TM3030 Power
Author TM3030 Power
Barcode
I'm currently working on my TM3030 build and I need a little clarification. The build notes state that it can run on either AC or DC power... If I choose to run it on DC (I have a few 24v DC adapters laying around) do I just connect to the same headers labeled AC Power? If there any benefit to using AC power? Thanks!
Synthbuilder
Yes. Once built your module can be run from either AC or DC supplies. Just be sure you wire up the power inlet socket as detailed in the Builder's Guide.
There are no advantages to running the unit on either AC or DC. Although, DC wallwarts do tend to radiate less 'hum' from the output lead.
Tony
