| View previous topic :: View next topic |
| Author |
multi midi out ports thru ES-4 expander? |
ts-12 Learning to Wiggle
Posted: Fri Jun 08, 2012 11:19 am Post subject: multi midi out ports thru ES-4 expander? |
| since gate expander has 8 ports, I can use each port to transmit 16 usual midi channels, each of the 8 ports can work as individual midi port simultaneously? |
| Back to top |
bil_g Common Wiggler
  Posts: 168 Location: WV
Posted: Fri Jun 08, 2012 1:21 pm Post subject: |
| Yep. Just realize that each port will require a separate instance of the ES-4(or 5, I guess) Controller plugin. You can use the 'thru' function to chain them together since they all need to go to the same spdif outs. |
| Back to top |
Posted: Fri Jun 08, 2012 10:00 pm Post subject: |
so I can't use all 8 ports on es-4 expander as 8 midi out ports with one es-4?
If i would want to use 8 midi out ports, I will need 8 ES-4s and one ES-4 expander? |
| Back to top |
chrisso Super Deluxe Wiggler
Posted: Fri Jun 08, 2012 11:07 pm Post subject: |
| I think he was talking about multiple plug-in controllers, not the Euro modules. |
| Back to top |
Posted: Sat Jun 09, 2012 11:27 am Post subject: |
What chrisso said.
The plugin is what deals with MIDI but each instance of the plugin can only operate as a single MIDI port. That's why you need 8 instances of the Controller plugin to use all 8 Expander outs as MIDI ports. Check out the 'thru' function in the ES-4 Controller manual.
You don't have to use all 8 for MIDI, of course. That's just what it would take to set up what you described on the software side. |
| Back to top |
Posted: Sat Jun 09, 2012 11:37 am Post subject: |
no I'm asking about hardware actualy.
I have alot of MIDI modules and keyboards, which are collecting dust right now because I can't really use them with my DAW due to high jitter in Windows 7 thru USB.
after i found out about the ES-4 Spdif to midi conversion, now Im interested in buying it, but first i wanna make sure if i can send multiple midi out ports to my midi modules.
I don't really wanna chain them together in series by midi thru from one midi out port.
for example, lets say I have 4 MIDI sound modules. How many Hardware ES-4s and ES-4 expander do i need to output MIDI from my computer to each module, 16 channels per each module. ? |
| Back to top |
Posted: Sat Jun 09, 2012 11:43 am Post subject: |
Just one of each.
1 ES-4 and 1 Expander = 8 MIDI ports |
| Back to top |
Posted: Sat Jun 09, 2012 6:16 pm Post subject: |
| Ok, I'm ordering, after I find where to buy Eurorack and power supply, (in NorthEast U.S.) |
| Back to top |
