| View previous topic :: View next topic |
| Author |
How important is an ADC for a Modular Syntheticist? |
Setherian Common Wiggler
  Posts: 225 Location: Berlin, Brazil!
| Back to top |
Morley Super Deluxe Wiggler
    Posts: 2331 Location: Belgium
Posted: Wed Jun 20, 2012 12:20 pm Post subject: |
I see any AD as a necessary evil. If I compare a mix where I go live on the desk to one where I go via an AD, it's no contest.
SO, get the best you can but I doubt it will be a night and day thing. _________________ www.davidmorley.com
https://www.facebook.com/davidmorleymusic |
| Back to top |
dogoftears Puddle of Sealions
  Posts: 1692 Location: NorCal
Posted: Wed Jun 20, 2012 12:29 pm Post subject: |
the answer is yes, it will sound different and better. you will also have more headroom and less S/N. it is a very good idea if you exclusively record hardware synths. it's entirely necessary if you want to accurately record any processing/mixing/mastering through high-end outboard gear like tube compressors, 500 series rack, channel strips, etc.
you don't need it, but it will sound good. the RME is a good choice for "prosumer" quality for the mean time. a high end ADC is definitely on my list of desired gear, but it's fairly low down on the priority list considering how much you have to spend for 4-8 quality channels. it's an issue that always bugs me, though, when im pricing out some of the outboard gear i want. its like "okay... i could get this tube comp, this eq, and this pre amp for x thousand dollars... but oh wait all of that will be pointless unless i get this 2-3000 dollar ADC to record it all with!" so yeah... might be better to take the dive sooner then later. _________________ More Xexify music cus my SC's are all maxed: http://xexify.bandcamp.com
dog-trance http://soundcloud.com/dogoftears
a.c. lyon (weird-beat) http://soundcloud.com/aclyon
dc offset (ambient) http://soundcloud.com/dcoffset
| slow_riot wrote: | | in an alternative reality I think I'd like to be a filthy free flowing psytrance stoner, and perhaps this music gives me a chance to briefly play out this fantasy. |
| Back to top |
Babaluma Manual Gain Rider
     Posts: 6757 Location: Milan
Posted: Wed Jun 20, 2012 12:50 pm Post subject: |
yeah agree with the above, you don't actually need it, but it probably will make a positive difference. you'll need great monitoring to be able to make the most of it though.
main things i noticed when going from prosumer to pro:
the high end sounded like it was extended forever
i could hit the ADC as hard as i liked (even inaudibly clip it a little), and it didn't start to sound shit. (this was something i really noticed with my old echo converters, if i went much past -18dB RMS they started to sound "pinched"). of course, as i'm using them for mastering mainly, this meant i could get a much higher level to digital using the analogue gear, and so i didn't have to use as much digital processing for loudness. always a good thing! _________________ Hermetech Mastering | Discogs | SoundCloud | Bandcamp | Facebook | Pathmusick |
| Back to top |
Posted: Wed Jun 20, 2012 1:31 pm Post subject: |
| Babaluma wrote: | yeah agree with the above, you don't actually need it, but it probably will make a positive difference. you'll need great monitoring to be able to make the most of it though.
i could hit the ADC as hard as i liked (even inaudibly clip it a little), and it didn't start to sound shit. (this was something i really noticed with my old echo converters, if i went much past -18dB RMS they started to sound "pinched"). of course, as i'm using them for mastering mainly, this meant i could get a much higher level to digital using the analogue gear, and so i didn't have to use as much digital processing for loudness. always a good thing! |
oh yes of course the monitoring is part of the vicious cycle of "well if im gonna get that hifi ill need this hifi... +X,000$$"
definitely consider all the expenses that you *will* want to start investing in if you get a nice ADC.
i also find with MOTU, Apogee, and RME that there is very little headroom to capture outboard audio, even though the monitoring output level comes out low. like Babz said this means you have to do more digital gain. in a perfect world the signal comes in as hot as it can and is naturally hot coming out, and when it comes time to master the limiter doesn't need to do so much or any gain. _________________ More Xexify music cus my SC's are all maxed: http://xexify.bandcamp.com
| Back to top |
Posted: Wed Jun 20, 2012 2:01 pm Post subject: |
Just to add, I use SSL converters which are midrange in price. I could hear a very big difference over MOTU 896 and when compared to RME less so but still the low end was MUCH better and the high end transparent and clear.
I still prefer going straight to tape! _________________ www.davidmorley.com
| Back to top |
numan7 numan "sonic" seven
Posted: Wed Jun 20, 2012 2:09 pm Post subject: |
isn't recording to tape kind of like strapping on outboard eq and compression in some ways?
i would just like accurate and precise sampling, throughout the audible range, of the signal being recorded.... no booming bass, crispy mids, sizzingly highs (or other Apogee et al marketing bs)!
cheers _________________ "if you want to raise some hell, VCO2 is your friend - just set the sub pitches to modulate each other in a feedback loop. and enjoy the chaos... " -- karl ekdahl (poster)  |
| Back to top |
Posted: Wed Jun 20, 2012 4:11 pm Post subject: |
I don't know. Look at speakers. We like some and don't like others. They have a sound and whatever we put through them will have that sound. No way around it. Tape does this too but for most people it does seem to be a limitation with musical side effects (slight rolled off high end, slight compression etc) as opposed to digital which has negative side effects. The better you get, the less there are but they are still present.
Purely analytical speakers will not be pleasant to listen too. That is the trick with monitors. To make them listenable AND accurate. I guess that goes for converters too.
And good quality tape is actually remarkably transparent. Not the exaggerated lo fi tape sound many think is tape.
BTW, I meant mixing straight to 2 track, not multi tracking.
Cost issues make digital a clear winner though. Cheap tape sound sucks as does cheap analogue, but high quality analogue still wins out in my book over high end digital.. _________________ www.davidmorley.com
| Back to top |
Posted: Wed Jun 20, 2012 4:12 pm Post subject: |
Hey Morley, what tape recorder do u use or recommend?
I will get something new in the next few days, it will either be a good AD converter or a lunchbox with 2 pres and a stereo comp (Vandergraph?).
And perhaps a Elysia Nvelope on the top..
So I wonder whats a priority here, Pres, Compression or ADC? _________________ http://soundcloud.com/dragns
http://soundcloud.com/lunaire
http://soundcloud.com/baz-ofia |
| Back to top |
Posted: Wed Jun 20, 2012 5:50 pm Post subject: |
thanks for a very cogent and concise explanation, morley!
| Back to top |
Entrainer Super Deluxe Wiggler
Posted: Wed Jun 20, 2012 5:58 pm Post subject: |
Why Burl B2? It has a "sound". Personally, that's the last thing I want
my ADC to have. Especially for a modular synthesizer.
If you want transformers to use as coloration, get a nice preamp/DI.
Then you can choose multiple colors with different pres.
I'd recommend the Black Lion Sparrow MKIIs (Red or White). Use it as the
clock into your RME.
And when those pros say "this is the first time what I record sounds EXACTLY
like what's is coming from the board"... it's true (MKII white).
Analog SOUNDS analog. I know you folks know what I'm talking about...
the sound of live analog modular, captured. _________________
| Back to top |
Fnord Discordian Wiggler
    Posts: 1895 Location: Dirty Jersey
Posted: Wed Jun 20, 2012 6:07 pm Post subject: |
I like the B2's "sound", but I also use crazy pre's and a tube mixer... _________________ bsmith: it would be awesome to see people with lots of euro give them pokemon values and do battle
Muffwiggler: I've seen communities ruined over politics. I've seen friendships end over racism. I've never seen these things happen as a result of breasts. |
| Back to top |
NV Super Deluxe Wiggler
Posted: Wed Jun 20, 2012 7:40 pm Post subject: |
I'll be the asshole that says if you're not sure whether or not you need a $2,500 2-channel ADC, then you probably don't need it. What does the rest of your studio look like? Do you have professional outboard pres, compressors, and EQs? Or is the RME your only outboard? Do you only record your synthesizers, or do you use microphones or DI guitars?
The difference between a cheap converter and a "good" converter can be pretty noticeable, but less so in the difference between good and "pro." Investing in a high-end converter to me is a last step audio engineer sort of thing to do, with room treatment, outboard, instruments, and technique coming way before. You'll hear a difference between the B2 and your RME, but realistically it won't be the amount of difference you would hear or experience investing that $2,500 elsewhere or in an overall better multi-channel interface. In short (and in my subjective opinion), if you're engineering albums for others as a career and primary source of income then absolutely a high-end 2-channel converter is a good idea. If not, a "good enough" multi-track interface is certainly good enough. |
| Back to top |
Posted: Thu Jun 21, 2012 1:45 am Post subject: |
| Setherian wrote: | Hey Morley, what tape recorder do u use or recommend?
So I wonder whats a priority here, Pres, Compression or ADC? |
My gearslut side will always go for toys over practical stuff! Get the lunchbox :-)
The Nvelope would be first on my list.
I use an MCI JH110 (needs a service now though) 1/4"
I used to use a Revox PR99 which was great too.
Another point re AD converters. If you are doing many layers and recording many times with an AD, any issues are obviously multiplied.
If you are recording a few layers, then it will be less critical.
I guess my main feeling is that for me the best sound I have had or heard is when avoiding everything and going live through a nice analogue desk straight to 2 track (avoiding multi tracking) but obviously this is not always practical.
Grab the outboard  _________________ www.davidmorley.com
| Back to top |
evs Wiggling with Experience
    Posts: 298 Location: Cologne
Posted: Thu Jun 21, 2012 2:49 am Post subject: |
why dont sell the rme stuff and buy a metric halo device?
very very good AD / DA converters and an audio interface, too.
or just try to record (if you don´t have done it allready) in 192kHz.
the difference from this to 44,1 is immense. even with a low cost AD converter. _________________ www.emilklotzsch.de
www.tonsturm.com
www.filmtongestalter.de |
| Back to top |
Posted: Thu Jun 21, 2012 4:04 am Post subject: |
lots of people believe 192 is a complete waste of time. can actually sound worse as the clock has to be of even higher quality. try and track down dan lavry's AES papers called "Sampling Theory", and the more recent one, "The Optimal Sample Rate For Quality Audio".
on the other hand, i heard roger foote say he really prefers 192 and can totally hear the diference, so as you say evs, best to try it for yourself! _________________ Hermetech Mastering | Discogs | SoundCloud | Bandcamp | Facebook | Pathmusick |
| Back to top |
Posted: Thu Jun 21, 2012 5:43 am Post subject: |
thanks, did not know this paper!
however, i find that 192 is sounding better than 44,1.
but i never made an blind test with that..
however, i think the only way to tell if you hear a difference between different ad converters or sampling rates is to make a blind test.
so regardless of what the internet says:-), make a blind test and decide whats important for you. thats all what it is about!
by the way, is anyone using here anything from metric halo? |
| Back to top |
| Back to top |
| Back to top |
ndkent Super Deluxe Wiggler
| Back to top |
