| View previous topic :: View next topic |
| $$$ - Which Design would you like to buy? (please only vote if you intend to buy a panel) |
| The left hand panel ('Spirograph + Roman Text') |
24% |
[ 18 ] |
| The right hand panel ('Sweeping Arcs +Bold Text') |
46% |
[ 34 ] |
| I would buy either Panel |
28% |
[ 21 ] |
| I don't want to buy either design. I will start my own Group Buy for different panels. |
0% |
[ 0 ] |
| Total Votes : 73 |
| Author |
[CLOSED] Random Looping Sequencer - Euro Panel Group Buy |
Monobass thonk.co.uk
    Posts: 6633 Location: Brighton, UK
Posted: Sun Jun 03, 2012 2:25 am Post subject: [CLOSED] Random Looping Sequencer - Euro Panel Group Buy |
I'm doing a run of full kits, component kits, panels & PCBs.
http://www.muffwiggler.com/forum/viewtopic.php?p=941192#941192
Orders OPEN. A few panels of both designs left as of 1st Sept 2012. PM me order details as specified in the 2nd post in this thread.
DO NOT REMOVE THE PAPER FROM THE PANEL BEFORE YOU PAINT IT! see quote at the end of this post for a painting guide.
Both designs are available.
Panels are 6 GBP each (approx 9.5 USD).
Shipping will be 2 GBP per order for Europe or 2.5 GBP for World/USA
These panels will be supplied 'as-is', no variations in font or panel colour or design will be available in this run.
More info on Tombola's Random Looping Sequencer project here - http://www.muffwiggler.com/forum/viewtopic.php?t=60740
The design is manufactured in black acrylic, as you can see in this video that material choice is important for the top blinkenlight action - http://vimeo.com/42939320
I used the same manufacturer than Tombola used, 4D Laser, you'll need to do the engraving paint fill yourself. Tombola describes it thus:
| Quote: | | When I got them cut, they put masking tape over the top (ie engraved) part. That makes it super easy to infill the engraved letters with white acrylic paint. |
Obviously you can fill in whatever colour you like. I won't be filling any panels for anyone else, even at extra cost
Here's a good guide for the similar painting technique from the sammichSID build manual, be careful with knives though... maybe the particular panel mentioned here is more resistant to scratching.
| Quote: | The panels are made from laser-cut acrylic and come with backing paper still attached and the engravings
cut through the backing paper. This paper makes an ideal mask for painting the engraving.
IMPORTANT NOTE: You can build the entire sammichSID with the backing paper still on the panels, and then paint the panel engraving after you have finished. This allows you to play with your new MIDIbox SID synth while you paint the panels (a slow process).
The original sammichSID prototypes were painted using acrylic paint, but since then, people have
used other kinds of paint. Gloss enamel paint, like what is used in model making, can be used, and might be preferable to acrylic.
I do not have a “perfect” technique yet, but you can achieve very good results by doing the following:
Find some good acrylic or enamel paint. White paint will work best, colours might appear too dark against the black background. For colours, you could try white paint and then a coloured ink glaze.
Test your technique on a small area of the rear panel, where a big mistake is less obvious and easier to fix.
I suggest the “POWER” label on the rear panel. If doing this, only peel off a section of the mask where
you have added paint.
Using some paint thinned with water, apply the paint into the engraving, minimizing the amount of paint
is left on the mask. Wipe up excess paint with a piece of damp sponge. It is better to apply multiple coats
of thinned paint (at least initially) than thick paint. Avoid the temptation to get it done quickly and slap on
thick paint from the tube, at best this will require a lot of scraping of paint from the mask, at worst there
won't be clean edges to the engravings, which you'll discover after peeling off the mask and making it
very difficult to fix.
IMPORTANT NOTE: You do not want paint sticking between the engraving and the mask, as this will
cause paint to be pulled out of the engraving when you peel off the mask. It's OK if there's a little bit of
paint residue on the mask, that's unavoidable. Wiping up excess paint with a piece of damp sponge not
only avoids this problem, it also makes it easier to see how much paint is actually in the engraving and
how clean the edges are.
Wait until paint in the engraving has dried and apply more paint. Continue to do this until the paint in the
engraving is even and solid. You are aiming for the engraving to still be concave, not totally filled. If it
looks even and you're happy with it, stop adding paint.
If required, use a craft knife to scrape some paint off the mask at the edge of the engraving, i.e. where it
might pull paint out of the engraving when you peel off the mask. If you've wiped up excess paint as you
applied each coat, you might not need to scrape off paint at all.
Slowly pull off the mask, checking how the mask is lifting off near the engraving. Clean up any imperfections using a craft knife. The matte black acrylic surface is quite tough and won't
be scratched by scraping with the edge of a knife. | [/quote] _________________ Thonk - Modular Synth DIY
258J Euro kit - Manhattan Analog Kits- 4ms Kits - Clarke68 Panels - Expert Sleepers Glow Cables - Banana Jacks
| Back to top |
Posted: Sun Jun 03, 2012 2:25 am Post subject: |
Orders Open - Only a handful left
ok I'm taking orders again,
Max order is 2 panels.
I"ll keep going until I've run out of panels.
Please PM me the following text:
| Quote: | I would like to order:
X x Sweeping Arcs Turing Machine Panels
X x Spirograph Turing Machine Panels
I'm aware that I may have to pay additional amounts of customs and tax in my country and that currency exchange rates fluctuate.
I'm also aware that I'm only buying an engraved and laser cut acrylic panel that may help me building an electronic module - I'm *not* buying a diy kit, not a project - just a panel. I understand that the panel comes without any paint infill on the engraving.
My shipping address is
XXXXXXXX
XXXXXXXX
XXXXXXXX
My PayPal address is XXXXXXXX
My Forumname is XXXXXXXX |
Orders
Totals
Spirograph = 77
Sweeping Arcs = 115
theabsent = 0 x Spiro - 6 x Arcs
mig27 = 0 x Spiro - 4 x Arcs
thanatronique = 2 x Spiro - 2 x Arcs
Memory_Leak = 3 x Spiro - 3 x Arcs
amsonx = 1 x Spiro - 1 x Arcs
regenbot = 1 x Spiro - 1 x Arcs
keninverse = 0 x Spiro - 4 x Arcs
L = 1 x Spiro - 1 x Arcs
mckenic = 0 x Spiro - 1 x Arcs
xerxl = 0 x Spiro - 2 x Arcs
mikecameron = 0 x Spiro - 2 x Arcs
FetidEye = 1 x Spiro - 1 x Arcs
en. = 1 x Spiro - 1 x Arcs
Oldstench = 1 x Spiro - 0 x Arcs
defenestration = 0 x Spiro - 2 x Arcs
asterisk = 0 x Spiro - 1 x Arcs
recompas = 0 x Spiro - 1 x Arcs
monstrinho = 0 x Spiro - 2 x Arcs
cr = 0 x Spiro - 2 x Arcs
Protofrangiste = 0 x Spiro - 4 x Arcs
pre55ure = 0 x Spiro - 2 x Arcs
reggiechacha = 3 x Spiro - 3 x Arcs
Oisin = 3 x Spiro - 0 x Arcs
stromcat = 0 x Spiro - 1 x Arcs
rowman = 2 x Spiro - 0 x Arcs
raisinbag = 6 x Spiro - 0 x Arcs
bennybones = 1 x Spiro - 0 x Arcs
Lockheed = 0 x Spiro - 2 x Arcs
sicpaul = 2 x Spiro - 2 x Arcs
tokyomatik = 0 x Spiro - 2 x Arcs
J = 0 x Spiro - 2 x Arcs
citric acid = 0 x Spiro - 1 x Arcs
iopop = 1 x Spiro - 1 x Arcs
paperCUT = 1 x Spiro - 1 x Arcs
Dego = 0 x Spiro - 2 x Arcs
zombieFredrik = 1 x Spiro - 1 x Arcs
ThomasVanTa = 2 x Spiro - 0 x Arcs
oootini = 0 x Spiro - 1 x Arcs
votek_mendo = 1 x Spiro - 1 x Arcs
janvanvolt = 5 x Spiro - 5 x Arcs
NS4W = 2 x Spiro - 0 x Arcs
astroschnautzer = 2 x Spiro - 2 x Arcs
Naturebot = 2 x Spiro - 2 x Arcs
Limpmeat = 2 x Spiro - 2 x Arcs
trainspotter = 0 x Spiro - 1 x Arcs
active = 1 x Spiro - 1 x Arcs
monobass = 2 x Spiro - 2 x Arcs
robotfunk = 1 x Spiro - 0 x Arcs
frozenkore = 0 x Spiro - 1 x Arcs
Lazerkind = 1 x Spiro - 1 x Arcs
Luggi = 2 x Spiro - 2 x Arcs
Oberkorn = 1 x Spiro - 0 x Arcs
Haima = 0 x Spiro - 1 x Arcs
iL = 0 x Spiro - 2 x Arcs
mOBiTh = 0 x Spiro - 3 x Arcs
Juxwl = 0 x Spiro - 1 x Arcs
legs = 2 x Spiro - 0 x Arcs
zdarma = 1 x Spiro - 1 x Arcs
NickB = 1 x Spiro - 1 x Arcs
robert mcleod = 0 x Spiro - 4 x Arcs
spotta = 1 x Spiro - 1 x Arcs
far gon = 6 x Spiro - 6 x Arcs
mamonu = 1 x Spiro - 0 x Arcs
nangu = 3 x Spiro - 7 x Arcs
mattrick = 4 x Spiro - 0 x Arcs
blue_lu = 0 x Spiro - 1 x Arcs
gwaidan = 2 x Spiro - 2 x Arcs
ringstone = 0 x Spiro - 1 x Arcs _________________ Thonk - Modular Synth DIY
| Back to top |
regenbot Veteran Wiggler
  Posts: 540 Location: Finland
Posted: Sun Jun 03, 2012 2:45 am Post subject: |
I like the Spirograph panel more  _________________ sounds
drawings
free music |
| Back to top |
cr Common Wiggler
Posted: Sun Jun 03, 2012 3:50 am Post subject: |
Hey Monobass, do you have any idea what the price range will be? I'd be very much interested in one, but still a bit reluctant to vote. _________________ https://www.facebook.com/clausmartinmusic |
| Back to top |
| Back to top |
| Back to top |
NS4W Wiggling with Experience
Posted: Sun Jun 03, 2012 4:32 am Post subject: |
thanks 4 initiating! i think the spirograph version would rock the LEDs! _________________ http://soundcloud.com/ns4w/ |
| Back to top |
mckenic pew!pew!pew!kthnxbye!
  Posts: 3228 Location: Limerick, Ireland
Posted: Sun Jun 03, 2012 6:13 am Post subject: |
Oh sweet Jesus please let it be the Right panel!
Dont know why but I really, really dislike the swirly onion one! _________________ DONT FORGET TO DONATE TO KEEP MUFFS ALIVE!
mCKENIC.cOM | mCKENIC Soundcloud |
| Back to top |
| Back to top |
lms.ktp the slowest growing eurorack owner
Posted: Sun Jun 03, 2012 7:52 am Post subject: |
out
| Back to top |
Posted: Sun Jun 03, 2012 8:00 am Post subject: |
You know what! I want one anyway please - this is a great project and I'd be stoked to have one in my rack  _________________ DONT FORGET TO DONATE TO KEEP MUFFS ALIVE!
| Back to top |
monstrinho Super Deluxe Wiggler
 Posts: 1079 Location: mundo afora
Posted: Sun Jun 03, 2012 8:02 am Post subject: |
| Please count me in. |
| Back to top |
Memory_Leak Wiggling with Experience
 Posts: 442 Location: 127.0.0.1
Posted: Sun Jun 03, 2012 8:18 am Post subject: |
two for me please  |
| Back to top |
amsonx Grey Man Patcher
   Posts: 1118 Location: Genova, Italy
Posted: Sun Jun 03, 2012 8:41 am Post subject: |
Count in me for 2  _________________ FS (EU) A-187-1 DSP
http://soundcloud.com/antimediascrambler
richard wrote:
"we just need some mutlinational to grab the copyrights over the sine wave and we are all fucked" |
| Back to top |
Dego Veteran Wiggler
    Posts: 663 Location: Sweden
Posted: Sun Jun 03, 2012 8:55 am Post subject: |
I want two
| Back to top |
rowman birds are dinosaurs
 Posts: 573 Location: Melbourne
Posted: Sun Jun 03, 2012 8:57 am Post subject: |
| swirly onions, two of em. Thanks |
| Back to top |
bleeps Ultra Wiggler
   Posts: 878 Location: LA CA USA
Posted: Sun Jun 03, 2012 8:59 am Post subject: |
| Original recipe for me (the right). In for one or two depending on final price. Thanks for doing this! |
| Back to top |
Posted: Sun Jun 03, 2012 9:06 am Post subject: |
One spirograph - the elegant and stylish option  _________________ http://soundcloud.com/ns4w/ |
| Back to top |
Posted: Sun Jun 03, 2012 9:15 am Post subject: |
| Just one thought; is it possible to make these with oval mounting holes instead of circular? Makes it much easier to correct any potential gaps between modules. |
| Back to top |
raisinbag Super Deluxe Wiggler
Posted: Sun Jun 03, 2012 9:31 am Post subject: |
| Interested but honestly depends on price. If they are really cheap I would get a few. As for design I dont care, would rather save a buck if one is cheaper. Just my two cents, wait my one cent, as you can see I'm pinching my pennies (since we don't make them anymore here in Canada!). |
| Back to top |
