Part number needed for Elektron EU power cord
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear
Author Part number needed for Elektron EU power cord
sempervirent
Last Visit: 20 May 2013
PostPosted: Mon Jun 18, 2012 10:07 am    Post subject: Part number needed for Elektron EU power cord Reply with quote Add User to Ignore List
Anyone in the EU with an Octatrack or an MKII Machinedrum?
I'm traveling from the US to the EU and want to take my Octatrack. I need to know the part number for the power cord (not the PSU with attached cable that plugs into the device, but the detachable cable that goes from the PSU into the wall). The Elektron power supplies are the switching type, so all I need is the power cord that will fit in an EU outlet.
On US cords the part number is stamped into the space between the wall plugs, I'd imagine it's in a similar place on EU plugs.
Elektron, in their typical evasive fashion, suggested buying the $60 World Power Kit, when all I need is a part number so I can get the same cable from China for $5.
darenager
Bad Mother Fucker
PostPosted: Mon Jun 18, 2012 11:41 am    Post subject: Reply with quote Add User to Ignore List
Its a standard figure 8 type power lead, used in lots of domestic electrical appliances, you should be able to pick one up in almost any town with an electrical/electronics store in the country you are visiting for a few euros.
http://www.youtube.com/darenager
http://darenager.bandcamp.com/
http://twitter.com/daren_ager
"Man, the living creature, the creating individual, is always more important than any established style or system" - Bruce Lee
sempervirent
PostPosted: Mon Jun 18, 2012 11:44 am    Post subject: Reply with quote Add User to Ignore List
Thanks, since there was some discussion on Elektron-Users in the past about certain cables fitting loosely into the PSU and being too easy to pull out, I'm still interested to know exactly which cable is used by Elektron.
darenager
Bad Mother Fucker
PostPosted: Mon Jun 18, 2012 11:54 am    Post subject: Reply with quote Add User to Ignore List
Ah I see, well mine are just generic ones that I picked up locally, the plug is a little longer than the ones that came with them but they fit very snugly and I have had no issues with them (mine came with euro 2 prong plugs, so I got some UK 3 prong leads to avoid using adaptors) Just checked and there is no part number on them.
tIB
Stainer!
PostPosted: Mon Jun 18, 2012 12:05 pm    Post subject: Reply with quote Add User to Ignore List
Im pretty sure those threads referred to the PSU plug being loose into the machine itself- I had one like that.
Listen
Download
sempervirent
PostPosted: Mon Jun 18, 2012 12:16 pm    Post subject: Reply with quote Add User to Ignore List
Actually, I think you're right. I'll look for one of those figure-eight cables (I believe the technical name for those plugs is IEC C7) or just pick up an adapter (which I could also use for other devices).
darenager
Bad Mother Fucker
PostPosted: Mon Jun 18, 2012 12:32 pm    Post subject: Reply with quote Add User to Ignore List
I'd avoid using an adapter, they tend to be a bit loose in my experience and you can get arcing/crackles if the cable is accidentally jogged.
sempervirent
PostPosted: Mon Jun 18, 2012 12:46 pm    Post subject: Reply with quote Add User to Ignore List
Yeah, that's kind of why I wanted to find a sturdy cable. Arcing is definitely something I want to avoid! I think I'll have to use an adapter for a couple of other small electronics but I just got this cable for the OT, should do the trick.
One question though (I know you guys are in the UK but maybe you know): why do some of the EU plugs have shorter tips and a slim shape (cf. http://www.samtattoo.com/upfile/proimage/20103312011254924.jpg) while the others have a bigger plug and tips that extend further (http://plugsockets.manufacturer.supplierlist.com/productsimages/europ eanpowercord_128193.jpg)?
darenager
Bad Mother Fucker
PostPosted: Mon Jun 18, 2012 1:05 pm    Post subject: Reply with quote Add User to Ignore List
I think it is just due to different brands, mine have longer tips than those supplied, there is around 2mm of the figure8 part that remains unshrouded by the socket when fully inserted, but the connection is fine.
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> General Gear All times are GMT - 5 Hours
