Key voltage
Author Key voltage
kecked
Can I use a simple pot off the dizzy bus to control key follow voltage or should I buffer it first? Sometimes you don't wont the full Key cv. This would only be for the vcfs.
Synthbuilder
You can use a 47K lin single pot...
... but the wiper signal will be a relatively high resistance and may be liable to pick up unwanted stray signals if the connection to the next module is long. I'd buffer the wiper signal if you are thinking of distributing the potted down CV to a number of modules.
Tony
