spec ?
lysander
I have been looking through the docs but can't find any info on the midi out.
Does any processing occur on it ( like removing the messages from the input channel ) or is it a midi - thru ?
And is there any measurable clock skew introduced by using it in a midi chain ?
( I have just started my dual TM3030 build so can't test for myself quite yet ).
Synthbuilder
lysander wrote:
...is it a midi - thru ?
It is just a simple midi through. It's generated by the TM3030's PIC so it is not simply a buffered version of the midi input like on the midiDAC for example. Because it is a 'soft-thru' there is potential for some additional functionality perhaps in the future but nothing is planned yet.
As for throughput skew I have not measured it. I did ask Colin (at Sequentix) about it a while ago and he said that the PIC will not produce appreciable skew although the opto-coupler might.
Tony
lysander
Great thanks for the quick answer !
