Moog Slim Phatty CV input?
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear
Author Moog Slim Phatty CV input?
drewtoothpaste
married to the sea
Last Visit: 25 May 2013
PostPosted: Sun May 27, 2012 7:22 pm    Post subject: Moog Slim Phatty CV input? Reply with quote Add User to Ignore List
I can't get my Slim Phatty to play notes upon CV/Gate input. Is there something special I need to turn on somewhere? The manual has generally been unhelpful here.
Do you wear nail polish?! Super Black Lacquers: Holographic, Glitter & Solid Nail Polish
drewtoothpaste
married to the sea
PostPosted: Sun May 27, 2012 7:30 pm    Post subject: Reply with quote Add User to Ignore List
Addendum: I want to be able to feed it a CV/Gate sequence from my Orb (same as I send to my Roland synths or a modular) but it seems to play a sustained note which changes in pitch instead of triggering the VCA envelope with the incoming gate signal.
decaying.sine
Broken <--> Fixed
Last Visit: 26 May 2013
PostPosted: Sun May 27, 2012 7:44 pm    Post subject: Reply with quote Add User to Ignore List
I am not sure about the voltages Drew, but is it possible the Orb doesn't appropriately trigger the Phatty because of either too low voltage or maybe bipolar CV ( -5 to +5) versus unipolar CV (say, 0 to 10 or 0 to 5)?
I don't have either synths, so just throwing some ideas your way.
decaying.sine
Broken <--> Fixed
PostPosted: Sun May 27, 2012 7:48 pm    Post subject: Reply with quote Add User to Ignore List
Just looked it up and Orb looks like it sends 0 - 12V and 0 - 10V for gate and accent out, respectively.
Looks like Slim Phatty is -5 to 5.
Does that mean you need to offset the Orb voltage seriously, i just don't get it
drewtoothpaste
married to the sea
PostPosted: Sun May 27, 2012 7:55 pm    Post subject: Reply with quote Add User to Ignore List
The orb manual says it sends a +12V trigger to the Gate output when a note is played, and the Moog Slim Phatty manual says it takes a +5v trigger, but I'd guess that the Orb's gate output falls to 0 when a note turns off, since it seems to trigger my fully-analog gear OK.
I'm hoping I can just use a different type of cable (TRS with one half unpatched?) or do something in the software editor to allow it to work right.
drewtoothpaste
married to the sea
PostPosted: Sun May 27, 2012 7:58 pm    Post subject: Reply with quote Add User to Ignore List
Hmm, does the gate take -5 to +5? My manual just says "+5v trigger" but maybe this is why it's not working.
decaying.sine
Broken <--> Fixed
PostPosted: Sun May 27, 2012 8:01 pm    Post subject: Reply with quote Add User to Ignore List
Do you have a multimeter to verify the Orb gate output drops to 0? I can't imagine why it wouldn't, and the evidence does suggest it does if it works with your modular.
I remember having a similar sustained note issue with my a-111 and a-190 but that was about 3 years ago, and I don't recall what caused it or how I got it working correctly.
decaying.sine
Broken <--> Fixed
PostPosted: Sun May 27, 2012 8:05 pm    Post subject: Reply with quote Add User to Ignore List
I'd think it'd be +5 on and then to 0 based on the way the manual reads.
Did you see this text in the manual?
"You can use the SP to process any audio signal simply by plugging into the Audio IN jack. To hear the external audio signal without having to hold down a key on the keyboard, plug a dummy plug (or a patch cord with nothing connected to the other end) into the KB Gate jack. This will leave the keyboard gate open, and the volume envelope will remain at its Sustain level until the keyboard gate closes. Due to the design of the envelope circuits, you will need to turn the envelope Decay parameter down below 12:00 in order for the Sustain level to remain constant. If you notice that the volume of the external signal begins to slowly fade away, check to be sure the envelope Decay parameters are not set too high."
Perhaps that is what you were referring to in the post or two previous re. leaving cable unpatched.
drewtoothpaste
married to the sea
PostPosted: Sun May 27, 2012 8:13 pm    Post subject: Reply with quote Add User to Ignore List
I didn't see that, but it sounds like an unpatched cable might normal the gate input to zero which would mean the VCA is open.
I'm working on setting up a Euro sequencing system so offsetting the voltage inside there before sending it to the slim phatty might be a solution, seems like bad design not to let it work with normal CV/Gate signals though!
I do have a multimeter, I'll double-check the orb output next time I'm in the studio.
iamgoldman
One Bad Poster
PostPosted: Mon May 28, 2012 4:53 am    Post subject: Reply with quote Add User to Ignore List
be careful with sending high voltages into the slim phatty. i was sending a +8v pulse from my drone commander into its gate and fried its OSC1 circuit after a handful of uses. it does receive 0+5v, and since the orb sends +12 gate out, def attenuate or something.
EMwhite
PostPosted: Mon May 28, 2012 9:57 am    Post subject: Reply with quote Add User to Ignore List
Phatty Gate will accept either a 'switch close' (normal footswitch) or 5V, some say 5.1V or something obscure like that. It think it prefers a square'ish leading edge but your sequencer ought to do that just fine.
I'm sure that you know that some modules that we typically mess with are very specific about acting on a gate as it crosses 1.8V or something like that. Moog gives no specific info in this regard.
I've had issues with the gate in my Voyager Old School but after getting it serviced/calibrated, no issues but the VOS does NOT accept a switch.
My advice is to certainly keep voltage beneath 10V and better, attenuate the signal down to a tad over 5V and see what gives.
I think you were the one that posted a .mp3 audio that could be used as a sync signal, maybe have a look to see how high from a voltage perspective that rolls. Obviously, you want a gate with a given duty cycle, not just a quick pulse.
If you've got other analog gear (I recall that you do), maybe setup an LFO with a given pulse width attenuated to the 5V range and tweak it to see if you can snap Phatty to life.
CZ Rider
PostPosted: Mon May 28, 2012 11:30 am    Post subject: Reply with quote Add User to Ignore List
Have a Phatty here. You have to go into a menu under MIDI setup and change the gate in setting from sus.ped to gate and it should work. Just tried this out with an MS-20 LFO out into the Phatty gate in. Same result as you had, infinite sustain till I changed the setting, then it triggered from the LFO. Should work now?
UPDATE:
Just tried this with the square wave out from the MS-20 and got the same infinite sustain, although the ramp LFO out triggered fine. Also tried the clock out from an OB two voice and triggered fine also. So it still might be a gate compatability problem from the Orb? On the MS-20 the ramp LFO out is labled as bi-polar -2.5 to+2.5 and the square out is 0 to +5. The square does not seem to work unless I send it through an offset processor. Strange behavior as with a voltmeter the MS-20 square shows 0 volts at low? Must have to go just below into negative voltage to trigger? I'm stumped as to why.
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear All times are GMT - 5 Hours
