| View previous topic :: View next topic |
| Author |
Using a pair of same oscillators |
a scanner darkly a fuzzy beacon
 Posts: 798 Location: Vancouver • Seattle
Posted: Wed Jun 13, 2012 4:12 pm Post subject: Using a pair of same oscillators |
I keep seeing people recommending having a pair of same model oscillators. Is there a reason for that aside from being able to have a dual voice?
It seems to be implied that you get better results with FM when using a matching pair - is that true? Are there other reasons?
Tried searching to no avail - if there are threads about it already will appreciate being pointed in the right direction. _________________ music • dj mixes • eurorack video tutorials • bug |
| Back to top |
estin Learning to Wiggle
Posted: Wed Jun 13, 2012 4:33 pm Post subject: |
well I ordered 3 of the dotcom oscillators in my system 22 that is coming. I figured if 1 sounds great, 3 will sound fantastic.  |
| Back to top |
rjungemann Wiggling with Experience
 Posts: 254 Location: CA, USA
Posted: Wed Jun 13, 2012 4:47 pm Post subject: |
If you choose to either layer a handful of oscillators (for example for a detuned saw sound) or decide to do polyphony, you will get a more consistent sound if you use the same oscillator.
Some oscillators are triangle-core and some oscillators are saw-core. Other waveforms generated from these basic waveforms will have slight imperfections (for example a sine might have an almost imperceptible point at the peaks). When layering more oscillators of the same type, the harmonics will be more similar.
Furthermore, some oscillators reset to the beginning when synced, and others reverse when synced. It may sound messy if you pair oscillators with different syncing styles.
But by all means, demo different oscillators and buy what you're moved to buy, even if you buy oscillators that don't necessarily match. If you're not going to do matched polyphony and you're not interested in making detuned saw sounds (or you already have an osc that can do detuned sounds already), there really isn't much of a reason to pair up oscillators. There is something to be said for getting a digital osc (like a Cyclebox or Piston Honda) and a more conventional analog osc too, to create a wider variety of sound. |
| Back to top |
diophantine Super Deluxe Wiggler
  Posts: 1427 Location: San Diego, CA
Posted: Wed Jun 13, 2012 4:54 pm Post subject: |
Cross-modulating two oscillators of the same type is also an enjoyable activity!  |
| Back to top |
Posted: Wed Jun 13, 2012 4:58 pm Post subject: |
Yeah, when I said "dual voice" I also meant thickening the sound with slightly detuned oscillators, basically any patch that would require having 2 sound sources with very similar characteristics.
And a good point about saw core and triangle core sync being different but still, it seems there is another reason for having a paired up oscillator in your system. Variety is good (and I have several oscillators, digital and analog) but it seems in every "help me choose my next oscillator" thread there is always advice to get another same oscillator in addition to the one you already have and like. Perhaps there is no any specific reason other than expanding your system with what you already know works for you, but that was the impression I was getting from those threads. _________________ music • dj mixes • eurorack video tutorials • bug |
| Back to top |
Posted: Wed Jun 13, 2012 5:00 pm Post subject: |
| diophantine wrote: | Cross-modulating two oscillators of the same type is also an enjoyable activity!  |
But is there a reason why it's better (if it is) than cross-modulating different oscillators? _________________ music • dj mixes • eurorack video tutorials • bug |
| Back to top |
Dr. Sketch-n-Etch Super Deluxe Wiggler
   Posts: 2553 Location: Vancouver, BC, Canada
Posted: Wed Jun 13, 2012 5:08 pm Post subject: |
One reason to use more than one of the same oscillator is because they will probably track together better. The Dixie, for example, has very good tracking over about 8 octaves, and serviceable tracking for 2 octaves beyond that. What little tracking error there is tends to fall in the same places in the audio spectrum. That means that, even though Dixie tracking might not be perfectly accurate, it will be very precise with respect to other similarly calibrated Dixies. This, I assume, also applies to other VCOs. _________________ And this abundance of technical means allows the heart to overflow freely.
Olivier Messiaen (1908-1992) |
| Back to top |
| Back to top |
Posted: Wed Jun 13, 2012 5:30 pm Post subject: |
| a scanner darkly wrote: | | diophantine wrote: | Cross-modulating two oscillators of the same type is also an enjoyable activity!  |
But is there a reason why it's better (if it is) than cross-modulating different oscillators? |
"Better" is of course subjective. Also, bear in mind that you need not limit yourself to FM, but other modulations as well (some of which may be oscillator specific).
Perhaps it is just me feeling more comfortable, and working with a pair of oscillators that respond similarly, but I've been much more pleased with the results from crossmodulating two similar vcos, rather than two different vcos. |
| Back to top |
whitewulfe Chaos beckons, I heed the call
  Posts: 1670 Location: C-YXD (Edmonton, Canada)
Posted: Wed Jun 13, 2012 5:44 pm Post subject: |
I went with triplets, not only because it was a good deal, but it maximizes the use of the Triple Soft Sync module I got with them ^_^
Plus Q106s are just... Sexy, and so versatile. |
| Back to top |
richard bananaphile
    Posts: 6251 Location: Berlin
Posted: Wed Jun 13, 2012 5:49 pm Post subject: |
Loads of people have posted over the years that the M15 is particularly fantastic when FM'd or cross-FM'd with another M15 or M37 (which apparently shares the same core). My own experience is that the M15 also sounds as great, and possible better, modulated by a variety of other sources too, e.g. Doepfer A-143-9, Cwejman D-LFO, Wiard Anti-Osc, A111, RS95, Cyclebox. Also I never really thought the M37s stood out as an FM modulation source for the M15 at all (though not having a sine could be a big part of that). I felt the same way about the A111, didn't see much benefit having a pair. On the whole I think I prefer crossbreeding
The matched tracking and timbrel consistency are good arguments though, and if I ever played chords on my modular (which I doubt will ever happen) I'd want as many near identical VCOs as there were voices in those chords
(Through thinking about this stuff I've just realised I've never really explored the E350 as an FM source - it has to be killer, right? ) _________________ stuff: http://richard-scott.net
sound: http://richardscott.bandcamp.com/
vision: http://vimeo.com/richardscot/videos
LATEST RELEASE: http://vicmodrichardscott.bandcamp.com/album/gurgle-sputter-rungle-bli ppoo-box-solos |
| Back to top |
Posted: Wed Jun 13, 2012 6:01 pm Post subject: |
I wonder if that has anything to do with the fact that M15 is supposed to be one half of 258, and from what I've seen/read about 258 so far it seems that 258 design encouraged self cross modulation (just my guess).
And not to mention DPO but it is a _dual_ oscillator with prepatched cross modulation on steroids. _________________ music • dj mixes • eurorack video tutorials • bug |
| Back to top |
transistor logic Wiggling with Experience
  Posts: 426 Location: Montreal
Posted: Wed Jun 13, 2012 6:06 pm Post subject: |
well i guess having identical modules helps understanding better whats going on . i mean if tomorow you buy a second osc of a model you already have you already know it inside out and are ready to go . if you buy a new one you have to learn how it reacts to stuff , experiment and learn it inside out to take full advantage of it . if you have 8 different oscillators chances are that some of them are still mysterious to you , if you have eight times the same , i bet you know it really well in all its tiny details . personally i dont have twins or triplets yet . but someday i hope i will
i dont think i am being very clear here , sorry bout that |
| Back to top |
Posted: Wed Jun 13, 2012 6:28 pm Post subject: |
| a scanner darkly wrote: | A trick question: is FM on a Dixie better when it's FM'd by another Dixie?  |
In principle, of course, no. However, there are a couple things to consider: 1) the sine on the Dixie has very low THD, which is a plus for certain types of FM, and 2) the Dixie's waveforms are pretty symmetric, which is good for FM'ing VCOs (like the Dixie) which do not have AC-coupled FM inputs.
But these are actually pretty minor points. Some VCOs do respond better to modulation in general, of course, but I personally can't think of any real reason why a particular modulation source would work better with a specific VCO. _________________ And this abundance of technical means allows the heart to overflow freely.
| Back to top |
Posted: Wed Jun 13, 2012 6:53 pm Post subject: |
It would make sense then that perhaps oscillators that get recommended as pairs are the ones that are good as FM modulators.
Thanks Dave, those are interesting points, I should read up on FM (or even better buy you a beer and pick you brain sometime ). _________________ music • dj mixes • eurorack video tutorials • bug |
| Back to top |
Moog$FooL$ Broke Dick Dog
    Posts: 1217 Location: Vancouver, BC.
Posted: Wed Jun 13, 2012 10:26 pm Post subject: |
hmmm..... hadn't noticed many other folks from Van. around here lately.
hello asd!
perhaps it's time for doing one of those old VanSynth Saturday afternoon coffee get togethers.
been awhile...... how about u Doc., what'd ya say?? |
| Back to top |
Posted: Wed Jun 13, 2012 11:41 pm Post subject: |
| Moog$FooL$ wrote: | hmmm..... hadn't noticed many other folks from Van. around here lately.
hello asd!
I'm always up for a coffee get-together! The last time I saw a scanner darkly in the flesh, he was still called a fuzzy beacon. (How is that patching software coming, by the way?) Plus, Moog$Fool$, it's been over two years since your awesome synth meet at the Little Mountain Gallery (which was pretty historic for me because that's where I first met Danjel van Tijn). I think maybe we're overdue! _________________ And this abundance of technical means allows the heart to overflow freely.
| Back to top |
Posted: Thu Jun 14, 2012 12:14 am Post subject: |
well looks like Saturday wants to rain.
maybe this Sat. @ The Main. 1pm?
| Back to top |
JohnLRice Howl at the Moon
    Posts: 7697 Location: Western WA USA
Posted: Thu Jun 14, 2012 12:17 am Post subject: |
Well, possibly. I agree with the good Dr. Sketch-n-Etch on similar tracking being a reason to get multiples of the same VCO and that point applies to FM'ing in certain situations where two VCO's are tracking a keyboard or sequencer and one is the sound source and the second is FM'ing the first. If you dial in, say a solid ring mod / bell type of sound for instance and the tracking isn't identical on both VCOs, your sound will start beating etc. _________________ | My Facebook | My Soundcloud |My Vimeo | My YouTube | My GrooveShark | |
| Back to top |
Posted: Thu Jun 14, 2012 1:03 am Post subject: |
| Moog$FooL$ wrote: | well looks like Saturday wants to rain.
Yeah, maybe, if we don't end up going to see Prometheus that day. _________________ And this abundance of technical means allows the heart to overflow freely.
| Back to top |
